Question about Kohler K-CB-CLC3026FS Silver Aluminum 30" x 26" Double Door Mirrored
Door sagging on Model # K-CB-CLC3026FS because of hinge failure
Refrigerator door sags and binds opposite hinge side. Can lower hinge be moved to raise sagging side?
Most likely cause is a worn cam in the hinge. After a while plastic cam wear out a causes doors to sag. Take your model number to Searspartsdirect.com and find the hinge cams and replace. Our went out a few years ago and our door did not shut. We came back 4 days later to a real smelly mess all over our kitchen thanks to these plastic cams. To prolong useful lifetime, try coating the cams with protroleum jelly. Doors should shut when you release the door when open 1 inch by themself. If they do not, the refrigerator feet need to adjusted so front is a little higher than back.
Sep 29, 2014 | Refrigerators
Car door is sagging
Take a good look at the door hinges. Often, there will be replaceable bronze bushing inserts in the hinges, and the hinge pins are also prone to wear, especially if the recommended lubrication is not done.
If the bushings and/or pins are not replaceable and the wear is in the hinges, the hinges willl need to be replaced.
Other possible causes are loose hinge mounting fasteners, failure of the door or "A" pillar (for front doors) at the hinge mounting location(s) due to rust or physical damage, and (of course) collision damage to the door or door frame.
Oct 04, 2012 | Toyota Celica Cars & Trucks
Door sags 1996 buick
If you have to lift up on the door and or close it hard--likely a bad hinge --each door has two and you can look into replacing the whole hinge or there are kits with the pin and bushings that can be used to repair a hinge.
Driver door would be most common if car that age and you may just need one of the two hinges replaced/repaired.
Jun 16, 2012 | 1996 Buick Century
Driver side door sags.
If your door sags it means the bushings in the door hinge are worn out, but there is a way to adjust it without replacing the hinges if they aren't too bad. If you open your door there are bolts that attach the door hinges to the A-Pillar, most of the time they are accessable from the outside. First get a car jack and position it under middle edge of the open door, put a small piece of wood on the jacking point to protect the door. Loosen the bolts to the hinges and raise the jack so it raises the door up. tighten the bolts on the hinges back up and open and close the door to determine if the door was raised enough to eliminate the sagging.
Jan 25, 2011 | 2002 Pontiac Sunfire
I have a kenmore he4t washer and the front door
First thing to check is if your door hinge has a sag to it. The next step if there is a sag is try adusting the screws that hold the hinge on the frame of the door sometimes these do come loose. and do require tightening. Folowing confirmation that there is no sag in the hinge your next step would to order a new door latch. If you are not mechanically capable of removing the front section of the machine you should call a technician
Apr 28, 2010 | Kenmore Elite 45986 Front Load Washer
The front door hinges are sagging how do I change them
I believe your hinge pins are worn. The only fix is to replace the hinges or the hinge pins. Neither is a pretty job.
Thanks for your question at FixYa.com
Jan 14, 2010 | 2001 Dodge Ram 2500 Truck
Freezer door on Kenmore AS-18 is sagging
I have this fridge and the sagging door means that you are missing a plastic washer. you might have accidentally placed this washer on the top rather then on the bottom where it belongs.
Jan 04, 2010 | Kenmore 18.3 cu. ft. Top Freezer...
97 dodge dakota driver door sag, repair.
Likely nothing to adjust.
With the door open, see if the door can be lifted up and down while looking at the hinges. If there is play, the door hinge pins/bushings are worn out, and on some vehicles, the hinges are not serviceable, and replacement will be needed. G/L
Oct 02, 2009 | 1997 Dodge Dakota
Oven door hinge failure
U need to replace both door hinges together.
In your browser bar , type in youtube.com
Then in then search box type in fitting oven door hinge
Click on appropiate video and follow instructions.
This should be a big help to you.
Plz rate my solution.
thanks.
Dec 22, 2008 | Ovens
Kohler K-CB-CLC3026FS Silver Aluminum 30" x 26" Double Door Mirrored Logo
460 people viewed this question
Top Kohler Medical Experts
ray gallant
Are you a Kohler Medical Expert? Answer questions, earn points and help others
