Question about JVC LX-D700 OEM Projector Lamp
JVC LX-D700 Projector
It doesn't work
Jvc projector blue screen
unplug it let it set hit power button plug back in might work for you
Aug 14, 2016 | JVC -HD DILA FRONT PROJECTOR THX CER -...
Playing blue ray movies on jvc dla sx21 projector
It should work right away. Try again, restart the projector and ps3 make sure everything is connected and the input on the projector is on dvi.
May 17, 2008 | JVC DLA-SX21U Multimedia Projector
Jvc x3 projector orange lamp light flashes wont power up
1,Check the fans ,if the fan is running
2,Inductor (Sensing element),near the Color Wheel. Use a cotton swab moistened with alcohol to wipe the Inductor.
Have a good day!
We supply original projector parts: lamp, bulb, Lcd, Lens, DMD,
motherboard, powersupply ... with high quality and competitive price.
Jerry China
Tel: +86 131788 67858
E-mail: lampdeng@hotmail.com
Skype: lampdeng.com
YM: lampdeng@yahoo.com
http://facebook.com/lampdeng
http://www.lampdeng.com
Nov 02, 2013 | JVC Dla X3 3d Projector
JVC DLA-RS1U Projector turns off
I have a similar problem. JVC Project (DLA-RS1) shuts off after about 30 min to 1 hour of use. Everything turns off - bulb, fan, even the little light on the projector near the buttons. After 10-15 min the red light comes back on and you can start the projector.
I have seen this happen when I had installed a knock-off bulb. I believe the bulb runs a little hotter and the projector over heats. Now I am seeing it happen even with a JVC bulb.
I am in the process of taking the cover off the projector to see if anything is blocking the air flow (like a piece of broken bulb, which did break a while back). If a problem doesn't show up there I am going to check the fan to see if it is turning at full speed (maybe replace with a beefier fan?).
Does anyone have instruction on dis-assembly?
Apr 17, 2012 | JVC DLA-RS1U Projector
MANUAL FOR D700 NIKON
Welcome to FixYa.
Nikon D700 Non-printable User Manual http://www.nikonusa.com/pdf/manuals/noprint/D700_noprinten.pdf
Nikon D700 Printable Manual (may require serial number validation) http://www.nikonusa.com/pdf/manuals/dslr/D700_en.pdf
Thank you for using FixYa.
Have a great day!
Jas247
Sep 29, 2011 | Nikon D700 Digital Camera
I am getting an "Out
The resolution of your computer screen (monitor) is too much for the projector.
Decrease the resolution (say 1024 x 768) and check.
It if alone doesn't help, decrease the refresh rate of the screen.
But most probably reducing the screen resolution will be enough to overcome the problem.
Sep 24, 2011 | JVC DLA-HD2K Multimedia Projector
Transfer from recorder to projector screen
It depends of what uotgoing ports you have on your jvc and what incoming ports there is on the projecor.
For example,If there is an S-video out from your jvc and there is an S-video incoming port on the projector you using an s-video cable.
If there is an hdmi outgoing port on yuor jvc and an hdmi incomming port on the projector you using an hdmi cable.
There are hdmi cable, dvi cable, s-video cabe, component cable and composit cable.
Good luck
Dec 04, 2008 | JVC Everio GZ-MG360 HDD Camcorder
Problem of video camera .
got this one from sillygirl say thank you sillygirl!!!!Theres a ccd problem with several manufacturers and JVC is one of them see if your model is on the chart. Good Luck http://www.jvcservice.com/service/custnoticecamcorder.asp?ReqType=CCD
May 17, 2006 | JVC (BHNEELPLP03) Projector Lamp for...
JVC LX-D700 OEM Projector Lamp Logo
21 people viewed this question
Top JVC Office Equipment & Supplies Experts
MusicMania
Level 1 Expert
Piyal Perera
Piyal Perera
jasbo
jasbo
Are you a JVC Office Equipment and Supply Expert? Answer questions, earn points and help others
