Question about Dyson DC07 Animal Bagless Upright Cyclonic Vacuum
Dyson dc07 Cut out after funny motor noise
SOURCE: Dyson DC07 burning smell.
sounds like it is on the way out this may be because 1, you need to clean the filter cos when its dirty it stop air from going around the motor witch makes it get hot and overheat 2, also if you allow the bin to get to full this will also stop the motor from geting air to it so a good clean on your filter and bin will allow air to the motor then no overheating should accur
Posted on Jun 17, 2007
chrispurs1
  • 372 Answers
SOURCE: problem fitting new motor into dyson dc07 casing
Hi.
There is try this site http://dysonmanuals.inc.io/
Posted on Nov 15, 2007
SOURCE: Dyson Dc07
I had the same issue and solved it easily.My experience is the same as the March 6th response/ When you push your foot onto the base and then recline the handle, use your toe to gently push the very front of the base down closer to the carpet. This creates a much stronger seal and suction and picks up every bit of dirt easily. If i do not do this extra step the suction is much much less. I tried an experiment with sand that I poured onto my carpet. Initially, I went over the sand 4 times and the dyson 07 would only pick up 50 percent of the sand. I then poured more sand onto the carpet, and this time pushed the front lip down so it was contacting the carpet. This time only two passes were needed to completely **** up all the sand. Not sure why this is not in the manual but it really works. Good Luck!
Posted on Jun 29, 2008
SOURCE: DYSON MOTOR BRUSHES
how do I change the carbon brushes in a dc07, I have removed the brush units from the motor
Posted on Jan 18, 2009
  • 10865 Answers
SOURCE: My Dyson DC07 won't turn on!
you may have a broken belt. Bad news regarding all Dyson's. You can't replace just the belt your self. You have to purchase a new belt assembly which includes the gears. And it wont be cheap. I would call it a design flaw but i am sure that dyson calls it a profit scheme.
Posted on Mar 29, 2009
Dyson making loud noise
Not sure if this will help but mine sometimes make a loud noise as well and its usually due to hairs stuck UNDER the belt in the motor area. Get some sharp skinny scissors and long skinny pliers and get under that belt, cut the hairs and use the pliers to pull out those hairs. That noise is usually because too much hairs stuck under the thing that turns the belt and the belt cant spin so it makes a lot of noise. When i do this it solves the problem of noise, but eventually hairs will collect in there again and make the noise again so i just take the hairs out again and problem solved.
Dec 14, 2013 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson dc07 is making weird noise
Hi there, it's Jack at Dyson.
I'm sorry to hear your DC07 is making a popping noise in use. Unusual noises can be caused by a number of different issues, and in order to determine exactly what's causing this we would need to hear it. I'd encourage you to call our freephone customer Helpline on 0800 298 0298 (UK), or 1-866-693-9766 (US). One of our experts will be able to listen to the machine over the phone and diagnose the cause of the issue.
We'll look forward to hearing from you.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Mar 04, 2013 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Loud humming dyson DC07
Hi Phil,
I apologize for our delayed response. I am sorry to hear you are experiencing an unusual noise when you initially run your DC07. Based on the details you provided we would appreciate the opportunity to trouble shoot with you over the phone so we can also hear the noise to better determine next steps.
At your earliest convenience, please call us directly at 0800 298 0298 (UK) or 1-866-693-9766 (UK). We look forward to speaking with you.
Best wishes,
Jessica
Nov 28, 2012 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson animal dc07 does it have a reset button?
The reset button is incorporated into the on/off switch for the brushroller which is the grey button next to the red power button. Try hitting that button separately.
Sep 18, 2012 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson motor making high pitched noise. Is this
Most likely, there's something in the dirt tube. Ic could be something like a piece of paper or cellophane, vibrating from the air going over it. without hearing it, a high pitch noise could be different things.
Jun 13, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Brush bar does not turn & makes a loud noise
You need to clean your roller and replace the clutch assembly that drives the belts. poorly designed vacuum with many flaws.
May 27, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson DC07 Animal Bagless Upright Cyclonic Vacuum Logo
20 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
