Question about Wine & Spirits
Cant get to days telly bingo results - Wine & Spirits
Why cant i get bingo on club pogo .com
Make sure your Java and Shockwave player are up to date
Apr 28, 2013 | Computers & Internet
Cant get onto bingo .net?
I can, check it isn't a problem with your internet connection.
Jun 26, 2012 | iwi Bingo .net
I play party dice on facebook and for two days I cant download the game
this is property of FB..so u cn't get it..use IDM full version.
Mar 11, 2011 | GamePoint Bingo
Since digital switch i cant auto tune my telly with out a password
since digital switch i cant auto tune my telly with out a password
Dec 04, 2009 | Toshiba Regza 37HL17 37 in. LCD TV
Cant seem to fine the sega mega drive2 on my tv
hi, if your plugging the sega mega drive into the airial socket ie same fitting as the arial then what you need to do is make sure its plugged into the arial socket properly now you need to switch it on with a game in wait for minute or so for the game to load up.
Then you need to put your telly onto a channel you dont use such as 7.
Then you need to use the telly remote and enter the setup mode once in this mode you need to use the setting that lets you scan for the telly channels.
Now depending on your telly this will either be an auto tune or manual or both if you can choose then pick the manual type.
Once this is selected you then need to choose witch way your going to tune ie up or down.
Make sure on the menu your tuning the channel you want ie 7 or what ever you want to use.
Now it dont matter witch way you start scanning so start the scanning then just keep going the one way then eventually you will get the screen tuned into the mega drive you then need to save this setting into the channel your using.
Right now you have done all that if by any chance on the lead from the megadrive to the tell it has a switch ok then try it with it in the on possition then scan all the way if after ages you get no picture then press the little switch and scan again.
But depending how old it is you may not have a switch dont worry if not as its less hassle to tune in as you havent got 2 choices.
So their is the instructions if it is an arial socket type connector.
If however it is the three color leads then plug these into the right colors on the telly then make sure you have a game in switch it on wait 1 min or so then get the telly control and find the source or maybe av button depending on your control is will be either of those 2 if it dont have them then look for a small picture on the control it will look like a square box with an arrow running from the right to left this is the av/source button.
Once you have found this button you may need to press it 3 or 4 times untill your on the right input ok then you should have it on(only these instructions if its color leads if not follow first instructions ok)
I know its a lot of info but youll get their in the end (that is if the lead from mega to telly isnt damaged) if after doing what i say you still get no picture then the chances are the lead is damaged and needs replacing but from what i can remember (back in the day) it was just a normal arial lead anyway so you should have one of these lying around.
Let me know how you get on or if you need further assistance ok
Nov 12, 2009 | Computers & Internet
Cant get 42''lcd telly to let me play ps3 threw hdmi cable
You will most likely have to contact your LG dealer to fix this. The problem is due to the HDMI input not recognising the playstation, the cure for this is a software upgrade for External Device IDentification (EDID), which can only be done by a service centre.
Mar 29, 2009 | LG 42LC2D 42 in. LCD HDTV
I have a sega mega drive with all the relevant pieces but i cant tune it into the tv
Hi. is the lead from mega drive a rf socket that goes into the arial socket on the telly and does the lead have a switch on it?
Plug the rf lead from md into areial socket on telly
then put telly on channel you dont use i used 0 or 9 but use any.
then turn mega drive on
then press setup on tv
enter channel settup then you need to go through the procedure of tuning channel in its best doing it manualy its like when you tune a channel in make sure md is on then keep changing the frequency one way or the other could take few minutes then when you get it on the telly save this setting on the channel you want to use ok.
If it dont work then the chances are the lead is damaged this is often the case with these consoles as the are not made that well so if no good then replace if necesarry.
If your unsure on tuning your telly then give me make and model then i can talk you through the process ok
Apr 22, 2008 | Video Game Consoles & Games
Panasonic Tx-28PL1
Check Horizontal Output Transistor....if shorted,replace both
Horiz out transistor and flyback transformer...Use Panasonic
original parts, if possible.If transistor checks ok, then just replace flyback transformer ONLY.......................T.
Jan 25, 2008 | Panasonic TX-28CK1 28" TV
Tv turns on get piture then get fuzzy whit line then goes off pleaze help me
i had this same problem, there is a common fault with these models, and the onyl way to fix it is to get a chip replaced in there...cant remmerb the name of this, but it cost me about £30, now the tvs fine
Oct 31, 2007 | Televison & Video
Wine & Spirits Logo
78 people viewed this question
Top Wine & Spirits Experts
deton8 von Splosion
Dave braun
Dave braun
guymark
Level 1 Expert
Are you a Wine and Spirit Expert? Answer questions, earn points and help others
