Zircon Stud Finder, Electronic Stud Sensor, Includes Picture Hanging Kit, International 62320 Logo
A
Anonymous Posted on Apr 15, 2014
Blinking lights The bottom 3 lights flash continually,the top light doesnt come on
Can you help diagnose a tv with no picture or sound? just a baclklit and flashing red indicator light
The red light flashing is indicating the error.
depending on the make and model of the TV, the duration of the flash and number of flashes determines the error code.
1helpful
What causes orange light to flash 4 times?
It is related to a badly installed or empty print cartridge: http://www.canon.co.uk/support/consumer_products/product_ranges/printers/pixma/error_codes/#1600
1600 - Orange light blinking 4 times Description:
The ink cartridge has run out.
Resolution:
  1. Lift the printer cover up.
  2. Identify the ink cartridge that has run out (the ink cartridge flashes quickly at around 1-second intervals).
  3. Replace the applicable ink cartridge and close the cover.
  4. Press the [Resume/Cancel] button on the device to continue printing.
If the above solution has not resolved your error, please contact your nearest Canon authorised service facility using the link at the top of the page.
1660 - Orange light blinking 4 times Description:
The ink cartridge has not been installed correctly.
Resolution:
  2. Check that the red lights on the ink cartridges are all turned on.
  3. If no red light is activated on a particular cartridge, check that the cartridge is securely positioned and adjust if necessary.
  4. Also make sure that the orange protective cap has been removed from the bottom of the ink cartridge.
  5. Press the [Resume/Cancel] button on the device to continue printing.
2helpful
2answers
The power button has a blinking red light, what does this mean?
4 flashing red light = av cable not connected. double check id av cable is connected properly. try using different av cable.
3 flashing red light = hardware problem . may require repair
2 flashing red light = overheating
1 flashing red light on bottom right LED with error code = hardware failure may require repair
This is my second dockstar, and both have just gone to rapid blinking amber lites. seagate doesn't really tell you any thing.
moz-screenshot.pngmoz-screenshot-1.png1-If you never shut off the device try to turn off for 4 hours and try to use it again.
2-The bottom light must flash when is on,if not you have a power supply or net cable problem.
3-If the top light is amber is indicate you have a disk problem
4-Do a power cycle
5-if the problem continues run the disk diagnosis utility from the web interface
6-If fails the drive needs replacement, check for warranty
7-Try to do a system reset.Press and hold the switch( a small hole at the bottom of the Ethernet) until the top front light flash and allow the unit to restart.
If you need more help come back.Post / thumbs / testimonial are welcome!
3answers
What does it mean when the ac button lights are blinking the ac buttons-ac and circulating button lights blink continuously and you cannot shut them off at all this just began after the car wouldnt...
it is needing to be calibrated because of dead battery.i cant remember for sure but i think you had to push rear wiper and recirc buttons at the same time and hold them down a couple of seconds. engine has to be running and at normal operating temp. lights will flash and vents will change heat to cold etc. if it fails any test the lights will just keep blinking untill repaired and recalibrated.
Flashing light
Here is what HP has on the subject of the triangle light flashing:
c00028322.gif 1 - Attention Light 2 - Ready Light 3 - Go Light Figure 2: Printer light key c00028323.gif 1 - Symbol for light off 2 - Symbol for light on 3 - Symbol for light blinking
c00028328.gif Door open, media out, no print cartridge, or media jam
The printer is in an error state that requires operator intervention or help. Check the following:
  • The print cartridge door is completely closed.
  • Media is loaded.
  • The print cartridge is correctly installed in the printer.
  • There is no media jam.
Figure 8: Paper jam c00028328.gif 13.JJ.NT JAM IN TRAY 1
13.JJ.NT JAM IN TRAY X
The Attention LED is blinking. Check paper loading then open and close top cover.
When there is a jam in tray 1, verify the paper is loaded correctly, open and close the top cover. Pressing GO is ignored.
When there is a jam in tray X, verify the paper is loaded correctly, open and close the top cover. Pressing GO is ignored. These are the error explanations for just the flashing triangle light, there are many more, but none for just the flashing triangle.
If the light pattern is different let me know (other lights on as well)
-Hope this helps.
2helpful
Error 5100
Hello! Try this:
1. Unplug the power cord
2. While pressing the ON button, plug the power cord back in.
The power light should flash an orange/yellow color.
Continue pressing the ON button, and press the RESUME button 4 times. The light changes every time you press it.
3. Release both buttons, and restart the printer.
The printer should now stop blinking and operate as usual.
I hope this works for you. OMS
Top Zircon Measuring Tools & Sensors Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Zircon Measuring Tool and Sensor Expert? Answer questions, earn points and help others
