Question about Dell Computers & Internet
Power switch is orange - Dell Computers & Internet
  • Dell Master
  • 998 Answers
A steady or Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Posted on Jan 03, 2015
Rear wipers won't work on 2004 yukon
You need to remove the trim panel inside the back door, Unplug the motor, Be sure you have power on the Orange wire with key on, then test the Grey wire with wiper on, key on and if power? then likely bad motor If NO power on one or both wires at the plug? then fuse for rear wiper or bad switch the orange wire is from the RR WPR fuse in the under hood fuse box.
I doubt the other fuse is bad as if it was, the rear washer would not work So,, be sure power on orange wire, then check power on grey wire with wiper on and key on. No power on grey? bad switch. No power on both orange and grey? likely motor. This is the only way to test the system
Feb 26, 2015 | 2004 GMC Yukon
Will not power up
You may want to make sure that on the back of the computer where the power cord is that the orange switch is not on 220 or something different. Play with it flick the orange switch one direction then try it then switch it back. Also if that does not work, you could either have a bad power supply or the button for the power could be disconnected from the mother board.
Jun 22, 2011 | E-Machines eMachines Desktop PC
My ricoh 2045esp copier won't turn on. The wall outlet is working. Is there a fuse I need to replace, or reset button?
Have you checked the main power switch -- the orange switch on the lower left hand side of the copier? If that switch is off, the power switch on the ops panel won't work.
If that orange switch is on and you still can't get any power, there might be a blown fuse. The power supply board has several fuses on it, and if one of those fuses blows, it could prevent the machine from booting up.
Jan 05, 2011 | Ricoh Aficio 2035 Copier
Won't power up the on off switch is orange and
have you tried holding down the power button till it shuts off ?
Oct 15, 2009 | Acer Aspire One PC Notebook
Power mirrors don't work. Which fuse controls this
Here is repair information from Mitchells:
1) Disconnect power mirror switch connector. Connect test light between power mirror switch harness connector terminal "A" (orange wire) and ground. If test light illuminates, go to the next step. If test light does not illuminate, repair open in orange wire between power mirror switch and righ rear power distribution center fuse block No. 1 (located under left side of rear seat).
2) Connect test light between power mirror switch harness connector terminals "A" (orange wire) and "J" (Black wire). If test light illuminates, check for poor connections at the power mirror switch. If connections are okay, replace power mirror switch. If test light does not illuminate, repair open in Black wire between power mirror switch and ground.
Aug 04, 2009 | 1997 Oldsmobile Aurora
I have a westinghouse three speed fan. there are 4 wires a black, purple orange and yellow . the new switch has four connectors L 1,2,3 does any one know witch goes where? thanks , i bought the new switch...
ok. hope this helps, use a switch from FANTEC. it'll be called a 3 speed fan switch. CAM #5 No. 21105. this will also say Single Layer 3 or 4 wire application SPLIT continuity function.. THE SPLIT PART IS VITAL. now when wire it. the BLACK wire goes in SLOT 3. ORANGE wire goes in L. PURPLE wire goes in slot 2, ORANGE wire goes in slot 1. IF, and i repeat IF this does not work for you ensure you have a SPLIT CONTINUITY FUNCTION switch. NO MATTER WHAT the BLACK wire WILL go into slot 3. the ORANGE wire WILL go in slot L. switch the orange and purple wires only. ENSURE POWER IS OFF WHEN CONNECTING OR DISCONNECTING WIRES. YOU WILL GET THE SNOT ZAPPED OUTTA YOU IF YOU DON'T. please post if this helps.
May 02, 2009 | Westinghouse Electric Westinghouse...
MSI MS6511 jumpers overview?
Dear User here is confiruration.
1.Orange with + sign and orange is for HDD LED.
2. Green with +Sign and Green is for Power LED.
3.Red is for Power switch.
4. Blue of Black is for Reset switch
Mar 29, 2009 | Computers & Internet
Chevrolet Astro -89 electrical diagram
nowhere, you have to buy one for 8.00
Jan 14, 2009 | 1989 Chevrolet Astro Cargo
Signal wiring for 74 sportster
CONNECT IT BETWEEN POWER SUPPLY AND THE SWITCH. POWER IN ONE SIDE POWER OUT THE OTHER
Dec 03, 2008 | 1979 Harley Davidson XLH 1000 Sportster
Coleman a/c
black= power wire - red= power wire+ blue= a/c control orange#1= thermo orange#2= common
Dec 12, 2007 | Coleman 805D712T
Computers & Internet Logo
mukhtar21 shaikh
mukhtar21 shaikh
