Question about Makita 18V 1/2"CRDLS Drill Kit
Cordless drill stuck on forward - Makita 18V 1/2"CRDLS Drill Kit
4 Suggested Answers
SOURCE: model cd55 Ryobi cordless drill driver
Your drill probably has a bad or stripped drive gear. Does the drill operate in forward w/a battery that is not fully charged but yet good.?
Posted on Sep 13, 2008
pappapumpdaf
  • 635 Answers
SOURCE: i loosend the drill bit on my Makita cordless
That can be cured with WD-40, and 2 pairs of channel lock pliers. Spray the chuck inside with WD-40, then grab the lock collar closest to the drill body itself with the pliers, being careful not to squeeze too hard and damage the plastic, then do the same for the spinner in front of it and rotate it clockwise while holding the lock collar in place.
Posted on Mar 24, 2010
  • 90 Answers
SOURCE: switch for forward and reverse only opperates in
your transmission has gone out
Posted on Aug 30, 2010
Trigger on the drill master cordless drill will not move
You may be between "forward" and "reverse" setting. Try changing that and see if it helps.
Apr 17, 2018 | Drills
How do I "unfreeze my cordless drill?
Check the forward/reverse switch. Sometimes they can be the problem.
Jun 08, 2014 | Dewalt DC727 Cordless DrillDriver (Drill...
Speed control switch
You can find an Authorized Service Center near you on Hitachi's website (www.hitachipowertools.com) to see if they have a switch to sell you. Another optioin is sites like www.ereplacementparts.com where ou can do a search on your model number and find your switch. They do have your switch available (PN 333640) for $38.70 +S/H.
Feb 09, 2013 | Hitachi DV18DL 18V Liion Cordless Combi...
Jaws won't tighten or loosen to hold a bit
Hmmm some times the counterclockwise screw that attaches the chuck to the drill come forward and that is how then it stucks the 3 parts that fix a drill to a chuck. Check if this screw come forward. If yes then destroy it and replace it... We destroy it by using a drill smaller than it (usually it is 5mm so we use 4mm bit and of course a CARBIDE one because even cobalt ones can not drill a hardened bolt)
Mar 26, 2012 | Dewalt 18v Battery Hammer Drill Dcd950...
Have b&d firestorm 14.5 volt cordless, forward and reverse switch broken older model but hate to throw it away. it is stuck in forward andhave two batteries and good charger throw away? or fix ?
Fix! We had the same problem, and when we opened up the case (8 screws and a pin later), we found that a tiny plastic tab had broken off the Forward/Reverse selector, which costs less than a dollar. We ordered it from a local supplier to avoid $10 shipping.
Aug 30, 2011 | Black & Decker & Cordless Drill
The chuck on my Dewalt 18v hammer drill will not stay tight. it loosens whether I am in forward or reverse
the chuck on my dewalt 18 volts hammer drill will not stay tight it loosenss whether i am in forward or reverse
Oct 14, 2010 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Black and Decker Cordless Drill Chuck stuck in full open position
I'd put penetrating oil in it and tap the chuck with a plastic hammer. That should free it up.
Best rgrds, W/D
Aug 18, 2009 | Black & Decker Drills
Cordless Drill, Keyless Chuck stuck in full open position.
if chuck is wide open ,look down inside there should be an allen screw or bolt at the bottom of the chuck it should undo anti clocwise and the chuck comes off
Aug 18, 2009 | Dewalt DW056 18 Volt Cordless Impact...
Model cd55 Ryobi cordless drill driver
Sep 12, 2008 | Makita 6932FDWDE 14.4V Impact Driver
Makita 18V 1/2"CRDLS Drill Kit Logo
48 people viewed this question
Top Makita Drills Experts
epangan29
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
