Question about Lenovo ThinkPad 65W Ultraportable charger 92P1213 (20V 325A) Port Replicator AC Adapter
Does anyone know the size screw that attached the bottom right had outer cover of the Lenovo G595 laptop computer? The other screws on the bottom seem too small.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 19 Answers
Its a very long screw.G480/G485/G580/G585: M2.5×6.0 mm,
flat-head, nylok-coated (11)
G780: M2.5×8.0 mm, flat-head,
nylok-coated (16)
Posted on Nov 18, 2014
How do i clean the fan on my lenovo thinkpad?
I would take the screws off of the bottom first. Be careful not to miss any screws, as there may be some under the padding. Remove the bottom cover, and boom. There's the fan waiting to be cleaned. I suggest using a bottle of compressed air.
May 18, 2014 | IBM Lenovo ThinkPad T61 Notebook
Missing bottom case screws-need size
Sometimes there is a screw code next to the screw. Look at this code and then find a screw code with the same code, then remove this matching screw and yiu will be able to identify the screw you need.
Oct 17, 2012 | Dell Vostro 3500 Notebook PC Core i3...
How to change a cmos battery in a transport gx2 notebook?
You'll have to take the laptop apart to get to the cmos battery in most cases. It will be a silver battery about the size of a nickel on the motherboard. The most common size is CR2032. Also sometimes the battery will be in a vinyl covering and have a cable that attaches to a port on the motherboard. Which ever type you have you'll need to either remove the battery or unplug the cable and let the laptop sit for an hour or two. Then put it back, reassemble the laptop and reboot the laptop. With the CMOS battery out the computer will lose the date, time and password on some older models.
Ok, on a laptop you need to get some cups and label them to put the screws in so you will know where they came from. Remove the Power Cord, Remove the Battery then start removing all the screws from the bottom of the laptop. Then remove all the devices from the bottom of the laptop such as the hard drive, the memory, dvd/cd drive, wireless card, etc. Take note of how the wires are on the wireless card, those are the antennas.
Look inside the battery case, hard drive case, memory case and dvd drive slot for screw. Some screws on the bottom case in inside of some of the device cases might have the icon of a keyboard next to it. Those screws hold the keyboard in place.
Turn the laptop over, remove the strip that is just above the keyboard but be careful because a cable might be attached to it. Then remove the screws that hold the keyboard in place that are under where the strip was and gently lift the keyboard out because there is definitely a cable under it.
Next you can remove the screws from the lcd hinges at the corners and lift the lcd screen off, also note that you will have to pull the antennas cable and the lcd cable when you remove the lcd.
Next start removing any screws that hold the palmrest in place. Take note of any cables that are attached to the palmrest and remove them then lift the palmrest off.
Next start removing any screws you see that hold the motherboard to the bottom case, then lift the motherboard out an start replacing the fan.
A digital camera to take pictures will be most helpful to refresh you memory of where things were.
Jun 06, 2012 | MPC Computers TransPort GX2 Notebook
How to remove the screen from the y510
The thin plastic 'frame' in the front of the LCD screen, is the Display Bezel.
Goes by many names. Display Bezel is used by HP.
Display Mask, LCD Bezel, LCD Panel Bezel, and LCD Front Bezel, are a few other examples.
Lenovo/IBM uses LCD Front Bezel.
Lenovo doesn't show an HMM for the IdeaPad's, other than for the S9e series, and S10e series, (Notebook), plus the A1-07 series. (Tablet)
(Hardware Maintenance Manual)
http://support.lenovo.com/en_US/SupportSearchResults.page?searchText=ideapad+hmm
(An HMM is a Service Manual)
I also see there are no guides posted by users.
Therefore we'll have to 'wing it', using my years of experience with repairing laptops, and you as the tech.
1) Do you see any screw covers on the LCD Front Bezel?
May not be the usual synthetic rubber covers. May be plastic, and the same plastic, and color as the LCD Front Bezel.
Example,
http://www.insidemylaptop.com/replace-broken-lcd-screen-lenovo-x60s-laptop/
Scroll down to the photos in Steps 1 and 2.
Also note the 'seals' on the side of the Display Assembly, shown in Step 2 photo.
We'll start with this.
2) Haven't worked on a Y510, and perusing the internet; it seems no one has found a solution, for removing the LCD Front Bezel off of an IdeaPad Y510.
{ ALL power removed before beginning. Remove the AC adapter
(Charger), and Battery }
3)
A) There is no sticky double-sided tape holding it on.
B) Can't simply 'pop' it off, as with other Display Bezels, that do not use Philips head screws to hold it on.
[ For all Display Bezels, (Other than this baby, perhaps), there are locking tabs on the outside edges of the Display Bezel.
These match up to snap locks, on the inside edge of the Display Cover. (Top cover of laptop)
When the Display Bezel is removed, the locks snap loose ]
C) I suggest remove the screws which hold the Display Assembly to the laptop, and see if at the bottom of the Display Assembly, there are screw covers, or just screws, to remove.
If there are, and no other screw covers/screws to remove, the LCD Front Bezel should pop off.
This is what I mean by pop off,
http://www.insidemylaptop.com/replace-screen-on-lenovo-g560-laptop/
Step 2 and 3.
{ The laptop is made by Wistron. (Philippines) One of the three major laptop manufacturers, that makes laptops for ALL laptop brand manufacturers.
Such as Acer, Compaq, HP, Lenovo, Toshiba, Asus, you name it }
Post back in a Comment.
Regards,
joecoolvette
May 06, 2012 | Lenovo IdeaPad Y510 Notebook
I have 32 in Vizio and am using a full motion wall mount. It is attached to the smaller inner mount. I would like to attach it to the larger outer mount but dont know the screw size. It is larger than...
To know the exact size of the screw, you have to get the circumference of the hole where you will insert the screw. If possible to bring with you the outer mounting in buying the screw to have a perfect fitting.
Nov 30, 2010 | Vizio L32 32 in. LCD HDTV
Where is the cmos battery located in the computer??????????
#1
Turn off the laptop and remove the AC adapter. Remove the battery from its compartment on the bottom of the computer. Turn the laptop over and remove the screws holding the DVD drive in place and pull out the DVD drive.
#2
Remove the remaining screws on the bottom of the computer. These screws secure the wireless card cover, the memory card cover and the modem card cover. Then remove all of the plastic covers. Remove the wireless card by sliding it gently out.
#3
Remove the corner screws on the bottom of the laptop securing the bottom housing. Remove the housing by pulling it away from the laptop. Remove any remaining, exposed screws on the bottom of the computer.
#4
Turn the laptop over and remove the thin plastic strip that runs along the border of the keyboard with your fingernails. If your fingernails aren't long enough, a plastic card will work as well.
#5
Remove the two screws on either side of the keyboard securing it to the computer. Remove the keyboard.
#6
Remove all of the exposed screws where the keyboard used to sit. These screws secure the top housing to the computer. Remove the housing, exposing the motherboard.
#7
Locate the CMOS battery. It is a small battery about the size and shape of a coin and should be easily visible on the board. Depending on the model of Toshiba you are working on, the CMOS battery will either be secured with a clip or connected to the board by two small cables. Either way, they are easily removable.
#8
Disconnect the battery by pulling gently away from the cables or by popping the clip out. Your CMOS battery can now be removed
Oct 06, 2010 | Toshiba Satellite X205-SLI1 Notebook
How to disassemble a lenovo 3000 y500
1st pray to god...
open all the screw..on the back side ...
open all cover on the back side
open the keyboard cover its on the upper side of the keyboard
open the keyboard screw
release all the wire from the main board open the upper case
open the screw again...
open the mainbord ...
Sep 24, 2009 | Lenovo 3000 Y410 Notebook
Lenovo 300 n200
Most Thinkpads have screws that fix the keyboard to the laptop. the screws are located on the bottom of the laptop and may have a a small keyboard symbol next to these screws.
After you remove the screws you can lift the keyboard off, there will be two ribbon cables which connect to the motherboard, you need to slide the plastic catches back before you can remove the ribbon cables.
Jan 28, 2009 | Lenovo 3000 N200 Notebook
Where is the cpu located in the Lenovo Ideapad Y510
hi,
I Lenovo Notebooks cpu is located at the extreme left upper corner and when you will open then the heatsink will be visible on it.
after opening the screw of the heatsink simply turn the non removable screw and then lift the cpu.
Dec 26, 2008 | Lenovo IdeaPad Y510 Notebook
Help with opening them
A215 has a detachable front (grey) cover. It is attached on 4 coaks (pins). Just push a flat screwdriver under it and turn slightly - the cover will go out a little. Do it around the cover - and it will be detached. You will see 6 screws (or 4 in the left speaker). You need to unscrew them all.
Jul 23, 2008 | Dell A215 Computer Speakers
Lenovo ThinkPad 65W Ultraportable charger 92P1213 (20V 325A) Port Replicator AC Adapter Logo
132 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
