Question about Sharp R-1480 Microwave Oven
How to set the time on my microwavw Electrolux mef41 ? Thanks
My lg microwavwe wont stop running but doesnt heat.when you press it says door
You may have either a defective door switch, or the latch assembly is not properly activating the switches.
Jan 26, 2017 | Microwave Ovens
HOW TO FIX MICROWAVW TOUCH BUTTONS?
If the touch pad and circuit board are two separate components, I'd check all the connectors, ribbon cables, etc. , between the two. Sometimes removing and re-plugging in a cable will fix the problem.
If it's all one unit, there are companies that fix them. Current price is about $39.
May 10, 2016 | Microwave Ovens
LG microwavw won't turn on
I agree, most likely the fuse.
Apr 20, 2014 | LG LMV2053 Microwave Oven
Emc38905x Does not start. Select microwave, then power then time press start & nothing happens. Need to toggle the power to reset & ok for afew days then fails again
I have an ELECTROLUX MICROWAVE (Model : EK23CBS4) purchased in January-12 from Pune. During usage glass plate got automatically cracked. when i called up service centre they said glass plate is not covered under warranty. When I verified the warranty book there is no as such things are mentioned. Most of the customer having the same problem glass plate getting cracked automatically. So I will suggest do not purchase any of the product Microwave Oven of ELECTROLUX. This is our responsibility avoid any product to purchase of ELECTROLUX.
Thanks, Mritunjay Kumar Cell# - 9922385632
Nov 06, 2011 | Electrolux E30MO65GSS Convection Microwave...
How many watts hot point microwavw m#rvm1435wd001
Your RVM1435 microwave is rated at 950 Watts for cooking. Total watts will be slightly higher as the power used for the display, clock, etc. are not counted for cook power. Here are the rest of the common specifications.
I hope this helps - please rate my reply. Thanks.
May 20, 2011 | Microwave Ovens
What size fuse would i need to replace in a emerson microwavw mw#8992rd
It is critical to use exactly the same fuse type and value that was taken out.
Mar 04, 2011 | Emerson MW8102SS 1100 Watts Microwave Oven
Hi, The microwavw heats up and F3 shows on the LCD and wont work until after a while. Thanks
Make and odel please.
Error code F3 on many models of microwave oven means a problem with the touch panel, (tact switches).
Replace the switch panel to fix the fault.
Hope this helps.
Jan 18, 2011 | Microwave Ovens
The microwavw make a electrical sound now it run but not warm
sounds like you magnatron shorted. you should call for service. find a shop you can bring it to. its alot cheaper then having a tech. come to you.
Feb 26, 2010 | Whirlpool Microwave Ovens
Microwavw will not heat food
replace the magnetron of your unit.
Sep 08, 2009 | Microwave Ovens
Sharp R-1480 Microwave Oven Logo
37 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Ed Mac
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
