Question about Staples One Touch High Capacity Stapler
My new stapler is beeping and the red lights flash
The stapler maikes a beeping noise and the red lights are flashing
Blue parrot lights blue and red keep flashing and there aren't any beeping noises
If your headset is 6 or more months old, it could be the rechargeable battery is due for replacement. The power supply or battery is the one thing that can cause all sorts of odd symptoms. I read your post and put a known bad battery into one of my 3 Blueparrott B250-xt headsets and did just as you described. If you would like to order a new battery for this headset, email me at ebhammonds@gmail.com. They are $20 and shipping is free.
Jan 02, 2012 | Radio Communications
Ps3 wont stay on
charge it red light turning of and beeping is meaning its dead
Mar 02, 2010 | Sony Playstation 3 (PS3) Console
Brake pressure light flashing- red light on dash stays on
if brakes work ok leave well alone ,this sounds like an electrical fault that big money to repair.At the end of the day the brakes are failsafe manually operated
Jun 06, 2009 | 1989 Lincoln Town Car
Lexmark c530dn red light on
Operator panel display blank, five beeps, and LED off
Service tip: The printer has detected a problem with the system card, the operator panel assembly cable (part of
the top cover access assembly), or the operator panel assembly if POST does not complete. The printer emits
five beeps, and sticks in a continuous pattern until the printer is turned off.
Is this what you are getting?
Mar 12, 2009 | Lexmark C530dn Laser Printer
It doesn't start up, only beeps and red light flashes
pls try to use another compatible memory stick.
then confirm the status of your micro processor
Apr 21, 2008 | HP Compaq dc7100 Ultra-slim PC Desktop
Light keeps flashing red,amber, green
If you turn off the printer and turn it back on, do you get any noises, ie motor noises, or does it instantly go to all lights flashing?
If you get no noises this usually indicates a board fault and you should look for a new printer.
Apr 07, 2008 | Brother HL 5140 Laser Printer
Packard Bell
Check out the following link:
http://support.packardbell.com/uk/item/index.php?i=topic_02437&pi=platform_storeandsave3500&dhepn=C050890000
It includes the following:
Beeping noise and flashing LED
dot.gif dot.gif Situation dot.gifWhen I turn on the Store & Save, it makes a beeping noise and the LED flashes continuously. dot.gif Details dot.gifThese symptoms indicate that the AC adapter is not providing enough power. dot.gif Solution dot.gifThe AC adapter will need to be replaced. I hope this helps, Bob
Mar 24, 2008 | Computers & Internet
Lock/unlock signal beeps
if you could send the serial number it will help me determine who manufactured it for sears and then point you in the right dirrection.
Sep 16, 2007 | Kenmore Elite HE4 Electric Dryer
My tricity bendix washing machine flashing and beeping end light
Hi, we had something similar happen just before christmas. Our machine seemed to finish a cycle and started making beeping noise with end light flashing. Then when I switched it back on to do another load it just started beeping with end light flashing no matter what cycle was selected. Engineer has been out and advised that it is a fault with the motherboard so has ordered another one. Hope this is of some help. Machine was tricity bendix aw1400w.
Dec 14, 2006 | Tricity Bendix AW1400W Front Load Washer
Staples One Touch High Capacity Stapler Logo
22 people viewed this question
Top Staples Office Equipment & Supplies Experts
Saleem Baig
Saleem Baig
Randy Schumann
Randy Schumann
Are you a Staples Office Equipment and Supply Expert? Answer questions, earn points and help others
