Question about Sony Cyber-shot DSC-S650 Digital Camera
Sony cybershot 7.2
My camera states format error. how do i reset or fix issue?
  • 10,594 Answers
When memory card got unstable, camera gives format error. Format memory card by format option in camera Menu.
Posted on Jun 18, 2009
Cybershot w310 getting card format message
What happens when you try to format the card?
Feb 18, 2013 | Sony Cybershot DSCW310 Digital Camera
My sony cybershot dsc-w350 keeps turning itself on and off and reads system error
The system error is displayed in the Camera when there is some internal malfunction or when the Lens in the Camera get stuck.
Try power resetting the Camera to check if it resolves the issue. To power reset the Camera, turn off the Camera and remove the battery pack. Press and hold the power button for 30 seconds. Remain the Camera without power for 60 seconds and reinsert the battery.
If the issue persists, try Initializing the Camera. The Initialize option can be done only if the Menu of the Camera is accessible. To access Initialize select MENU-->SETTINGS-->MAIN SETTINGS-->INITIALIZE-->OK.
If the issue persists, service may be required.
Thanks for using FixYa
KenSolutions
Dec 05, 2010 | Sony Cybershot DSCW350 Digital Camera
So many issues with my sony cybershot DSC-T20
Two methods: go into the setup menu and scroll to "reset" and follow the on-screen instructions. Second method...remove the card and battery...press all the buttons...leave the camera alone for 20 minutes...insert the card and then the battery...turn it on.
Sep 25, 2009 | Sony Cyber-shot DSC-T20 Digital Camera
Problems with my Sony Cybershot W210
1) Make sure that you're not using more than 4 GB memory stick pro duo with the camera. Then try to remove the memory stick and capture 2 images in the internal memory and turn OFF and turn ON the Camera and check. If the error message comes, its the issue with the Camera itself and requires service after resetting. to reset the Camera, select Initialize under Main Settings 1 menu under Settings. if the issue persists, the camera may require service
If its working fine, transfer all the images to the Computer and format the memory stick. Formatting will delete all the contents. If the issue persists, memory stick should be replaced.
Sep 21, 2009 | Sony Cyber-shot DSC-W70 Digital Camera
Sony Cybershot DSC S650 Memory stick not formatting
Well I have the same camera.
And mine won't turn on.
Suggestion dont trust this camera.
Or maybe it just can't hold that much memory.
Mar 15, 2008 | Sony Cybershot S650 Digital Camera
Format Error in Sony Cybershot
it could be a faulty memory card, but a more likely cause is that this stick isn't formatted yet. you can format it usually by bringing up the camera menu, then going to tools and format. you can also format it by using windows and a cardreader or your camera.
Mar 04, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
ho un problema con la mia cybershot dsc-t5 come posso risolvere l'errore di formattazione C:13:1 su una memory stick duo prodotta da neo
Jan 02, 2008 | Cameras
Sony cybershot
according to the manual and E:91 code means "a camera malfunction that you cannot reverse has occurred" rhe corrective action states "Press the RESET button" Hope that works for you. I have a cybershot with a lens problem and Sony wants to charge me $190 to have it fixed
Aug 31, 2007 | Sony Cyber-shot DSC-T20 Digital Camera
Sony Cyber-shot DSC-S650 Digital Camera Logo
198 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
