Question about Toshiba 52HM95 52" HDTV Projection Television
Lamp i have color wheels problem where find this parts..?
  • 10,594 Answers
Part Store is good place to buy parts.
Posted on Jun 18, 2009
All the lights are blinking
If a DLP suspect first the lamp, then the color wheel, which are the two most common failure parts in this set.
Color wheel faces lamp--look to see lamp not shattered inside and color wheel not missing parts of the plastic wheel at the same time as lamp is removed--it faces the lamp.
Jun 01, 2012 | Samsung 50" Slim-Depth DLP HDTV
The tv hums, you can turn the volum down to zero znd the tv hums to loud
You have a Bad Color Wheel,that is what is causing loud humming sound.
Encompass Parts Distribution 1-800-638-3328
Samsung Parts 1-800-627-4368
Color Wheel is Located Behind Lamp ,Pull Lamp out and with a Flash Light Look inside you should see Color Wheel. Color wheel spins 9,000 rpms per second
Apr 12, 2011 | Samsung HLS4676S Television
My HLN5065WX will turn on, play for about 1 minute, flash funky colors then go black. Once this happens you can not shut down the TV. You must unplug to turn off.
Bad Color Wheel, its located behind the Lamp Pull Lamp out and use a Flash Light You should be able to see it.
Samsung Parts.com 1-800-627-4368
You can also go to Encompass website and look up your Model#
Oct 27, 2010 | Samsung HLN5065W 50" Rear Projection...
Heard a loup pop when I turned the tv on; the timer/lamp/standby/temp lights on the power on button are now flashing; when I pushed the power button again the lamp light on the power button flashes and...
Color Wheel - Pull out the Lamp using a flash light look right into where Lamp was you should see the color wheel turn TV on watch to see if wheel is turning,From what you have said Problem will be the Color Wheel. Encompass Parts Distribution has them 1-800-638-3328
Sep 26, 2010 | Samsung HLR5667W 56" Rear Projection HDTV
Samsung hlp4667w Heard loud noise. No picture but could see that lamp was still on for about 5 seconds. Replaced lamp. No joy. Ballast is getting 330v from main PS. Cannot hear color wheel running.
Ur colors wheel is dead.Replaced the colors wheel.U have no tech.skill don't tries to replaced the colors wheel,because have to take alots of boards parts,and manchanics parts to get to the colors wheel.
Mar 10, 2010 | Samsung HL-P4667W 46" Rear Projection HDTV
Color wheel or did i break something else?
Usually a bad color wheel will produce a high pitched sound or even a grinding noise; some sets may actually shut down if the wheel is bad or shattered.
To determine if you have a bad color wheel:
  1. Turn set off and wait for main fan to shut off.
  2. Unplug the set.
  3. Remove the lamp door and then remove the lamp.
  4. In the direction the lamp faces you will see a round opening; the color wheel is facing this opening. It is a round plastic wheel with colored segments—we want to look to see if any of the segments are missing; a shattered wheel should be clear to see.
I have also posted the general instructions for Do it yourself replacement of this part in the TIPS AND TRICKS section of this site.
I will attach a photo of the color wheel for you to know what you are looking for----
If you have any questions feel free to respond to this posting.
If this has helped you rate this solution as I do this here for free.
SD TECH
Jan 01, 2010 | Samsung HL-R4266W 42" HDTV-Ready...
The tv makes a loud noise - timer/lamp lights light up but no picture/sound. Changed bulb - tv worked for a short while. Now issues starting all over again. What could be causing this?
Ballast Board that connects to Lamp it could be bad or recheck to make sure its pluged in good anyway Ballast Board is what turns Lamp on Loud Noise means Color Wheel which can also shut set off Id say Color Wheel Call Encompass Parts 1-800-638-3328 they List all the Parts you need Part# for color wheel is BP96-00674A cost 129.69 They also have Service Maualfor your TV. Also Look on E-Bay under Electronics found some good deals thier Got my Lamp for 85.00 and Ballast Board for 65.00
Nov 18, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Toshiba 52HM95 52" HDTV Projection Television Logo
124 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
