Xerox Color C75 Press error 077-333 - Office Equipment & Supplies
There's a small black "x" mark on every print on our Xerox C75 digital press.
The only thing I can think of is the IBT belt might have a mark on it. If the 'X' mark is in the same place on each print, regardless of size A3 or A4 then the problem is being printed intentionally e.g. within the file, if it's more random then it could be the belt. Is it only in the black, if so recheck the black drum. Is the mark on the edge of the paper it could be the cleaning system problem.
This is one problem that would need to be seen.
Good Luck.
May 27, 2015 | Xerox Office Equipment & Supplies
Xerox error code
Try this:
Enter Service mode:
1. On the Control Panel, press the Down Arrow button to select
Troubleshooting and then press OK.
2. Press the Down Arrow button to select Service Tools, and then press
OK.
3. While pressing and holding down the Up Arrow button, press the Down
Arrow button to display the Hidden Service Menu.
Select Reset Error Log
Reboot the machine? Yes
Wait for about 15 min.
Should be all right after that.
Last time did work just fine for me!
If don't work mail me at:
innovaprinters@hotmail.com or
impressaodigital.poa@hotmail.com
And we try something else.
Jul 22, 2014 | Xerox Corporation Xerox ColorQube 8570DT...
Xerox XC 1045 has a flashing H 4 error.
elem_1_spacer.gif Performing a Fault Reset 14 will reset your copier and will help to clear error codes.
  1. Turn the power off.
  2. Locate the Clear Button, which is grey in color, in the upper right corner above the green Start Button.
  3. Locate the Auto Button the lower left corner of the Control Panel.
  4. Turn the power back on.
  5. Press the buttons in the following sequence, releasing each button after each time you press it: [Clear], [Auto], [Clear], [Auto]. Every light on the Control Panel should go out, and the error code should clear.
  6. If the error code has not cleared, wait a few seconds then repeat Steps 1 through 5.
  7. Program the copier as if you were going to make 14 copies.
  8. Press the green [Start] button to store the reset code. The copier will return to the ready position.
  9. Run a test copy.
Jul 01, 2009 | Xerox Office Equipment & Supplies
Xerox majestik 5765 error codes
Sorry I am not familiar with this machine, usually if you press the start key for 3 sec it should show you the other codes? Good luck.
P.S.: If i run into anything I'll send it to you .
Jan 12, 2009 | Xerox DocuColor 12 Color Copier
Error Code 10-399
Hello sir; The problem you have can be reset, just follow the steps as below;
1, power on the machine.
2, while hold down the 0 key, press start.
3, enter the access number 6789
4, click onNVM reset/NVM initialization.
5, enter 777-018 press start.
if still have problem let me know
Jan 02, 2009 | Xerox DocuColor 12 Color Copier
Phaser 860 error code 07.003.45:116163
It is a print head tilt error.
Most likely ink is in the stainless steel pivot block at the bottom of the print head.
Also the printer could have been unplugged and the cleaning blade is stuck to the print head.
Or a cable is binding the print head movement.
Nov 12, 2007 | Tektronix Phaser 860DP Thermal Printer
1,194 people viewed this question
k24674
jasbo
jasbo
