My jvc LT-40DG20J wont come on and the spdif optic out is flashing
4 Suggested Answers
Slinteriors
  • 8617 Answers
SOURCE: MY JVC LT-40DG20J DOESN'T COME ON
That could be a main board issue or a power supply issue. I would check the power supply for the stand by voltages and see if any are missing or low
Posted on Nov 05, 2012
  • 22 Answers
SOURCE: JVC LT-40DG20J 42` HD TV wont turn on.
I hope this is the solution to your, particular, problem...
http://www.diyforums.net/my-jvc-lcd-tv-does-not-power-on-when-i-hit-the-power-button-...-720127.html
Posted on Jun 28, 2014
gopakumarg43
  • 75581 Answers
SOURCE: JVC LT-40DG20J 42` HD TV wont turn on. I turned my
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience. Do a search by type in the brand name of the device to the search box.
How do I fix my Jvc the screen won't power on. When I reset it the lights on the buttons light up...but shut off right away. It has power because the red light on the bottom left corner stays lit.
JVC LT-46AM73 LCD TV Won't Turn On - YouTube
? 3:28
https://www.youtube.com/watch?v=y5j3RGUe4gM
Feb 25, 2015 - Uploaded by Awesome Things
JVC LT-46AM73 LCD TV won't turn on after power outage. ...LCD & LED TV Repair - No Image & Blank Black ScreenFlashlight Test - How to ...
JVC wont turn on - JVC - Streaming Video & TVs
www.tomsguide.com/answers/id-1677424/jvc-wont-turn.html
May 15, 2013 - JVC lcd tv will act like its turning on then the green light after 2 seconds ... wont turn on Forum; SolvedAcer Laptop V4DA2, screen won't turn on.
My Jvc Av-32F476 Tv Won't Power On, The Green On Timer Light Stays ...
www.diyforums.net/my-jvc-av-32f476-tv-wont-power-on-the-green-on-...
Dec 8, 2013 - My jvc av-32F476 tv won't power on, the green on timer light stays on and m. ... On the remote control, look for the buttons PICTURE MODE and DISPLAY, with ... My Jvc Lt24dd52j Won't Turn On The Blue Light Is Flashing But ...
Nov 1, 2014
I Have A JVC LT-42TG30J, Randomly The Tv Has Decided It ...
Aug 29, 2012
I Have No Picture On My 47 Inch On My Jvc Big Screen Just A ...
May 23, 2012
My Dynex 42" Wont Turn On Power Led Is Lit Up But It Won't C ...
May 24, 2011
More results from www.diyforums.net
Jan 18, 2016 | JVC Televison & Video
I have a JVC 40 inch LCD lt-40dg20j TV. It was on working fine then just went off. There is no power lights even coming on. What can it be.??
If you have not checked the power outlet yet, start there. Many times a bad plug in or a triped electrical breaker will be all that is wrong. If you are sure that you are getting electrical power to the unit, then most likely you have a faulty power supply board in the unit.
Oct 18, 2014 | Televison & Video
JVC LT-40DG20J 42` HD TV wont turn on. I turned my TV on and no picture just blue flashing light, after hours of turning it on an off it came on, after 5 6 hours it shut off again, now there's NO flashing...
Jun 28, 2014 | Televison & Video
Nov 04, 2012 | JVC LT Televison & Video
Do i have to buy a blu-ray player with a coaxial connection to be compatable with the jvc rx e100 home theater receiver?
No, it has connections for optical and coaxial (*) digital audio.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/JVC-RX-E100SLC-Receivers-manual/id/315ci068/t/2/
>>>> * A word on coaxial vs spdif (optical) audio cabling - I always use coaxial if I have the choice because it is A) cheap RCA cable available anywhere in any reasonable length you want to run; B) can be extended and SHARED with other components if you have limited jacks available. You just have to be careful to make sure only one digital source at a time is turned on while using the other; C) RCA cable is impervious to problems arising from tight bends; optical physically delicate and won
Mar 21, 2011 | JVC RX-E100 5-Channel Amplifier
Trying to connect my computers sound card to amp via spdif to optical in amp not working why?
The JVC audio piece of this is straightforward if your PC's soundcard is configured correctly to output the right digital bitstream. You most likely have some proprietary software managing the Sound Card and its properties. Find it and look around for something that controlls the spdif output. Usually there's a way to change the sampling-rate.
Your receiver will surely accept 44.1 khz, maybe higher for certain sources like mulitchannel DVD video. Experiment with different PC settings and play something to test it. Eventually you'll figure it out.
Of course, optical cables also need to be routed carefully to avoid small-radius bends which will cause data or signal loss.
Feb 03, 2011 | JVC RX-7032V 6.1 Channels Receiver
I have a slightly older samsung surround sound that was working fine till I bought a new tv and the red and white audio cords would not output sound with the new tv. So I bought an optical audio cord which...
* A word on coaxial vs spdif (optical) audio cabling - I always use coaxial if I have the choice because it is A) cheap RCA cable available anywhere in any reasonable length you want to run; B) can be extended and SHARED with other components if you have limited jacks available. You just have to be careful to make sure only one digital source at a time is turned on while using the other; C) RCA cable is impervious to problems arising from tight bends; optical is too delicate and won't work well when bent. <<<<
Make sure your optical cable has no small-radious bends in its routing.
Jan 26, 2011 | Samsung Audio Players & Recorders
I am wanting to start using optical but the channel (01) keeps flashing and theres no sound? Any Ideas?
CD 01 coaxial digital or optical inputs. If the 'o1' is flashing this means there is no signal. This could either be a damaged optical spdif/ coax cable or the sample rate your sending to the sherwood is too high (over 96k ?) lastly it would be a fault with the system itself.
Dec 16, 2010 | Sherwood RD-6106 Receiver
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
