Question about Hampton Bay 52 In. Indoor/Outdoor Tahiti Breeze Ceiling Fan
Looseblades how to get to the blades to tighten them
Why can't the screw be tightened?
First of all, the blade has to be seated correctly on the spindle and the screw hand tightened to hold it in place. Next, a locking device such as a screwdriver has to be inserted crosswise between two teeth to prevent the blade from rotating. With the blade locked, the screw can be tightened. Finally, be sure to remove the locking device before operating the saw.
Oct 05, 2015 | Saws
Why can't I tighten replacement blade sufficiently?
Check the diameter of the replacement blade hole against the removed blade. Similar blades can have different size mounting holes.
Sep 17, 2015 | Saws
Why won't my saw blade go on tight. the mechanism that secures the blade won't tighten down good enough.
You need to make sure the blade is centered properly on the washer on the spindle as you tighten the nut. It can slip off while you tighten the nut. Tighten the nut a little at a time while you wiggle the blade to make sure it's seated properly in the washer.
Sep 14, 2014 | Dewalt Heavy-Duty 36V Cordless 7-1/4"...
Jig saw blades wont stay in.
loosen it more before you put the blade in.
Mar 16, 2014 | Skil Saws
Circular saw motor turns when tightening saw blade
Insert a tool such as a screwdriver across the blade guard and against a tooth to prevent blade rotation, then tighten the blade nut. Be sure to remove the wedging device before operating the saw
Dec 29, 2012 | Now Evolution #Fury 7 1/4" Mp Circular Saw
How to tighten blade
if the blade is unbalanced it will not stay tight and should be replaced then with a block of wood to hold the blade from turning tighten the replacement blade
Jun 10, 2012 | Black & Decker 19" Electric Lawnhog...
My blender is leaking slightly from underneath the blade. Is there a way to tighten the blade coupling?
I am guessing you have a KSB52. If the leak is through the blade spindle then tightening won't help. The "wingnut" is tightened through use anyway. The most likely cause is a failed seal. The whole blade unit will need replacing, search Amazon for 9704291
May 04, 2011 | KitchenAid KSB560 5 Speed Blender
How do i tighten my wiper blades?
You could replace the arms if they are ***** out or put tin foil over gear to shim it up to tighten gap between the arm and gear I see lots of new parts on eBay so it must be a commend problem
Jan 30, 2011 | 2000 GMC Jimmy
Can't tighten the blade- it spins
Use a round shaft screwdriver place between the blade teeth to prevent it from turning.
Mar 04, 2010 | Sears Craftsman 7-1/4 in. Circular Saw...
Jigsaw dc330 blades keep poping out when used
Hi Paul,
When inserting the blade, turn the saw upside down to prevent the blade from moving while tightening.
Before inserting a new blade, check the receiver for obstruction or debris that may prevent the blade from properly registering with the tightening screw.
Make sure the blade is fully seated in the receiver before tightening.
The tightening screws that secure blades on any type of reciprocating saws (Jig, Scroll, Sawzall, etc.) are constantly under stress and do wear out. If the problem continues, it may need to be replaced.
Best regards
Mike
Oct 29, 2009 | Dewalt Saws
Hampton Bay 52 In. Indoor/Outdoor Tahiti Breeze Ceiling Fan Logo
16 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
