Question about Sony Cyber-Shot DSC-W220/B Digital Camera
Where is the reset button the soncy cybershot
Reset button on a 2011 sony cybershot DSC WX9
there is no such thing as a reset button in the DSC WX9 camera. Sony does advice you to remove the battery for more than one minute, and than replace it after that minute, is something unexpected occurs.
Jan 04, 2014 | Cameras
FLASH NOT WORKING, ALL SETTINGS SHOWING GOOD
You may try to reset to factory settings. you may try to restore Locate the RESET button on the camera.Use a pointed object (like a ballpoint pen) to press and hold the RESET button for 2-3 seconds and then release.
Nov 29, 2013 | Sony Cybershot DSC-S950 Digital Camera
Sony cybershot dsc-w330 functions buttons does not work
Remove the battery and the memory card, press and hold power for 60 seconds this should remove residual voltage and reset the processor ic, if there is no change the systems controller board has failed, cheaper to replace camera.
Jun 09, 2012 | Sony Cybershot W330 Digital Camera
Wheres reset button on sony cybershot dsc w130???
I'm glad to provide the information about the Camera. The Camera does not have a RESET button to press manually to reset it.
If you wish to reset the Camera, you can use the Initialize option from the Menu item to perform it if the Camera is allowing it.
Please perform a power resetting if the Camera is not turning ON or you're unable to access the Menu items. Please follow the below steps to perform a power resetting
  • Remove the battery from Camera.
  • Press and hold the Power button for more than 15 seconds.
  • Reinsert the battery
  • Turn ON the Camera.
Thanks for understanding. Please let me know if you require further assistance.
Sep 12, 2011 | Sony Cyber-shot DSC-W130 Digital Camera
Were is the reset button
Hi plozgangster ,
DSCW370 Digital Camera do not have a physical reset button. What you can do is to initialize the settings of the camera. This works the same as pressing the reset button. You may follow these steps:
  1. Press the Menu button to display the MENU screen
  2. On the Menu screen select SETTINGS using the up or down arrow, then press the middle button to display the SETUP screen.
  3. On the SETUP screen, use the arrow keys to go to Main Settings.
  4. Look for INITIALIZE then select it using the middle button
For camera hand out please click on this link
Jun 13, 2011 | Sony Cybershot DSCW370 Digital Camera
My Sony Cybershot. DSC-W370 will not turn on
For me honestly I had the battery in backwards, its not supposed to fit backwards but for me it slid in normal. Line up the pins on the camera inside to the battery contacts. I felt dumb assuming the battery should have been fine, putting it in at least 8 times.
Oct 23, 2010 | Sony Cybershot DSCW370 Digital Camera
When I turn it on the screen stays black until I
  1. Ensure the camera is turned on.
  2. If applicable, ensure the lens cover has been removed before taking pictures.
  3. Ensure the LCD backlight is turned on by pressing the DISPLAY button several times until the screen appears. NOTE: Depending on the camera model, the DISPLAY button may be labeled as DISP or with a display icon [FIG. 1]. This button could be a standalone button or incorporated as one of the control arrow buttons depending on the model of camera.
  4. If operating the camera with a battery, ensure the battery is fully charged.
  5. Ensure the battery is inserted properly in the camera.
  6. If operating the camera with the power adapter, ensure it is plugged into a working AC outlet.
  7. Ensure no Audio/Video (A/V) cables are connected for viewing pictures on a TV; the LCD screen will not display when an A/V cable is connected.
  8. Perform a reset procedure on the camera.
The troubleshooting steps listed above should resolve your issue. If you have completed all of the steps and the issue is not resolved, service may be required. The Sony Service Web site at http://eservice.sony.com/ can assist you in obtaining service from a Sony Service Center or locating a Sony Authorized Servicer.
Try to reset the camera to original settings:
How to reset a Cyber-shot® digital still camera back to original factory settings. Solution
sp.gif sp.gif Cyber-shot cameras nowadays have a built-in rechargeable battery for retaining time, date, and other settings. Since the built-in rechargeable battery is not removable, current Cyber-shot camera models can only be returned to the original factory settings by pressing a small RESET button on the camera or by using an Initialize option in the menu.
Older-model Cyber-shot cameras (prior to the year 2000) do not have a built-in rechargeable battery and do not have a RESET button or Initialize option in the menu. These cameras require a manual power reset.
IMPORTANT: To determine whether or not your camera has a RESET button or Initialize option, or for other model-specific information to complete any of the steps in this solution, refer to the operating instructions supplied with the product. Manuals are available online in the Manuals/Specs/Warranty section of the Sony® eSupport Web site.
Follow the appropriate procedure below for your camera.
Using an Initialize option in the menu
Since Cyber-shot cameras have different menu system layouts, refer to the instruction manual specific for your camera model.
Using a RESET button
  1. Locate the RESET button on the camera.
  2. Use a pointed object (like a ballpoint pen) to press and hold the RESET button for 2-3 seconds.
  3. After 2-3 seconds has elapsed, release the RESET button.
Performing a manual power reset
  1. Turn off the camera.
  2. Remove the battery pack.
  3. Remove the button-sized lithium battery.
  4. Allow the camera to remain without power for 30 seconds.
  5. Reinsert the button-sized lithium battery.
  6. Reinsert the battery pack.
  7. Turn on the camera.
Jul 25, 2010 | Sony Cyber-shot DSC-W80 Digital Camera
SONY CYBERSHOT DSC - H3 DIGITAL CAMERA FLASH PROBLEM
Hi Jim,
Have you tried resetting all settings on the camera? On a Sony camera, it is called "initialize". The initialize setting is found by going to the menu, and tabbing down until you find an option called either "reset settings" or "initialize settings" and then confirm it.
Many times that will fix the issue, in case something has either been enabled/disabled on accident, or the software is sticking (which happens from time to time)
Feb 17, 2010 | Sony Cybershot DSC-H3 Digital Camera
Sony cybershot DSC W30 buttons fail
take the battery out and let the camera sit for an hour or two, take out the memory card, try to view photos on computer, if it does not work, you will have to format the card and start over. Some times when the format on the card is bad, the camera will not work properly. I have two cybershots myself.
Mar 13, 2009 | Sony Cyber-shot DSC-W200 Digital Camera
Dsc-w50 sony cybershot error codes e91:01
Sorry? I never advised of reset button near LCD of this camera.
let me know the problem and I will provide you advise / solution.
Nov 30, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Sony Cyber-Shot DSC-W220/B Digital Camera Logo
16 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
