Question about Cycling
Five gears on rear tire do not shift properly
    Scholar:
  • 119 Answers
If your bike is old, you need to make sure the gears or chain aren't worn out. Secondly you need to make sure that the rear gear shifter is well greased or oiled. It usually gets clogged with dust that prevents its from moving freely. If you have a grease thinner or if you have the time completely remove it, wash it soap, let it dry, oil it and put it back.
Another common gear problem is how well the rear arm is synchronized with the gear shifter on the handle bars. if you have gears 1.2.3.4.5.6 and the rear isnt properly placed you might have situations where the arm rests right in between 1 and 2 and causes the chain to make a funny noise. since the gear shifter has numbers, check to see if the gear the chain is on corresponds with the number the shifter is showing. So the largest gear [ the one closest to the spokes] is 1 and so on
So, [1] check to see if your parts aren't worn out, [2] check to see if they are properly oiled [3] check to see if the gears are properly set
Posted on Jun 18, 2009
How can I reinstall gears after changing rear tire?
I assume you mean to reinstall the rear wheel with the cluster, as there is no need to remove any gears for a tire change. Try the written instructions and pictures at Bicycle Repair Remove Install Rear Bicycle Bike Wheels by Jim Langley and/or one of the videos below. Be sure to first move the right shift lever to the high gear position (should be little or no tension on the shift cable and the derailleur should move all the way outward from center.
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
Feb 16, 2016 | Cycling
Chain intermittently slips in all gears. Is there an adjustment
Mark:
First of all, make sure that you are not over or under shifting. The chain has to be positioned exactly over the gear that you are trying to use. If you hear derailleur or chain noise The derailleur is not "in gear" and you have to adjust your shifter to eliminate noise. The derailleur must be adjusted so that the chain is parallel to the gear cluster in each gear. If the chain is twisted at all, it will skip gears. Check your rear derailleur to ensure it is pointing the chain directly at the front gear cluster. Check the front derailleur to see that it is pointing the chain directly at the rear derailleur. While you are at it... clean the derailleurs with alcohol and lube them with a light weight oil. Check the derailleur stops (small screws next to the cable clamp on the derailleur). Have the bikes rear tire off of the ground and pedal the bike with one hand while shifting with the other hand and you can see what the derailleur is doing. adjust the stops so that you can not shift the chain off of the gear cluster in high or low gear. You may have to adjust the cable length at the derailleur cable clamp, and at the adjusters on the shifter to get the exact adjustment that you want. It will take some time to properly adjust your derailleurs, but it is worth it when you can ride without your derailleurs acting up.
Jun 15, 2015 | Cycling
My 2002 ford explorer jerks when i get up to about fifty mph and let off the gas. I put all new bearings in the rear end thinking the rear end was the problem but it still does it.I put it in four high and...
There is a problem in the shifting of the gear box. Probably a faulty in the over drive servo that is not shifting until the throttle position has changed.. Run fault codes and look for servo/sensor faults and next have an oil change done on the gear box. The rear end has nothing to do with gear shifting so you replaced the rear end bearings for no advantage.
Oct 23, 2013 | 2002 Ford Explorer
Putting the rear tire back on my bike now the rear gears are not shifitng
check the wire is not pinched somewhere, if in doubt take the tyre back off and reassemble making sure the cogs go between the 2 sides of the chain
Dan :)
Sep 02, 2012 | Schwinn Moab LX
2004 grand cherkee doesn't shift and then shifts hard. Only happens when turning left. Sometimes rear tire on drivers side squeels when goes into gear. Thanks
You have binding in your drivetrain, Make sure all your tyres are the same size and not work unevenly, You can get friction modifiers that help smoother shifting, also you may want to check your diff oil levels.
Mar 10, 2012 | 2004 Jeep Grand Cherokee
My duramax grinds into gear when shifting to four high on the fly
have you replaced any tires lately if tire size is off a little this will happen i dont mean two different sizes if you have new tires on front and worn tires on rear or vise versa on large tires it dont much to change diff ratio so front and rear wont match
Nov 03, 2010 | Chevrolet 2500 Cars & Trucks
Not engaging in any gears
It sounds like you need a new cassette on the rear wheel. Take the rear wheel to a bicycle shop as they will have the tools to remove the old one and install the proper new one.
Aug 01, 2009 | Cycling
Do I need to replace all tires on peg perego john deere
Hi!
On these, only the 2 rear wheels are the gear wheels. You will just need to replace the tires on those with the rubber ones if you choose to go that way.  Good luck!
Jan 13, 2009 | Peg Perego John Deere Gator HPX Ride on...
Cycling Logo
94 people viewed this question
Top Cycling Experts
Marvin
Marvin
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
