Question about Nintendo 2ds electric Blue
My 2ds can turn on, but won't show the image
The blue light will show, but the two screens won't turn on or show image. I think the inner image screen is broke.
Blue light turns on but tv screen stays blank
The blue light indicates power is getting to your TV but there may have been failure of the internal power supply
Jul 07, 2013 | Sceptre Televison & Video
Hitachi LCD TV, Problem with the image
I am having the same problem with my 50v500 as well. Please let me know if you find a solution.
Apr 20, 2010 | Hitachi 50V500 50 in. HD-Ready LCD...
My Sony KP-46WT500 screen shows the tv image in blue only for a few seconds, then it goes completely blank (as if it were off). Do I need to replace the bulbs?
It is rear projection TV that use 3 picture tubes of red-green-blue to show color picture on tv front screen.
Do you see standby red light blinking when TV shuts off after showing blue image for a while?
If red standby light is blinking, please count it how many times it blinks, there would be 3 seconds pause between blinks so count pause to pause and post it here to find out possible solution.
Thanks.
Dec 22, 2009 | Sony KP-46WT500 46" Rear Projection...
I've got a Philips 50P8341A Projection 50'' TV. My problem started with the screen only showing an orange image. The picture was clear and sharp, but there was no color other than orange. So I tried to fix...
Turn the top left knob down till the pic comes back and the reason your color is off is the fluids in the green and blue chambers needs to be changed.
Nov 12, 2009 | Philips Televison & Video
Cannot rebot my 400 it shows a soft blue lite, but will not come on
if you dont get the splash screen at least then you could have either just bad backlight or more serious issues. can you see the image if you hold it sideways to a light? if not, you may be out of luck but if you do see some image and hear clicks when you touch the screen, you could take it to an electronics shop to see if they can fix the backlight.
Nov 10, 2008 | Fine Digital FineDrive 400 GPS Receiver
Blinking blue light
You have to check if you can see the image on the screen or not after it went blank (Power on both CPU and monitor) by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. Like mine, I can see window image using flashlight and check lamps inside. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so.
Thank you
Mar 12, 2008 | Samsung SyncMaster 930B 19" LCD Flat Panel...
Nintendo 2ds electric Blue Logo
Top Nintendo Home Experts
john h
Tom Chichester
Are you a Nintendo Home Expert? Answer questions, earn points and help others
