Question about GE Dishwashers
Dishwasher will not drain. had to install a pump kit because the macerator blade had stripped off. It rinses good now but still will not drain. The drain solenoid works well
  • 6,784 Answers
OK, check the following areas to combat this issue further.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
Posted on Jun 18, 2009
Frigidaire dishwasher motor sqeels when it comes on, lower blade wont spin. nothing clogged, took apart everything down to the impellar. impellar doesnt spin to send water to blade but the back fly wheel...
Sounds like an impeller and seal kit you will need I think you impeller jammed up and the shaft stripped out the impeller or your motor shaft snapped
I’m happy to help further over the phone at https://www.6ya.com/expert/george_106a9535a98aec8a
Nov 19, 2017 | Frigidaire 24 in. FDB435RFR Built-in...
Frigidaire Gallery Series Dishwasher - unit stops near the final rinse cycle without draining - "ER" on front display, all led indicators on front display also lit (e.g. low rinse agent, etc.),...
the problem is within the electronic control. Steam leaks in, due to an improper seal ring. Humidity stay in the compartment and eventually, the contact on the wire ribbon corrodes.
it can also be the new electronic module.
If the electronic module is ok, then the only working solution require that you order and install a "fit kit" from Frigidaire.
Some models even have a recall made form Frigidaire. Better check with them.
Apr 03, 2008 | Dishwashers
MY MACERATOR IS MAKING A LOUD GRINDING NOISE IT IS 4 YEARS OLD
Could be something stuck on the blade or impeller. You will have to open the unit and inspect the blade, impeller and drain pipe for any obstructions.
Aug 31, 2010 | Saniflo & Saniplus& Macerator Pump
Main wash pump is working but wont pump out
I guess you have checked the drain pipe outlet etc. if all is clear then the common fault on this wash pump is that the plastic blades on the pump Impeller have broken up.This is a 2 way pump one direction for pumping water to the spray arms and the opposite direction for the drain cycle.The pump will need replacing or you can buy a kit to replace the Impeller blades.To remove pump empty water out of dishwasher and take off plastic panel at rear of unit.Then remove metal plate across back of pump then extract pump and you will see how bad the blades are.
Hope this helps.
May 22, 2010 | Electrolux 23 in. ESI602 Free-standing...
Kenmore Model 587.15103800 dishwasher won't drain
dip water out take pump apart remove debris look for broken blades if so install pump kit thumbs up
Aug 11, 2009 | Kenmore 16602 / 16604 / 16609 Built-in...
Maytag dishwasher not draining fully
Try cleaning out the air gap.  The air gap is not part of the machine, and is located on your sink. If this becomes clogged, it may cause the machine to not drain properly.  Also, I know you said you checked the drain hose and cleaned as far as the filter and chopper blade, but have you checked the lower filter?  There is a filter located underneath the machine that should periodically be cleaned.  To check this, you need to access the machine from underneath by removing the bottom vanity cover. Hope that one of these helps!
Aug 01, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
LG LDF8812ST WONT DRAIN JUST INTERMITTENT BUZZ NOISE
Hi, there may be an obstruction in the pump housing that is causing the motor to freeze or, the impeller may be stripped and , jamming the pump. this will cause the hum you are hearing. the best way to inspect is to , extract the drain pump by, removing
the bottom drain filter housing or sump. manually
move the pump impeller to self it is moving freely. if the impeller is stripped, it will not be able to produce the draining surge necessary to pull the water out.
If the impeller is fine and, there are no obstructions visible, this will confirm pump failure.. replace the pump in this case
Jun 19, 2009 | LG LDF8812 Stainless Steel Built-in...
FDW40
This is a blocked pump,Strip down pump and remove blockage.
Jul 24, 2008 | Hotpoint 24 in. FDW60 Free-standing...
My dishwasher will fill with water but the water will not drain out
you need to remove the blades and strip it to the bottom of d/w under blades and check if it is blocked. if ok undo drain pipe and blow to check if blocked. good luckSLAPPER
Jun 26, 2008 | Dishwashers
Dishwasher dosen't drain completely
HI. check the following areas for faults.
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer
Dec 08, 2006 | GE 24 in. GSD2600GBB Built-in Dishwasher
Dishwashers Logo
95 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
