Question about LG Washing Machines
Lg wf f6627td
Water fills but just rotates and immediately starts beeping
4 Suggested Answers
  • 291 Answers
SOURCE: LG WF-8071TTP drum fills 3/4 and then drains unexpectedly
Either a main control board or you have a drain line problem causing the water to siphon out. If you house drain is lower than the washer water fill line or if your drain hose is sealed into the house drain line then you can have the water siphoned out of your washer. Check to make sure the drain line is not to far into your house drain pipe and that there is air around the drain hose where it enters the drain pipe, (not sealed tightley). If it is not the drain siphoning then you need a technician to diagnose the main control board and to replace it. Good Luck Appliance Specialists
Posted on Dec 14, 2009
richroth
  • 9472 Answers
SOURCE: STARTED, ROTATED A FEW TIMES,
he error code "dE" signifies a door open error. This may simply be because the door is not all the way closed, though it could also represent a number of other problems. There may be a faulty door switch, a malfunctioning electrical connection or a damaged gasket.
Posted on Dec 11, 2010
SOURCE: LG WF T6517TC Washing Machine does not fill water
sir
my washing machine WF-T6517TC
when it start to wash get Alarm "dE" beep and stop machine.
what need to do.
call me 91080843
Posted on Apr 29, 2013
Lg fuzzy logic wf-t1210stg water problem. The waterfill overflowing
(1) Check whether the pulsator is rotating when water fills continuously. If it doesn't rotate, water pressure is not sensed. Check the tube of the Ball Pressure Sensor(Pressure Switch), whether it is bent or blocked, repair that by unblocking.
(2) If there is no defect in the Ball Pressure Sensor(Pressure Switch), check whether the air hole of the outer tub is blocked, if the air hole is blocked, repair the blocked hole.
(3) Does water fill even though it is not energized (power is off)?
If so, change the inlet valve.
(4) Does water fill immediately after the power switch turns on before pushing the START/PAUSE button? If the answer is yes, then you have a short circuit of the triac of the controller.
Change the controller.
Good Luck.
May 08, 2015 | LG Washing Machines
WF-T1022TP(H) INCOMMING WATER DOES NOT STOP
could b eather a pressour switch prob or inlet valve sticking open
Apr 29, 2015 | LG Washing Machines
LG WF-T6517TC my washing machine WF-T6517TC when it start to wash get Alarm "dE" beep and stop machine. what need to do
Don't know exactly what that code is but normally washing machines will beep and switch off quickly if the pump is blocked.as it's not allowing water yo be pumped around.
I suggest that is checked firstly before calling anybody out.
Jan 02, 2015 | Washing Machines
WF-F7061DN washing machine water level lights flashes
Are you overloading the machine? If you run the machine without anything inside and this happens, check the motor or belt.
Jan 14, 2014 | LG Washing Machines
STARTED, ROTATED A FEW TIMES, FILLED UP WITH WATER, NEXT MODE "WASH" BEEP BEEP. BEEP BEEP.. "d E" .. MACHINE STOP. POWER STILL ON. CONTROL BUTTONS STILL FUNCTIONING. IT IS A LG...
Dec 11, 2010 | Washing Machines
sir
what need to do.
call me 91080843
Apr 10, 2010 | LG Washing Machines
LG WF-T753A Top Loader washer hot water inlet valve
Just found this whilst looking for known issues with my machine as the cold water won't stop when filling.
http://safemanuals.com/user-guide-instructions-owner-manual/LG/WF-T753A-_E
Aug 25, 2008 | LG WFT1071TP Top Load Washer
Washing Machines Logo
20 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
