Question about Samsung NX1000
Nx1000 wouldn't turn on. The green light is still on
My Samsung nx1000 used to have burst and continues setting on the drive as well as single and timer now only single and timer show up I don't know why
Check the mode wheel in your upper right.. check manual ,if all of the modes has all of the options.. I think the mode setting is the solve to your problem.. if that is a software problem, then you can just try to reset by removing the battery and restarting it .. or if the problem persists ,then go to the nearest service center to help you out.
May 19, 2015 | Samsung NX1000
Samsung nx1000 not uploading photos to facebook
Buy another camera...Samsung is no good
Apr 16, 2013 | Samsung NX1000
2008 Honda civicv ex won't start green key light
I think you may have a immobilisor problem try the spare key first
Jan 24, 2013 | Cars & Trucks
I have a problem .. I have a mrv t757 amp and it isnt bumping like I used too .. If i keep the volume low all 3 lights are green but once I turn it up it blinks red n yellow n green back andn for in the...
check all your connections to make sure you don't have a short, but most likely it's your amp. If it was the battery it would turn on and off, including radio, then your car wouldn't start(dead battery), but if it does this and your car turns on no problem then it sounds like the amp gave out.
Aug 23, 2011 | Car Audio & Video
The red\white\green lights just not turning off and its making battry empty fast ....how can i disable these lights :)
It wouldn't be the lights that are running down the battery. If your battery doesn't seem to hold a charge for any length of time, it's time for a replacement battery. You can purchase a new battery for around $40 on eBay.
Thank you, -Larson Custom PC Team
Apr 30, 2011 | Computers & Internet
It wouldn?t turn on...it would initially show the computer?s contents, then after half a second, it would simply go black...operation light is turned on (green) as if everything works!
Does your computer has multiple monitor support? Please check the slots. If there are 2 monitor attachment slot on your computer try connecting monitor to other slot.
Hope this helps.
Aug 17, 2010 | LG L1915S 19" LCD Monitor
Won't turn on - green light flashing
When this set is first plugged in the LED will flash for 70 to 90 seconds and then stop. During this time the unit will not operate. This is the amount of time it takes for the Digital Module to boot up. If the blinking LED never stops the Digital module is not booting up and must be repaired. I have done quite a few of these repairs and the average repair cost has been between $250 and $300.
May 09, 2009 | Mitsubishi WS-65611 65" Rear Projection...
Samsung NX1000 Logo
141 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
