Question about Viking DIPR160R Stainless Steel Kitchen Hood
Hi, we just moved into a house we bought a year ago. we have a viking vipr 36" ventilator downdraft, but i think the filter(s) is/are missing... the red filter light comes on in an hour and i went online and saw we are supposed to clean the filters, but it doesn't appear we have any.. do you know where we can replace them? thanks so much, terry..
    Sergeant:
  • 326 Answers
Docs.hdpi.com/PE-Links/vikingredo/vi-viprinstallation.pdf
Posted on Jun 18, 2009
KitchenAid Retractable Exhaust Fan problem when rising. When button is pushed, unit rises up about an inch. Requires 10 or more presses to extend fully. Otherwise fan and retraction is normal.
Kitchen Ventilation ' Kitchen Hoods and Fans ' KitchenAid
www.kitchenaid.com/major-appliances/hoods-and-vents/
KitchenAidShop and find how our hoods and ventilation systems clear the air in your ...Retractable Downdraft Design ... Telescopic Downdraft System in Stainless Steel.
30" Retractable Downdraft System, 600 CFM (KXD4630YSS ...
www.kitchenaid.com/shop/-[KXD4630YSS].../KXD4630YSS...
KitchenAidLearn about features and specifications for the KitchenAid 30" Retractable ... This 30-inch retractable downdraft vent rises 14 inches to help filter steam from ... 14" Rise. Enhances overall capture above the cooktop for more effective ... Makes it easy to select and adjust fan speed depending on your ventilation requirements.
KitchenAid® 36" Retractable Downdraft System, 600-1200 ...
Jan 10, 2016 | KitchenAid Dishwashers
Power at the plug, no response from "on/off" button.
Follow the power line with a tester, see where it is interrupted
Sep 16, 2015 | Viking VIPR162 36" Downdraft Ventilation...
Downdraft ventilator has stopped working
We have a Viking VIPR101 30" downdraft ventilator. We've learned that the ON-OFF switch on the side of the ventilator can overheat and burn out when it is held down continuously (poor design). Best to push and quickly release it. First time we had the switch professionally replaced--it's modular and very simple to swap out. Next time we fixed it ourselves with switch part # PV300182 from allvikingparts.com. They had replacement guidance on-line. Hope this is useful.
Mar 17, 2015 | Viking VGRT360-6B 36 in. Gas Cooktop
I have a wolf dd36i downdraft cook top ventilator just stopped working it has power and the switch is conected to the remot e
WOLF DD36I USER MANUAL Pdf Download. - ManualsLib
www.manualslib.com > Brands > Wolf Manuals > Cooktop > DD36I
View and Download Wolf DD36I user manual online. ... cooktop. Wolf downdraft ventilation systems are recommended. for use with Wolf electric ... The downdraft will operate most efficiently when ductwork does not exceed 40' (12 m) in length.
Feb 16, 2012 | Viking VIPR101 Kitchen Hood
I have a viking vipr161ss ventilation system. When I push the button on top of the ventilator nothing happens. When I manually activate the microswitch located in the electrical box under the cabinet the...
Hi- It sounds like you diagnosed the problem correctly. There is a chance there is something wrong with the board but I would replace the top switch first. They are pretty expensive if I remember correctly and be careful of the wiring colors, the last one I changed had the wire colors reversed but the wire labels were correct. Good luck.
Sep 24, 2010 | Viking VIPR Series Versavent Kitchen Hood
JVB37H1BB downdraft ventilation system stuck
Folks, I have experienced the same problem several times - in all of my cases the problem was solved by simply opening the back panel and taking out the motor assembly and re-aligning it. Check out this URL for a blow up of what's inside and parts list - http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5130126
The problem is that the arm tends to slip out and therefore won't raise or lower the hood anymore. Be careful when aligning it can be a little tricky - carefully observe the how the motor works outside of the housing via the switch and you will get the idea.
Jul 26, 2010 | GE Profile JVB67HWW 36" Telescopic...
30" viking downdraft goes up & down fan runs and will not responed when pushing on touch panel
After 11 years of use, the same problem just happen a few days ago - fan keeps running, doesn't respond to the on/off switch. Also cannot reset filter alert. As far as I can tell the entire switch panel isn't working. Or worse, shorted out. Might have to replace the ribbon and some switches.
For example the switches can be found at AllVikingParts.com For example --> http://www.allvikingparts.com/Button_Switch_Assy_p/pv300182.htm
There's a another thread on this forum: http://www.fixya.com/support/t410261-viking_downdraft_ventilator_electrical
I'll post the exact solution as soon as I have it figured out completely.
Mar 11, 2010 | Viking VIPR101 Kitchen Hood
Viking downdraft ventilator electrical problem.
You seem to have a slightly different model, but see a solution at:
it is probably the same thing
May 28, 2009 | Viking VIPR101 Kitchen Hood
30 INCH TELESCOPING DOWNDRAFT VENTILATION UNIT
I just found the part that I think you need. It's part no. WB7X7220
It's available through the GE parts and accessories store.
Sep 04, 2008 | GE Profile JVB67HWW 36" Telescopic...
Viking DIPR160R Stainless Steel Kitchen Hood Logo
517 people viewed this question
Top Viking Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Paul Carew
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
