Question about Visioneer OneTouch 8920 Flatbed Scanner
My Visioneer One Touch 8920 will not scan slides
I use it often for reflective sanning and have been doing so for years. For the first time I just tried to scan a slide and everything seems fine when I preview the slide except that the SCAN button never gets activated.
In the past I had disabled the loading of what I think is the software update checker, and the the driver for the unit buttons in Msconfig (yes, I know.. it's an old W98 machine, but it still runs). This has never been a problem for running the scanner from within the Visioneer software using TWAIN. But even after turning those things back on I still never get the SCAN button activated. I tried the scan button on the unit and it did somthing, but I have no idea where the file went if it created one. It did not go into the SCANSOFT folder.
  • dduchardt Jun 19, 2009
    I uninstalled both the One-Touch Version 3.0 and PaperPort Version 7.2 that came with the scanner. I then used RegSeeker to clean the registry. It cleaned several entries. I have used RegSeeker to clean the registry often and never had a problem with it. I ran it a few times until it found nothing left to clean. I then reinstalled the scanner software. Now it works.
As described in my earlier comment
Posted on Jun 19, 2009
I have upgraded to Windows 7. Where can I get drivers for Visioneer One Touch 8920 Scanner?
You can't. This is an older model, "end of life" per Visioneer, and they never released drivers for any system later than XP. If the XP drivers don't work, you'll need to replace the scanner with a newer model.
Jan 17, 2011 | Visioneer OneTouch 8920 Flatbed Scanner
How do I scan slides with the Visioneer 8920?
In the Twain window at the top is a dropdown menu where you can select 35mm slides. That gives you two choices of resolution at 1200 or at 2700 dpi, plus a custom setting option.
Apr 28, 2009 | Visioneer OneTouch 8920 Flatbed Scanner
I need to install my scanner but do not have the cd.
Try this download site for the drivers. http://www.opendrivers.com/categorycompany/16/11669/scanner-visioneer-free-driver-download.html
Jan 19, 2009 | Visioneer OneTouch 8920 Flatbed Scanner
Visioneer one touch 8920
The scan motor is straining against somethinmg - so re do the lock/unlock routine and carefully examing the machine and the manual - usually in PDF on the software disk.
Oct 15, 2008 | Visioneer OneTouch 8920 Flatbed Scanner
Visioneer 8920
I have had this very problem with 2 of these scanners (8920) and finally figured out what happens is that the cheap chinese power supply loses power over time and then finally gives out. Before it fully gives out it doesn't have enough power to scan properly but will still turn the scanner on. Symptoms range from terrible scans with noise to the dreaded "scanner is locked" error. I got a new power supply from radioshack - 12 VDC at 1.5A (1500 MA) and it works like brand new! Make sure the power supply can deliver the full 1.5 A of the original! This is very important.
Jan 22, 2008 | Visioneer OneTouch 8920 Flatbed Scanner
Error message
Get another scanner. Check whether the lock has not been enabled at the bottom of the scanner. This has happened with me as well and a known Visioneer problem.
Sep 19, 2007 | Visioneer OneTouch 8920 Flatbed Scanner
Visioneer OneTouch 8920 Flatbed Scanner Logo
175 people viewed this question
Top Visioneer Office Equipment & Supplies Experts
Mark Gough
Ed Mac
Are you a Visioneer Office Equipment and Supply Expert? Answer questions, earn points and help others
