Question about Hardware & Accessories
Model PB115m1 won't work
The timer gear does not move
3 Suggested Answers
SOURCE: My Intermatic Timer (model PB115M1) is not keeping
...may have solved this one... opened up an Intermatic Model HB31R and it seems to have the WG2030 timer motor... this model (complete timer box) cost $20 or so...
Posted on Sep 24, 2010
SOURCE: where to but a malibu
I do not have a resource for that timer.
No internet source shows that timer, and I research timers each day.
If I find something, I will update this post.
Work-around:
If power pack timer stopped working, buy cheap plug-in timer and put power pack on override and plug power pack into cheap timer. Power packs come with 5-year limited warranty. Otherwise there are no replacement clock motors for this product.
Intermatic PB series timers show on following 2 links:
http://www.poolandspacontrols.com/products/compact%20timer%20mechanisms/electronic%20timer%20mechanisms.aspx
http://www.poolandspacontrols.com/products/compact%20timer%20mechanisms/mechanical%20timer%20mechanisms.aspx
http://waterheatertimer.org/Woods-timers-and-manuals.html#FM1D
You posted under Malibu, which sells Intermatic ML series power packs.
http://waterheatertimer.org/Intermatic-trippers-and parts.html
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
http://www.intermatic.com/products/professional%20lighting/light%20expressions/power%20packs.aspx
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Apr 06, 2011
My 2003 ford taraus shifter moves through the gears easily but won't go into gear
Check the Ford website for recall information. There are hundreds of identical postings for that year and model. Good Luck!
Feb 11, 2012 | Ford Escape Cars & Trucks
I have a Kenmore washer 110.23832100 and it won't go through cycles anymore. It will start and we can manually change the cycle but it won't move ahead on it's own.
Hi Cat,
This sounds like the timer motor. This is located inside the head of the machine, accessed by the two screws on either corner of the head. Remove the timer knob, then the two screws holding this on, but only after you have the head open. Remove the timer, and you will see on the back a small teardrop shaped motor. It has two small wires on it, that give it power. Remove the two small screws from that, bring it to your parts dealer to obtain a new one. Reinstall in reverse procedure. Check with power while the head is open to determine that the motor is moving, you will see inside a small mark on the gear as it turns. Rescrew the head to the cabinet and you should be ok
Any further questions, don't hesitate to ask, rate and comment Thank You Joe
Sep 17, 2011 | Washing Machines
We have an outside landscape light time that has quit working. Model pb115m1. Do you carry these?
Fixya does not sell timers or parts.
Timer system is not identified for certain.
If landscape system still turns on-off with override switch, then you can work around and buy cheap plug-in timer, set landscape to override, and plug landscape system into cheap timer.
Open following link for low voltage transformer resources:
Add a comment for more help.
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
Aug 28, 2011 | Hardware & Accessories
Where to but a malibu timer model number is PB115M1
Work-around:
Apr 06, 2011 | Intermatic & Indoor/Outdoor Rain Tight...
Think I need a washer timer switch. Washer works when we move timer manually so I think it neews a new timer. Can you help me? Derek
Hi, You are correct in saying you need a new timer. When you have to move it by hand, the drive motor inside the timer has either quit or gears are stripped out. You will need your complete model number and then contact your nearest washer repair center to purchase the new timer. Hope this helps,
Jan 19, 2011 | Washing Machines
My Intermatic Timer (model PB115M1) is not keeping time. Without any electrical load it is loosing 3 hours every 24 hours. Its part of an older Intermatic Malibu yard light transformer. Is it fixable or...
Jun 19, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
Need to know watt output for PB115M1.
The timer has an amp rating for the contacts that switch the load you want to control. It will give you the contact rating on the door. For Wattage conversion, multiply the amps x volts= watts
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jun 27, 2009 | Intermatic & Indoor/Outdoor Rain Tight...
My viking refrigerator freezer won t freeze
A lot of problems have been reported with this model,with the defrost timer not moving,Like a clock stopping,the defrost timer has stopped,and won`t allow the compressor to freeze the freezer unit.Most likely not to cool in the refrigerator either is it?If I can help anymore,let me know,but have the defrost timer checked or replaced.
Jun 12, 2009 | Viking 42 in Built In Professional...
Hardware & Accessories Logo
56 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
