Question about Dewalt DWHTTR350 Heavy-Duty Aluminum Stapler/Brad Nailer
Staples won't fire on the DWHTTR350. How do I get the staples to come out the end?
What.size staples needed for arrow fastener ct50
Product description
Product description
2750-1378 Features: -Revolutionary design with ergonomic handling.-Easy release drop in loading channel for staples.-Battery contains an easy to read LED charge meter.-Built-in safety switch prevents accidental firing.-Adjustable staple drive with depth of drive dial.-Light weight design for prolonged stapling tasks.-Can use T50 type 1/4'' staples (2750-0719), T50 type 5/4'' Monel staples, T50 type 5/16'' staples, T50 type 5/16'' Monel staples, T50 type 3/8'' staples, T50 type 3/8'' Monel staples, T50 type 1/2'' staples, T50 1/2'' Monel staples, T50 type 9/16''.-staples, and T50 type 17/32'' Ceiltile staples. Includes: -Kit includes case, charger, and tool. Specifications: -10.8 volts.
staples needed for arrow fastener ct50 Google Search
Jan 11, 2018 | Arrow Tools & Hardware - Others
When i drive brads into wood there is a scar on the wood from the staple driver part
some of then have a light and heavy setting , not sure about your make tho . when you see that little divot dab it with a little damp cloth . then the wood will swell back out sometimes even covering the brad totally or STEAM IF YOU HAVE A STEAMER
Dec 01, 2015 | Dewalt DWHTTR350 Heavy-Duty Aluminum...
Staples won't advance and come out
There may be a piece of a broken staple jammed in the end or the spring may be weak
Apr 19, 2013 | Swingline 747 Classic Desk Stapler, 20...
The staples won't go fully into the Wood
1. The wood may be too hard for the staples to penetrate
2. The stapler drive spring may have ghotten weak
3. You may not be holding the stapler nose firmly against the wood while stapling
Jan 06, 2013 | Stanley TR250 H Heavy Duty Heavy Duty...
Stanley stapler/nailer gun spits out more than one staple at a time
Sometimes a gun will double fire, quickly fires twice and is caused by worn trigger valve or safety foot. However, two staples driven with one shot indicates that the staples could be the wrong gauge for the gun or the driver is damaged. The driver of a nailer has a taper on one side of the blade to prevent the driver from hitting two staples. The taper will push the remaining staples back into the rails. Make sure that the taper is facing the staples and that the staples are correct for the gun.
Aug 25, 2011 | Stanley Carrying Case Bostitch Brad...
The gun will fire staples, nails do not set.
Shoots staples fine but brads jam or bend. Check that the part called "guide bar", #35 on the parts diagram isn't getting stuck in the channel of part #30.
The guide bar retracts into the channel when driving a staple and springs out of the channel to guide brads.
The guide bar can get stuck in the channel if it's bent or gummed up. (Bent is likely the result of driving a brad into an obstruction.)
The business end should look like this:
Mar 07, 2010 | Stanley Bostitch Sb 2IN1 2 In 1 Narrow...
The staples don't come out. I have taken it apart
Make sure that the driver blade is all the way up to top of travel (push driver up with thin tool). Load staples and check that the first staple moved into position by looking down nose. If the driver is all the way up out of the way of the path of the staples and staples do not move into place check of debris or wrong staples. If first staple is in position fire nailer several times. If only one staples then miss, driver is not returning to top. This is usually caused by poor seal at the bottom of cylinder, cracked lower bumper or piston orings are too tight or too loose. Good luck
Feb 27, 2010 | Stanley Bostitch STB-MIIIFS Flooring...
Can't load staples
Fire the stapler with the load chamber open and down, see if anything falls out. Point it in different positions and fire it, just make sure it cannot fire anything at you.
Apr 18, 2009 | Stanley Tools TRE550 Electric Staple/Brad...
My arrow fastener model t-50m is jammed how do I remove the few
I have a similar issue with my T50m stapler. To remove the staples unscrew the locking nut near where you load the staples and remove the tapppered bolt. The track will lift out and the staples can be easily removed. Why this is happening is unknown to me also. I purchased a new gun.
Feb 14, 2009 | Arrow Fastener 509 9/16" T50 Staples
Dewalt DWHTTR350 Heavy-Duty Aluminum Stapler/Brad Nailer Logo
118 people viewed this question
Top Dewalt Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Dewalt Office Equipment and Supply Expert? Answer questions, earn points and help others
