Question about Sony PlayStation Portable (PSP) Console
Psp won't charge when plugged into computer
I can't get the psp to turn on, no green light, nothing. When plugged into computer, it doesn't try to charge. I have checked the cord and it is fine, I have moved it to different ports, that I know work. Any ideas or suggestions would be great
    Sergeant:
  • 321 Answers
U cant charge on a computer unless you have a charger that hooks up to it...are you sure your using a charger or are you using the cord that transfers data to ur psp! the data cord will not charge ur psp its not a charger all it does is transfer data sorry you need a charger for the psp not a data cable
Posted on Jun 18, 2009
I plug in to AC charge for the whole day and try to turnon, with switch on the right hand side, nothing happened
On the occasion it won't chrage the PSP. You should double check that it is charging it. Also, try to see if it'll turn on while plugged in. If it turns on, let it charge, if it doesn't either the battery is shot or the plug-in spot is broken or not responsive.
Sep 12, 2011 | Sony PSP (Piano Black)
When i turn on my psp the green light will come on but the screen won't come on and then a few seconds later the green light will shut off completely.
Hi tokyo_grl,
First you have to figure out what is causing the problem. Try the following steps.
1. Remove anything that is connected to the PSP, including the
Memory Stick, battery and any UMD games.
2. Plug the charger into both the wall and the PSP system, then wait for at least 30 seconds before turning the psp on.
--If the PSP turns on, your problem is not with your PSP, but with an accessory that was previously attached.If it does not turn on, your PSP is in need of a repair.
3. Next, unplug the power adapter from the PSP, and firmly place the battery into the PSP.
4. Plug in the Power Adapter once again, and wait at least 30 minutes for the PSP to begin charging, then try and power on the PSP system.
--If the PSP does not power on with the battery plugged in, but it did with just the charger, you need a new battery. If it powers on, do the next step.
5. Place the Memory Stick inside the PSP , and turn on the power. If the PSP does not turn on, but it turned on without the memory, you need a new memory stick.
If your PSP did not turn on during step 2, your PSP is bricked and indeed needs to be repaired by a qualified technician. I hope everything works out for you. Good luck.
Jul 16, 2011 | Sony PlayStation Portable (PSP) Console
Psp green light on, but no booting or anything. its not a fault of Software... its Hardware for Sure! any help?
Hello
If the green light comes on, but the unit won't power up, you could have a battery problem.
Clean out the battery compartment. Use a can of compressed air to remove dust, hair and other debris. If you left the battery in while you stored the unit, look around the connectors for any sign of corrosion that could be affecting the connection.
Plug the PSP into the power adapter with the battery still inside. If this doesn't work, remove the battery and see if the PSP powers on with the adapter only. If it does, then the battery likely needs to be replaced.
Boot the unit in recovery mode. The PlayStation Portable is like a small computer with a tiny hard drive. And just like a computer, sometimes it gets scrambled; booting in recovery mode can help you identify or correct the problem.
Determine if your PSP has been "bricked." If the PSP was turned off for any reason during a firmware update, it can cause "bricking," so named because it renders your PSP into a useless, plastic brick. Buying a new PSP or sending yours to Sony for repair are your only options if this has occurred.
Jun 10, 2011 | Video Game Consoles & Games
PSP charged all night and will not power on
You're not being clear.
You say "I get nothing"
Do you get a green light? Or no green light?
What if you plug it in? Do you get a green light if it's plugged in with no battery inside?
If you get a green light with the battery in but nothing on the screen, your PSP is bricked.
If the PSP works while plugged in but not with the battery it's either having motherboard problems or the three prongs on the back of the PSP are not making good contact with the battery.
Mar 16, 2010 | Sony PlayStation Portable (PSP) Console
My psp dosn`t turne on any more.any help?
do you install custom firmware? coz if you do maybe it got brick. try using pandora battery if it works. if it still dosen't works you may have a hardware problem.
Jul 19, 2009 | Sony Video Game Consoles & Games
Psp wont turn on
the downloads dont matter.u change the battery and if it doesnt work take it to a shop.if u have spill water on it open the psp cover and everything and for 2 days put it in the hot sun
Apr 25, 2009 | Sony PlayStation Portable (PSP) Console
Green light is on but nothing on the viewer
Ok it is bricked so what you need to do is: Take it to a shop, or get a Pandora's battery, email me when you have a pandora's battery
Feel free to E-Mail me: Thomashedderwick@hotmail.com
Aug 10, 2008 | Sony PlayStation Portable (PSP) Console
Psp doesn't turn on
Your PSP is on, hence the green light, its most likely your display that is messed up.
Try tapping the display button ( which is next to the mute button) a few times, if nothing comes up then you should send it in to be fixed or buy a new one.
Feb 19, 2008 | Sony PlayStation Portable (PSP) Console
PSP no power
Try taking the battery out and plugging it into the wall with only the charger and see if it turns on. does The green light came on?.
Jan 01, 2008 | Sony PlayStation Portable (PSP) Console
PLZ Help
If you bought it new the warranty should cover it...send it back to sony. If not you may have to take to a repair center
Dec 06, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
93 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
