Question about Allis Chalmers AC130 46" 23HP All Wheel Steer Lawn Tractor
Change tire on ac130 - Allis Chalmers AC130 46" 23HP All Wheel Steer Lawn Tractor
How do i change back tire
are you sure this is correct category, if not please add more detail and repost in the correct catrgory
Apr 24, 2016 | Cars & Trucks
I need belt routing diagram for ac130 allis chalmers riding mo2wer
http://www.allischalmerslawn.com/products/detail.cfm?id=148572cbdaa7a3282d365aca992a6bd8
May 19, 2014 | Garden
Tire size
Yes as long as u change the rims also not just the tires these numbers 195/60/15 195 is tire width 60 is tire height and 15 is rim size, most all Hondas will fit up to 215/35/18 with no rubbing issues on factory suspension ..... Every time the rim size changes u have change the height of the tire so it will fit some go as far as " stretching " the tire to allow larger rims or extreme offsets
Jan 28, 2014 | 2005 Honda Civic
Belt on Allis Chalmers AC130 keeps chewing up. What might be the problem?
Sounds like pulleys are out of alignment. Check to make sure no pulleys are seized up or out of alignment. With belt off, spin one at a time. Do this to all pulleys in the loop. By isolating them and checking one at a time, this will tell you which one is the culprit. Good luck and happy wrenching!
Sep 07, 2013 | Garden
How to install belt on allis charmers AC 130 riding mower
how to install pulley belts on an ac130 46" cut
Jun 18, 2012 | Garden
When a tire change is done is there a reason the low air warning light goes on?
ok first question did you put the exact same tire size that was on the car factory. If you change the tire size then the pressure for the tire goes up or down to meet that tire spec. your car just reads what the settings are for the stock tires so a change in size will make the sensor think the tire is low. If you put the same size tire back on then the system may jusy need reset.
Dec 17, 2010 | 1998 Toyota Sienna
Change spare tire removing spare tire
Put the car on a level ground, with the transmission in PARK. Lossen the nuts of the tire to change. Chuck back-tires if changing front, or chuck front-tires if changing back-tires. Jack up the car enough to raise the concerned tire off the ground. Remove nuts, and pull out the tire. Put in spare tire.
Hand tighten the nuts a considerable, but you might use the wrench to tighten a bit because this is a big/heavy car. Lower the car, and again tighten the nuts securely in a diagonal pattern with the wrench- two grunts used to be the rule of the thumb.
Oct 27, 2009 | 2001 Lexus LX 470
What kind of tires does my car use?? I have a scion tc 2005.. and im about to change its 4 tires for the first time.. but i was wondering if they have to be the exact same size.. any ideas?
Your tire size is marked on the sidewall of your tire, it will read something like this, P205/70R15. There may be other numbers or letters but these are the critical ones that the tire shop needs to fit new tires on your car.
You car is set up to run on a specific size tire but changes can be made, for any number of reasons, without too many problems as long as you know what to expect. Changing the P205 number will change tour speedometer about 2 mph per size. Going from P205 to P195 will slow the car down and going up to P215 will speed it up the same. The speedometer will read the same but the car will be moving at the new rate of speed.
Changing the middle number, 70 will make your tire wider or narrower and the numbers work backwards. A 60 tire is wider than a 70 tire. This can affect your gas mileage but one number won't be especially noticeable. If you are buying snow tires for winter then 75 is the best number for that. The tire is thin and cuts through snow to make contact with the road.
Changing the last number 15 requires you to change the rims. That number is the diameter of the rim and there really isn't much reason to change them unless you are customizing your car.
Price comes into play more than brand name. You don't need that $250 super sticky tire for normal every day driving which you can do just as well on a plain jane $125 tire.The sticky tires use softer rubber and wear out quicker.
Finally, do not believe anyone who tells you that all season tires are suitable for snow and ice. They work better than summer tires if you get caught in a freak storm, but they aren't suitable for everyday winter driving. If you live in an area where there is a considerable amount of ice on the roads throughout the winter you should seriously consider getting you tires studded for improved stability, handling and stopping. Hope this helps.
Oct 20, 2009 | 2005 Scion tC
Steering Vibration 2005 Colorlla
your car needs to be aligned and balanced...
Jul 15, 2008 | 2005 Toyota Corolla
Allis Chalmers AC130 46" 23HP All Wheel Steer Lawn Tractor Logo
21 people viewed this question
Top Allis Chalmers Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you an Allis Chalmers Garden Expert? Answer questions, earn points and help others
