Question about BenQ MS612ST 3D Projector
Benq lamp red light - BenQ MS612ST 3D Projector
Benq pe8720 service manual
8720 Went out just prior to playing. Now will start up, go to benq logo then lamp goes off. on top of projector lamp light is red. repeat lamp does go on seems as bright as ever but shortly after benq logo goes off. By my recollection lamp is not beyond it's 2000 hour range.
Feb 18, 2012 | BenQ PE8720 DLP Projector
Benq w1000 project not turning on
Look at the manual page 34, for the indicator messages. I suspect it's the same problem I have (which I haven't had formally diagnosed yet!), which I believe is a defective fan. My projector had been making a really loud noise on startup, which varied in length and volume. Recently the projector has taken to turning itself off after being on for about a minute, and the power light flashes green, with the temp and lamp lights flashing red.
Jan 27, 2012 | BenQ W10000 Projector
Projector's lamp won't light up.
Change thermostat and service it.Then solve your problem.
Dec 12, 2009 | BenQ PB8220 Multimedia Projector
My BenQ PE7700 stops working after a couple seconds.
the lamp is running too warm from inability to cool down. clean out the dust with canned air and check the fans. the temp sensor may need to be replaced, as the heat may have desroyed it.
Oct 14, 2009 | BenQ PE7700 Multimedia Projector
Benq pb8250 , red light blinking
you have a problem with either the fans, the ballast, or the colorwheel. if the fans turn on, listen for a high-pitched whir. if you don't hear it, replace the colorwheel. if you do, replace the ballast. if the fans don't spin, replace them.
Sep 22, 2009 | BenQ PB8250 Multimedia Projector
Projector shuts down after turned on and both red lights blink
this model is prone to over heat. look near the lamp for the temp sensor it is most likely bad
Nov 30, 2008 | BenQ PE7700 Multimedia Projector
PB6110 Powers down after 30s, splash screen appears, red temp lig
Be sure to check the filters and make sure you have good airflow thru the proj. Cleaning filters solved our temp shutdown problem.
Nov 17, 2008 | BenQ PB6110 Multimedia Projector
Benq PB6200 projector lamp or other problem
Hi there
I replaced a Mainboard on a BenQ PB6210 just yesterday - had all the same symtoms.
No LED lights coming on but the rest of the buttons has light.
Tried every other component from the lamp to the colourwheel , but the Mainboard replacement fixed it in the end.
You'll be looking at about $95 for the part
Apr 07, 2008 | BenQ (200NSH-LAMP) Projector Lamp for...
LCD shutting off automatically
The problem comes in the Lamp unit generally. check the condition of Lamp.
Viren
Oct 01, 2007 | BenQ PB6100 Multimedia Projector
BenQ MS612ST 3D Projector Logo
24 people viewed this question
Top BenQ Office Equipment & Supplies Experts
Tom Chichester
Electro Med Services...
Tony
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
