Question about Jabra Stone Bluetooth Headset
Jabra stone2 change language - Jabra Stone Bluetooth Headset
HOW TO CHANGE LANGUAGE ON JABRA MINI BLUETOOTH
Turn off headset, press and hold power button till light flashes blue and red continously.
Release power button and press it twice. You will hear a Chinese voice prompt.
Press twice again to hear English voice prompt.
Press and hold till it turns off.
Turn it back on and connect to phone.
Oct 12, 2016 | Jabra Solemate Mini Portable Bluetooth...
I forgot my passcode for my jabra stone2 headset. How do I reset it
Did you try
The pass code or PIN is 0000 (four zeros)
Jun 21, 2014 | Radio Communications
I forgot my pass code of my jabra stone2. How can I reset it
If you haven't changed it it should be 0000 (four zeros)
How to change language from german to english
You need to download english version from Jabra Support web page and install it.
Mar 08, 2014 | Jabra Stone Bluetooth Headset
I have a jabra VBT185z and lost the passcode since moving. Can you help me?
Go to this site, and it will walk you through each step to connect your particular Jabra headset with your cellphone. Choose the headset, and then at the next page, choose your phone. Moving your mouse over each step will change the picture to what you should be seeing on your phone at each step.
http://jabra.pairx.co.uk/ Pls come back and let us know if this solved your problem.
The passcode for Jabra bluetooth is 0000
Jan 02, 2010 | Jabra Bt185 Bluetooth Headset
I change my handset now jabra bt125 is not
Password is 0000.
Jul 03, 2009 | Jabra BT125 Headset
By Master Reseting english language has been changed by Chinese then how to restore English language
Hi There is a tool you can use to flash your firmware to the language you want. It is called Fighter. If you want it, I can help you to flash it to the firmware of your choice either Chinese, French, German.... I can even upgrade your P900 to P910 version so your external memory can recognize the Memory Stick up to 1GB but instead you cannot use the Bluetooth Function after upgrading. You can use the Jabra a12 Bluetooth Adapter instead to have a new connection with Bluetooth. I has my P900 working this way and it works Great. This tool can even unlock your phone too to the most latest firmware. Regards, pingping
Jun 12, 2007 | Sony Ericsson P900
Jabra Stone Bluetooth Headset Logo
23 people viewed this question
Top Jabra Radio Communications Experts
TO Lady
Greg Cann
Greg Cann
Michael Vincent Cruz
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
