Question about Kodak EasyShare C875 Digital Camera
When i turn the camera on....it saids memory card requires formatting. then continues to say formatting will delete everything on memory card. i press continue and nothing happens. goes back to say memory card requires formatting. PLEASE HELP i need my camera for tonite. Thank you Bflo, NY
  • Kodak Master
  • 19,396 Answers
Use a computer with memory card reader, and read the card using a computer.
If the computer says the same and does not read the card, then the pictures inside the card are usually lost.
If computer instead does read the card, then transfer all picture on computer using the memory card reader, and format the card using complete formatting.
If you need to use the camera tonight, then buy a spare memory card.
If the camera returns same error on different card, then you may have a faulty memory card slot, but that is quite uncommon.
Regards
Posted on Jun 18, 2009
Memory card requires formatting, press continue then it states that it will delete everything on memory card,then it does not format, it tells you that you need to format memory card. press cancel and...
Hope you have this figure out if not here goes. Sounds as if the camera is caught in a feed back loop. As long as you have down loaded and saved your images on the computer go ahead and format the card. When it says delete everything on the card select OK and click the start button everyone is happy again. By the way all new card and card after doenloading to the computer should be formatted in the camera. Never format in the computer and deleting images one by one is just a great way to totally mess up a memory card's mind. Format, Format
Dec 09, 2010 | Kodak EasyShare Z7590 Digital Camera
I just received a SanDisk, ElitePro, 32GB memory chip for my Kodak C875 camera. Upon chip insertion LCD says, "disc requires formatting", "continue", "formatting will delete everything on memory card",...
This camera's software will accomidate up to 2 GB SD card, or up to 8 GB SDHC card. Check your camera manufacturer's Help Page to learn the card capacity of your camera
Dec 25, 2009 | Kodak Cameras
How did my pictures get deleted by formatting the card?
when you format something it deletes everything leaving it how it came from the factory, it's possible that you had corrupted files and the camera advised to format, next time cancel
Aug 04, 2009 | Sanyo VPC-E760 Digital Camera
Memory Card
Hi...
The way to format is just follow this, you just plug you camera to the computer then turn it on, after that, the camera will detected, you open my computer, you can see the removable disk, just right click then format then check quick, then ok
Good luck !!!
Regards
PCmania
Jul 06, 2009 | Kodak EasyShare C875 Digital Camera
Camera will not format 4 gig card
I am having the same problem. I phoned a camera store and they said the camera is too to accept a 4GB card may only accept to a 2 Hope this helps
Jun 04, 2009 | Kodak EasyShare Z7590 Digital Camera
New memory card will not format
You are probably using a 4 gigabyte memory card and your camera will only support a 2 gigabyte card. Get the right card and it will format properly.
Larry
Mar 23, 2009 | Kodak EasyShare V550 Digital Camera
My Kodak EasyShare C315 needs formatting.
For all the camera users whose cameras won't format...they can't accept all the info on a 2 gb memory card... install a 1 gb card...worked like a charm for me! C315 and others were made before the 2 gb card. Only 1 gb cards work in the older cameras.
Tami
Dec 27, 2008 | Holga Flash, 120 Medium Format Camera...
Memory card
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • Jul 03, 2008 | Konica Minolta DiMAGE Xg Digital Camera
    Memory card
    this cam will work up to 2gb sd/mmc
    what's the capacity of your card? if it's above that, it's really not gonna work with this cam
    if your card is 2gb or lower
    2 possibilities:
    defective card - please try another card
    camera memory reading problem - arrange repairs with kodak
    Jan 20, 2008 | Kodak EasyShare C663 Digital Camera
    Kodak EasyShare C875 Digital Camera Logo
    694 people viewed this question
    Top Kodak Cameras Experts
    Tony
    Are you a Kodak Camera Expert? Answer questions, earn points and help others
