Question about SOG Knives Salute Knife
Assist blade hard to open
Sog zoom mini assist blade hard to open
My Cricut Explore Air wont cut
If your Cricut machine is not cutting all the way through your material, or is only scoring the material, choose a machine below for specific troubleshooting tips. Fortunately this issue can usually be resolved with basic troubleshooting.
correct cut settings.
  • Remove the blade housing, then remove the blade and ensure that there are not any bits of paper stuck to the blade or lodged inside the blade housing. Ensure that you replace the blade housing correctly into the machine. Once clean, test your cuts again. If the blade and housing are already free from debris, or cleaning it did not help, proceed to 3.
  • Try an arm buoyancy test: gently press down on the black arms that surround the blade housing and then release them. Do they bounce right back up, or do they stick or rub in any way? If they stick or rub, please contact Customer Care through one of the options below for further assistance. If they bounce right back up when released, proceed to 4.
  • Increase the machine pressure settings and try your cuts again. If this does not change the cut result, proceed to 5.
  • Increase blade depth by turning the dial at the top of the blade housing. If this does not change the cut result, proceed to 6.
  • Perform a Hard Reset on the machine. If this does not help, proceed to 7.
  • Check your machine's firmware version. If the firmware is not up to date, perform a Firmware Update using Cricut Craft Room, a Gypsy device, or Cricut Design Studio.
  • Retry your cuts with a new blade housing.
  • If the machine is still not cutting through materials, or is only scoring the paper, please contact Customer Care through one of the options below for further assistance.
  • Forced Firmware Update on the machine through Cricut Sync.
  • Retry your cuts with a new blade housing. If the issue persists, proceed to 8.
  • Attempt a Format and Restore on the machine through Cricut Sync. Please note that this step should only be taken if all other steps have failed to resolve the issue.
  • If this does not resolve the issue, please contact Customer Care through one of the options below for assistance.
  • new blade. If this does not help, proceed to 5.
  • Adjust/increase the Multi-Cut setting in the Cricut Craft Room cut preview screen and retry your cuts. If this does not change the cut result, proceed to 6.
  • Retry a cut using a new blade housing.
  • If the machine is still only scoring or not cutting through the material, please contact Customer Care through one of the options below for assistance.
  • Jan 16, 2017 | Crafts & Hobbies
    How do i change a blade for a zona mini hack saw?
    Hello there.
    The TENSION in the frame holds these blades in their slot.
    What you do is
    1) turn the saw upside down so the blade is pointing upwards.
    2) Hold the handle of the saw tight against your tummy or if you have strong arms just your hands So the saw faces away from you.
    3) Put the far end of the frame against a hard surface like a wall or bench.
    4) Push the handle against the force and you will see the FRAME bend very slightly, this will allow you to push the blade out of its slot.
    Engage new blade at the handle end then do the reverse of the above to allow the other end of the blade to go in the slot .
    DONE !!!
    Sep 21, 2014 | Zona Blade: 36-656 Mini Hack Saw Blades...
    Zoom button stuck on full in zoom
    Possible that the zoom switch is short or struck in action where by the zoom has gone to the extreme end. Wriggle the switch after the cam is switched off and see if it returns. If not the unit must be opened to check for the switch failure or possible motor failure, drive circuit or a mechanical jamming.
    Nov 30, 2011 | Canon MVX200i Mini DV Digital Camcorder
    Helo. My name is Peter. My questions is: Where do i find the cruise control fuse?Is it number 8 in the box under the hood?Thankyou for your assistance
    There appear to be two fuses for the cruse control. One will be in the fuse box inside the car and will be # F2.53. This should be a 10amp mini blade style fuse. The other will be in the fuse box under the hood and will be # F1.29. This should also be a 10amp mini blade style fuse.
    Mar 08, 2011 | 2005 Ford Focus
    Ariens 34 zoom blade binds at mid-height blade
    Sounds like the mower deck is lower on one side. I am having the same problem with my older tractor mower.
    Jul 24, 2010 | Ariens 34 In. Zoom Series Riding Mower
    How much does a pto cost, is it easy to replace or hard
    The electric clutch is approx $100 to $150. It is easy to replace. Blades are inexpensive.
    Apr 19, 2010 | Ariens 34 In. Zoom Series Riding Mower
    Camera GL2 Zoom Noise Problem
    the sound is either the tape reels spinning or the zoom can you possibly send me a copy of the sound mattgandersn@aim.com
    Feb 17, 2009 | Canon GL2 Mini DV Digital Camcorder
    Canon XM2
    You might have bad contact in zoom switch unit or a short in zoom switch. The switch assembly is replaced for the remedy.
    Mar 13, 2007 | Canon XM2 Mini DV Digital Camcorder
    AF assist light
    No, it doesn't. I had a 2000 and enjoyed it. This one has a faster lens.
    Sep 11, 2005 | Olympus Camedia C-2040 Zoom Digital Camera
    SOG Knives Salute Knife Logo
    74 people viewed this question
    Top Sog Knives Boating Experts
    Steve
    Steve
    ray gallant
    Fabrice Wolters
    Are you a Sog Knives Boating Expert? Answer questions, earn points and help others
