Question about DURAGADGET Sunrise design Pocket size Phone Pouch / case / sock for Nokia C2 , Nokia C1-00, Nokia C1-01 , Nokia C1-02, Nokia X5-01, Nokia 5235 Comes With Music
I want restore factory setting Basic code to rest factory is 12345 but if it is not working my imei no-353283/05/788151/3 plz help me. my no 8561098298 & my id is gajendragajendra852@gmail.com
Sir i have nokia 2630 phone i forget my restorefactor setting my friend changing for defult 12345 code my friend changing for new password i con't finout plz help me IMEI : 359305/02/59923/7
Dear,
You have to connect your phone with the pc and need a flash box then from there you can default your restore factory code which is 12345.If you haven't then please go to any mobile servicing center then asked them to restore your factory code. Thanks
May 24, 2014 | Nokia 2630 Cell Phone (Unlocked) - Black
Securety code eror
check this one
Master Code Generator will Instantly generate your Nokia's Master security code.
This service can be used if you need to reset your Security Code.
Your IMEI: 356924034968264 --
Your Nokia Master Code: 2401254345
or this one
Nokia 5000 hard reset
You can format your Nokia 5000 device by typing: * + 3 + call + Power on. Before the device is reset, you need to provide the lock code. The default lock code is 12345.
If it is not working try this code:
You can format your device by typing *#7370# in standby mode. Before the device is reset, you need to provide the lock code. The default lock code is 12345.
Some Nokia phone can be reset via this menu option
Press menu button or enter Menu > Settings > Phone > Phone management > Factory settings > Delete data and restore > YESRestore factory settings
To restore the phone back to factory conditions, select Menu > Settings > Rest. factory sett. and from the following options:
Restore settings only - to reset all preference settings without deleting any personal data
Restore all - to reset all preference settings and delete all personal data, such as contacts, messages, media files and activation keys
IMPORTANT!
Formatting the device will permanently erase all user data and settings as well as add-on applications and operator specific settings
goodluck
Apr 21, 2014 | Nokia 5000 Cellular Phone
How to reset my nokia c1-01 security code
i forgot my security code
nokia C1-01
plz help me
Sep 05, 2012 | Cell Phones
Sir I forgot my nokia 7210 supernova mobile. 12345 is not working. pls. help me for restore factory. How to crack the code
Remove the battery and the memory card from the phone,check for corrupt files on the memory card with a scan on your PC- card reader. Remove and format if necessary. Reset battery and open menu settings to open link to restore to factory settings- now type 12345. If this wont work then you must reinstall the software. check with Nokia care.
Jan 20, 2011 | Nokia 7210
I need a way to restore my factory settings, but n...
Dial *#06# from your phone. A 15 digit code will appear on the screen, which is called the IMEI number of the phone. Pass this number over to me.
May 20, 2010 | Nokia 5310 Cellular Phone
I have to restore factory setting in nokia 1110i using code 1234,0000 but not accept this code plz help me
Turn of your phone for 30 Minutes and Then Try 12345 not 1234. Please Vote if solved.
May 12, 2010 | Nokia 1110i Cellular Phone
Hello:) i hav problem wid my nokia 1650
ya as he told go to setting / restore factory setting
then it required security code
plz type the code 12345
njoy
Oct 29, 2008 | Nokia 1600 Cellular Phone
Format 6280 nokia
go to menu at your mobile screen >select settings > now select "Restore Factory Settings"............that's it you can do in nokia 6280
Apr 03, 2008 | Nokia 6280 Cellular Phone
DURAGADGET Sunrise design Pocket size Phone Pouch / case / sock for Nokia C2 , Nokia C1-00, Nokia C1-01 , Nokia C1-02, Nokia X5-01, Nokia 5235 Comes With Music Logo
23 people viewed this question
Top DURAGADGET Cell Phones Experts
bobby1964
Level 1 Expert
sandrasteven
colin fenn
Level 1 Expert
Are you a DURAGADGET Cell Phone Expert? Answer questions, earn points and help others
