Question about DeVilbiss Garden
No pressure coming out of hose - DeVilbiss Garden
Will start and run fine water comes out but has no pressure
Maybe bad pump. Remove wand and wand hose, run machine with water in. High pressure water coming out of wand/hose connection, bad wand or hose. No high pressure water, bad pump, replace.
Apr 01, 2016 | Simpson PS2600 PowerShot Commercial-Duty...
I can't get the pressure washer to start up. The water is coming out of the hose, but there is no water pressure
If the washer is the kind that shuts off completely when the pistol grip is released, the problem is likely the little pressure sensor located near the output fitting (the threaded part to which the hose connects). The sensor is a little plunger held down against an opening in the side of the pipe by a spring when there is low or no pressure in the output pipe, as when the trigger is pulled and the pressurized water in the hose is released by pulling the trigger. That completes the electrical circuit and the washer is on and continues pumping water. When the trigger is released, water in the hose and output pipe jams up super high pressure, forcing tjhe little plunger out against the spring, and the electrical circuit is broken. If you take the case apart, you will see wires coming from that area. The fix (if this is the problem) is to free up the little plunger.
Dec 05, 2012 | Coleman Powermate DuraBuilt 1400 PSI...
Washer flashes f 1 on the display window
The F1 error means that water pressure into the washer is out of range...the control on the washer learns the water pressure coming in from when it was brand new it is capable of learning just the water pressure to your house since it will vary from your neighbors...after it has learned what the normal pressure is if it doesnt see that normal pressure coming into the washer it will throw up the F1 error code
What to check is if water is coming into the washer from the rubber fill hoses with as much pressure as always did...things that could cause lesser pressure is; kinked/crushed fill hose,sediment built up in the filter screens inside of the water inlet valve( can be checked by turning off water and removing hoses and pop screen out from the back of washer where the hoses connect to)
If the filter screens are clear and water seems to coming from the hoses with good pressure...the washer control board would need to be replaced
GENE
Sep 06, 2011 | Kenmore Oasis HE 27082 Top Load Washer
WTW6600SW1 whirlpool cabrio washer keeps giving an F1 error, why??
GENE
Sep 06, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Hose on cjc-1001 pressure washer is leaking. Need to buy new one but cant find a distributor
http://www.watercannon.com/c-11-hoses-pressure-washer.aspx here a link to a site that sells high-pressure hoses. almost all hoses are similar when it comes to pressure washers, just by the right attachments and you'll be good to go.
Apr 05, 2011 | Garden
Water goes thru. have hydrulic oil to level. gun semas to stick on. NOT GETTING ANY PRESSURE AT NOSSEL.
Hydraulic oil?
Is this a pressure washer?
Pump should be half full of SAE20 or SAE30 non-detergent motor oil.
Engine should have 10W30 motor oil.
If you have a pressure washer ... and not water is coming out end of gun:
Take all hoses off machine.
Look at incoming water hose connection.
The should be a filter washer.
Clean or replace filter washer.
Hook up water and turn on water.
Water should come out other side of pump.
Turn on power washer and see if water coming out of pump is pressurized.
Now hook up pressure hose without gun.
Turn on pressure washer and see if water comes out of hose and is pressurized.
Finally, the gun may be bad.
We used to replace guns when they went bad.
Oct 24, 2010 | Dewalt 3800 PSI Pressure Washer
I have a Husky pressure washer w Honda GCV 160. The watwer won't come out the opening the pressure hose attaches to. The inlet is attached to the garden hose but water does not come out the outlet to the...
Not a solution... seems like it is blocked, mine freeflows at least a little water when you turn on the hose (engin off)... Did it get a big slug of dirt from the hose of fawcett? .... puzzzling....
Mar 07, 2010 | Garden
Engine runs. No water thru hose. Pressure valve(???) underneath has water coming out of it
Sounds like bad seals. But first take the hose off and see if water comes out the outlet without the hose there.
Nov 15, 2009 | Honda Pressure Washer PSI 3000
When garden hose is connected to the pressure washer no water comes out of the wand, engine is off.
Dear radcongirl,
Try removing the high pressure hose from the machine. Then connect the water hose and see if water comes out of the outlet.( you can also try this by putting on the machine for a few seconds). If water comes out of the outlet, then you have a problem in the high pressure hose or the wand and trigger. Check also the lance and nozzel for blockage.
I do not know what kind or model of machine you have, but most machines the water always comes out of the outlet when water is fed to the inlet. In bigger machines this cannot happen because they have a reserve tank.
Regards,
Fulltech.
Jul 16, 2009 | Honda Maxus Pressure Washer MX5222
Garden Logo
Top DeVilbiss Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a DeVilbiss Garden Expert? Answer questions, earn points and help others
