Question about Swingline 48209 Optima ® 45 Electric Stapler
Papers stick to staple area
When you put the paper in it hangs after the staple in inserted
How to install paper
Without a manual, look at the picture of the calculator. Mount the paper, with the feed coming forward and over the top of the calculator. Insert the paper (recommend cutting it flush) into the feed slot in the back. Then use the paper advance key to advance the paper through the rollers. Unfortunately the manual is not available from the Staples website. Good Luck,
Mar 02, 2015 | Staples SPL-P100 Printing Calculator
Can not feed paper
First try moving the switch manually to reverse. The machine should start. This may cause some paper to appear in the slot where you place the paper to be shredded. If it doesn't start, your problem may be more serious or complex and you should get in touch with the Staples store where you purchased it.
It may be that the paper you are trying to use is too lightweight. Try inserting a piece of cardboard (SLOWLY SO AS NOT TO LET THE BLADES CATCH THE CARDBOARD - LETTING IT CATCH THE CARDBOARD MAY BE BEYOND THE UNIT'S CAPACITY). If this starts the shredder, quickly remove the cardboard. If it continues to run (cycle), you may have had some paper blocking it.
Hopefully this has done the trick and everything now works. If not, talk to the Staples store where you bought it.
Jan 08, 2014 | Staples Cross-Cut Shredder
Spl-1506x shredder only runs in reverse
Daniel:
Unplug the shredder... Take the top off and turn it upside down. Use a screwdriver to take the lower cowling off and look at the motor. If the mounting area where the motor sits looks melted at all, the machine is toast. If the motor mounting area looks good, look at the slot where the paper is inserted... there should be a sensor (that "sees" the paper when you insert it) at the paper slot. Check to see that the sensor isn't damaged.
Nov 11, 2012 | Staples SPL1506X (CrossCut) Shredder
Auto setting will not work on Staples SPL-EXC8A
Cleaning of the paper sensors is essential. Blowing on the center of the paper insert area will clear the paper fibers near the sensor but not all. Since my shredder was way past warranty, I opted to remove the 7 screws on the back of shredder mechanism, gingerly remove the shredding mechanism from its seat and there I found, wedged in between one of the sensors, a solitary paper fiber. That ominous, evil paper fiber was wedged in so tight that even the jet engine blasts from a 747 aircraft would have not dislodged the paper fiber. Making use of a Qtip, I dislodged the paper fiber, cleaned out all remaining paper fibers in and around the inside of the housing, then reassembled the unit. It has worked satisfactorily since then.
Apr 24, 2012 | Aurora Electronics AS1018CD Shredder
Runs in reverse and forward ,when insert paper blades won't let paper in
unplug it and then use compressed air (duster can used for pc's) spray this into unit and into teeth area. This should dislodge any unseen material.. (TIP - don't put any staples or clips in the shredder) even thou it says you can - this can cause a jam as well as not recognize paper. I recommend you get Shredder OIL to use 1 a month to keep your shedder in good condition
Jan 01, 2012 | Royal VF700 Cross-Cut Shredder
How do i add more staples
Hi, You cannot add staples while there are still some left in the cartridge, you will have to wait until it is all finished, the paper holder comes out from the bottom of the cartridge, remove the old staple paper holder, pay careful attention or put a mark on the outside, now you are ready to insert the new staples in the cartridge. First you need to remove the new staples and take out the wrapper carefully, line up the arrow with the cartridge and insert it into the cartridge then snap it into place, replace the cartridge in the machine when you are done.
Thats it.
This fix is for the small finisher that hangs on the machine, it`s called M1 Finisher.
If you need a service manual for this model machine you can get it here
http://www.techmanualarchives.com/canon-irc-2620_3200-_3220-service-amp-parts--manual-25171.html
Oct 07, 2009 | Canon Image Runner 3320I Copier
Cant find standby operation
All shredders shut down within afew seconds if they do not detect paper inserted. Safety feature.
Jul 22, 2009 | Office Equipment & Supplies
Paper jam message on esp 7 kodak printer all areas have been checked and no evidence of paper in machine can be detected?
open rear access door and check out if there is any tape in and around the rollers or any torn paper or any staples there.. turn printer upside down and oprn bottom p[aper tray check out if there is any paper stuck there. take power cord out of printer and again insert it back. ur printer will work fine
Jul 13, 2009 | Kodak Office Equipment & Supplies
Panosonic Electric Stapler does not staple paper!
It could be either jammed up with staples or the spring mechanism is shoddy.
Apr 14, 2009 | Office Equipment & Supplies
Swingline 48209 Optima ® 45 Electric Stapler Logo
32 people viewed this question
Top Swingline Office Equipment & Supplies Experts
Paul Bade
Stitch85
Level 1 Expert
Are you a Swingline Office Equipment and Supply Expert? Answer questions, earn points and help others
