Question about Seat Covers 2004 Renault Clio MP3, Clio - CSC1E3-RN7009-2004
My oil cap melted down in the engine of my Renault Clio
    Master:
  • 448 Answers
Wow, that's bad for multiple reasons. It got hot enough to melt the oil cap, and that it went into the engine.
Posted on Aug 28, 2014
Renault clio overheating smoke coming from engine bay using up water and coolant blue smoke coming from exaust and white gunk on oil dip stick but had oil change?
blown head gasket --cracked head --or damaged engine block blue smoke is oil being burnt and the milky gunk is coolant/water mixing in with the oil
Sep 21, 2015 | Renault Cars & Trucks
Driving home slight bang in engine stoped wont start just turns over 2002 renault lio
Take out oil cap. Have someone swing engine check if cams turning. If not cambelt snapped.
Jul 08, 2014 | 2002 Renault Clio
White smoke petrol 1.4 renault clio.not stem
White smoke: White smoke is caused by water and or antifreeze entering the cylinder, and the engine trying to burn it with the fuel. If white smoke is present, check to see if the proper amount of antifreeze is inside the radiator and the overflow bottle. Also check to see if antifreeze has contaminated the engine oil. You can look at the engine oil dipstick, or look at the under side of the engine oil filler cap. If the oil is contaminated with antifreeze, it will have the appearance of a chocolate milkshake. Do not start the engine if the oil is contaminated with antifreeze, as serious internal engine damage can result.
It is also possible to be a engine problem you should immediate visit a car service.
Sep 12, 2012 | Renault Clio Cars & Trucks
Renault clio over heats and has a oil leek
locate were ur leak is coming from most common oil leaks are from the sump screw under the engine sometimes just tighting the screw can solve the problem and ur clio will over heat if ur level of oil is not right oil is pumped round ur moving engine componants to keep moving parts temperature down also check ur radiator for any leaks hope this helps
Mar 24, 2012 | Cars & Trucks
Hi, I have a renault clio 1.2 and there is a constant build of "mayonnaise" type oil inside the filler cap. Water never needs topping up, not sure what's going on ?
You have water seeping into you oil, usually a leaking cylinder head gasket. Have it attended to immediately, the contaminated oil is causing other damage while you drive. Sorry to say, but you are looking at a rather pricey repair.
Apr 16, 2011 | Renault Le Car Cars & Trucks
My Renault Clio 1.6 16v 2000 has started making a tapping noise from I think the top of the engine. Oil is topped up and no decrease in performance. Just tapping away! Any idea's and would it be an...
hi, just because you topped it up will oil it do'snt mean the oil good. the oil could be 4 years old and full of sludge the oil pipe filter filler can be partially blocked ( in the sump), the oil releif vale can stick open and pass oil back to the sump. the oil filter (changable external) can be partially block. to test oil is free to circulate START ENGINE TICKING OVER and TAKE THE OIL FILLER CAP OFF to see if oil comes out of the ROKER COVER. if not then the above applies
Sep 09, 2010 | 2000 Renault 181
I have a renault clio 52 reg, the engine coolant keeps goin down
i have a clio, had same problem too. its the head gasket. when this breaks or cracks it allows water into parts of the engine it should not, and therefore the water starts to mix with the oil forming this 'light brown gunge' the problem is that when driving with a damaged head gasket you will damage the head of the engine too which is why this is reoccuring. your best bet is to take apart the engine, clean it out, buy a new head gasket and then get the head of your engine skimmed. this could solve the problem depending on how damaged your head is.
Mar 23, 2010 | 2002 Renault Sportwagon
Oil pump failure on a renault clio 1.2 , 8 valve - y reg .
Usually it requires only replacing the oil pump, unless the engine has sustained damage.
Jan 12, 2009 | 2005 Renault 181
Renault clio clutch adjust
If the problem is just a clutch cable (clio 55 plate should be cable, not hidraulic), you can adjust or replace the clutch cable quit easily.
If the problem concerns instead the clutch disk, then you will need to put a car up on a bridge, empty the oil and fluid, and remove the clutch that is attached on the engine, on the right lower side.
This is usually not a job for home repair.
Nov 14, 2008 | 2005 Renault 181
Seat Covers 2004 Renault Clio MP3, Clio - CSC1E3-RN7009-2004 Logo
103 people viewed this question
Top Coverking Vehicle Parts & Accessories Experts
David Harrelson
David Harrelson
Lawrence Oravetz
Nicola Conroy
Are you a Coverking Vehicle Part and Accessory Expert? Answer questions, earn points and help others
