Question about Panasonic Audio Players & Recorders
I need cables for the SB WA05 subwoofer
Bought a used sub but did not get any cables so I cannot use it, Where can I buy these cables?
5 Suggested Answers
  • 2336 Answers
SOURCE: JBL SUB ACR10 SUBWOOFER
I would suggest to check the rectifiers first, very unlikely that the capacitors became shorted.
Posted on Sep 04, 2008
Grubhead
  • 5487 Answers
SOURCE: Faulty sound on Panasonic home cinema system
If you can leave off the subwoofer (disconect it) and the sound distorts you know it's the amp.
In either case you are looking at a transistor or IC that has a heat problem. You can find out which by spraying with Servisol Freezer spray on to a suspect device, when the distortion is there. If it goes away when the suspect is cooled, then it's gone. To confirm it heat it back up with a soldering iron, it should then start acting up again.
You should be able to get the spray from Maplin (UK) or Radioshack (USA), or that type of shop.
Posted on Dec 02, 2009
  • 127 Answers
SOURCE: I have bought JAMO sub 250 subwoofer and Pioneer
You don't need such cable, although you can use it if you have one. If receiver has only mono SUB output (as majority of receivers have), you just connect it to the Left socket on the Sub and it will work.
Using the Y cable would probably cause that you will fed the same signal to both left and right sockets, but half the intensity (you would divide the output from receiver by 2). So in the end the Sub would receive exactly the same signal as when using normal straight cable.
Posted on Mar 03, 2010
How do I connect a new dvd reader with a Panasonic SB-WA340 active subwoofer?
Of the Phillips is not a home theatre system them you can but you will have no volume co trol of the sub. If it is the alot of philips home theater in a box (htib) use special plugs...you would need to change the cable end of the sub to a compatible plug.
Aug 23, 2016 | Panasonic Audio Players & Recorders
How to connect a SB-WA310 Panasonic subwoofer to a different reciever
I want tyo do the same thing and use it for my computer or for my mothers computer as a subwoofer. I am an electronics engineer and have designed 2 mono class D aamps. I have degrees in electronics engineering and already have done this witha yamaha subwoofer surround system simular to this but it had a Svideo type looking plug to connecting it to the receiver. So I just traced the wires and solder traces and found the turn on wire to turn the yamaha sub module on. I just had one of these Panasonic SB-WA310 sub modules givin to me I thought I'd do the same when I got a chance. I own my own small business repairing car amps, I'm the cheapest in the USA and offer so many services no other car amp repair business offers. I do professionaly qulity work, have 17 years or more years experience, have'nt added up the years. Anyway I can be contacted at ampman37@gmail.com and I will post what you have to do what has to be done when I figure it out to get the SB-WA310 Sub Module on and used just for sub use and also use the rest of the channels, why waste them. I have the pinout of what each of the 25 wires do. So I think I know already how to turn this on just cause I understand the lingo of the pinout mames. I just have'nt had time to do it. Even though it would only take me a couple minutes to try it I'm so busy with repairs. When I get caught up I will get to it in about a week. Anybody who is still interested in getting this module running just for the sub and maybe the rest of the power for mids and highs E-mail me at the address above, I'm not one to post messages on these sites. Though, I get allot of amp repair business from people from this site. Still, I'm not one to go around posting. I will most likely will for this if many peopl are still wanting to know. Talk to ya in the future.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/mark_b53a7494531bf96d
Nov 29, 2011 | Panasonic SB-WA100 Subwoofer
How to hook up my subwoofer
It sounds like you're doing everything right. Did you define the sub to the Onkyo (Subwoofer = Yes, page 22)?
Let's prove the sub works. Set its volume about half-way, cutoff= 170Hz. Temporarily connect an RCA cable from its Line Input to one of the Tape Out connectors on the Onkyo and play some FM through it. If it's alive you'll hear the low end of the music.
Don't buy into the hype that there are different pedigrees of RCA (or speaker) cables that will make an audible difference. Save your money.
May 04, 2010 | Onkyo TX-DS696 Receiver
I have bought JAMO sub 250 subwoofer and Pioneer VSX919AH-K amp. Please advise how can I connect them. The amp has one RCA out for sub but the sub has two line in sockets (left and right). Do I need to use...
Dec 30, 2009 | Jamo SUB 250 Subwoofer
Nov 29, 2009 | Panasonic SB-WA100 Subwoofer
Simple question?? how do I connect my Panasonic subwoofer to my denon receiver?
I have a very similar problem with the same exact Panasonic sub. I went to Best Buy and Radio Shack looking for an adapter, and they basically told me that one does not exisit. Apparently, Panasonic designed the home theater system specifcally so that it could not work if any part of the entire system was ever seperated.
May 27, 2009 | Panasonic SC-HT930 System
Need to connect panasonic sb wa730 to panasonic sa dp1 system
There is a subwoofer outlet at the back of the sa dp1 connect via cable to the inlet on your sub then on your sa dp1 remote press shif and subwoofer at the same time
Feb 28, 2009 | Panasonic SC-HT730 System
Panasonic dvd player for subwoofer
I have a SA-HT 690 system with a bad SB-WA342 sub. I can sell you my player or buy your sub.
Oct 29, 2008 | Panasonic SC-HT730 System
Help with SB-WA920 sub woofer PLEASE!!!!
Sure, you can use transition between SB-WA920 system cable with other output. So, you use them as speaker. That's it.
Sep 07, 2007 | Panasonic SC-HT920 System
73 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
