Question about HP Officejet 5510 All-In-One Thermal Printer
Hp 5510 hard reset - HP Officejet 5510 All-In-One Thermal Printer
5510 all in one, my fax has stopped working. I reinstalled the 5510, the wizard set up my fax, it rings, picks up, BUT doesn't do anything else. Try to send and it sounds like it doesn't dial out? It...
First, I would suggest suggest you reset the FAX. If resetting does not solve the problem, you can then read and follow instructions on this link; http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01669298&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=311255
1. Remove all of the paper loaded in the main input tray.
2. Press the power button to turn off the HP fax product.
3. Disconnect the USB cable from the back of the HP fax product.
4. Disconnect the power cord from the back of the HP fax product and from the electrical
outlet, and then wait one minute.
5. Reconnect the power cord to the electrical outlet.
6. Reconnect the power cord to the back of the HP fax product.
7. Press the power button to turn on the HP fax product.
8. Reconnect the USB cable to the back of the HP fax product.
9. Replace the paper in the main input tray.
10. Use the HP Fax Test Service to try to send and receive a fax.
Good luck.
Mar 24, 2011 | HP Officejet 5510 All-In-One Thermal...
HP 5510 says clear paper jam. There is no jam
You could try unplugging the printer from the wall outlet, wait a few seconds then replug. Often times HP printers require a memory reset to clear up problems. There is no need to unplug from the computer, just the outlet.
Jul 17, 2010 | HP Office Equipment & Supplies
Printer # 5510 - How do I open to replace ink cartridge?
If you mean HP OfficeJet 5510 then the following tutorial is for you:
HP OfficeJet 5510 Replace Ink Cartridges
If you do NOT mean HP OfficeJet 5510, please do not fail my solution. Instead, start a new thread with your make, model clearly defined.
Jan 13, 2010 | Office Equipment & Supplies
My HP officejet 5510 is only printing yellow, and it was printing fine yesterday. I put in a new color cartridge, but still it only prints yellow. What else should I do?
first thing you should do is to check the cart again and make sure no packing material shoud nt be ther.. try to clean the cart..perform reset.. if it doesnt work.. replace the cart.. cart are bad.
Oct 19, 2009 | HP Officejet 5510 All-In-One Thermal...
My hp 5510 all-in-one won't scan photos
Unfortunately the 5510 is no longer supported by HP for OS X 10.5.x and up. On the Apple tech site, they actually redirect you to a page the HP upgrade page (read: buy a new one).
If anyone can think of any 3rd part software that works with this, please post!
Thanks!
May 01, 2009 | HP Officejet 5510 All-In-One Thermal...
Hp 5510 io keeps stating to check color cartridge/3 lights blinking/won t print/installed new color'' Let our Experts solve your ''hp 5510 io keeps stating to check color cartridge/3 lights blinking/won t...
hi..
try to install and reinstall the printer cartridge...and also clean the tab circuit of the cartridge and tab circuit of the printer carrier..
if the problem still exist..
rebreak the printer by full-out the power supply...to reset the settings and then turn it back...
Apr 01, 2009 | HP Officejet 5510xi Printer
My printer will no longer scan since I hooked it up to new computer. Help, I have a 5510 All in one HP
I recently found that my 5510 would not scan text into the OCR. I found out that the program the 5510 uses to scan text, HP Director has an issue with Internet Explorer 7.0. If you go to the HP web site and do a search for HP Director, you will be directed to several options for fixing this problem. The option that worked for me was to download their fix.
Mar 28, 2009 | HP 5510 4-in-one Printer
Paper jam hp 5510
Look in the rear of the machine for an access door.
Jan 04, 2009 | HP Officejet 5510 All-In-One Thermal...
Changing cartridges
for the 5510, the manual says to turn the machine on, then lift the catridge cover piece, which is the flap under the hp symbol on the scanner/copy part...it's the flap that hangs down just above where your print copies come out...it takes a little tugging, but it comes up and then you can see your cartidges...after that, push down on the cartridge and pull it out..
Mar 15, 2008 | HP Officejet 5510 All-In-One Thermal...
The ink carthridge location
how do I get to the ink cartridge on a hp 5510 all-in one?
Feb 15, 2008 | HP Officejet 5510 All-In-One Thermal...
HP Officejet 5510 All-In-One Thermal Printer Logo
56 people viewed this question
Seeker5211
Seeker5211
