Question about Sony KDF-50E2000 50" HDTV
Power light come on when the tv is turn on
I just replaced the xl-2400 lamp and a new ballet. because the lamp replacement light came on. now the red power light come on when i try to turn the tv. on. can you help.
5 Suggested Answers
  • 7 Answers
SOURCE: standby lamp flashes red
Had the same issue today when I replaced the bulb with housing. Did you try to turn on the TV without attaching the housing door? That was my problem...tried to see if the new bulb worked without going through the motions of screwing on the door. I believe the housing contacts are not making a good contact. Try taking the housing out and reinstalling it firmly in place and definitely screw in the door firmly as well. Perhaps it will work then. Advise...
Posted on Aug 06, 2009
SOURCE: how do i install a replacement xl 2400 lamp within
how do I REPLACE THE LAMP IN THE kdf-42WE-655 WEGA TV. i PURCHASED THE REPLACEMENT LAMP, PART NO. XL-2100U>
Posted on Sep 19, 2009
  • 1527 Answers
SOURCE: replaced lamp in Sony Wega tv - Sony xl-2400. tv
hello make sure the lamp and the cover is fitted securely, when you've done this the tv should be ok
shaun
Posted on Nov 10, 2009
  • 1039 Answers
SOURCE: power light keeps blinking Red and TV will not turn on
Is the light blinking constantly or is there a long pause then more blinking. If constant check the lamp door switch . Usually it is broken or jammed. If you jumper it and the set comes on that it. 4 blinks is bad fan.
Posted on Mar 26, 2010
When i turn my tv on it goes of straight away and keeps flashing red can you help
After replacing the lame, the lamp time should reset. Otherwise, TV won't start. If you wish to get more details, check this site. Pull up older posts there. Check the site with patience, as it has over 2350 posts now. All are related to electronic equipment repair help. If you check the site in Timeslide option, which can be selected from the dropdown list at the top left side of the display window, it will make search easy.
Apr 22, 2013 | Sony Lamp For The Kdf E50A12U Rear...
Turned tv on this morning. it was fine for a couple minutes then I heard a "pop" and picture went out. Red light blinking.
lamp burned out and popped all you need to do is replce lamp.the lamp part number is xl 2400.there is a door on the right side of tv.remove door and then remove innerdoor by turning handle carefully. then pull ring attatched to lamp housing.then replace in reverse order making sure inner door is replaced properly cause there is a safety switch on inner door that wont let tv power up if not replaced correctly. this should solve your problem good luck .
May 17, 2011 | Sony KDF-E42A10 42 in. LCD Television
TV doesnt turn on
Replace your Lamp XL2400 Mats Has them 1-800-628-1118
Mar 24, 2010 | Sony KDF46E2000 46" Projection HDTV
Tv will not turn on and on the power light blinks red 3 times
change the lamp XL-2400 AND RESET THE LAMP TIMER AFTER.
Oct 02, 2009 | Sony KDF42E2000 42" HDTV
Sony kdf e50 a60 when TV is turned on picture goes off almost immedately and red light starts blinking in stand by mode.
Red light blinking is an indication of lamp problem. Check and secure tightly the following:
  1. Outside lamp cover
  2. Lamp door
  3. Lamp
If all of the above does not solve the problem, you need to replace the lamp. Let the lamp to cool for 30 minutes after unplugging. Use XL-2400 replacement lamp.
  1. Remove the outside lamp cover.
  2. Remove the lamp door.
  3. Pullout the lamp
  4. Hook a finger through the loop of the lamp handle and pull the handle upwards. Then pull the lamp straight out.
  5. Mount the new lamp securely.
  6. Reattach the lamp door. Turn the knob back to "CLOSE" and secure the cover.
  7. Put the outside lamp cover back in its place.
or visit http://www.fixya.com/support/t2631342-need_replace_42_in_sony_wega_hdtv
Aug 11, 2009 | Televison & Video
I need to replace my 42 in Sony WEGA HDTV Projection lamp KDF-42E2000
Lamp code XL-2400 is Sony part number F93087500 and it is available on http://www.partstore.com/. You may also decide to purchase the less expensive Philips Lighting lamp part number F93087500RL. Either will work for your television set.
Jul 19, 2009 | Sony Office Equipment & Supplies
After installing the XL-2400 Lamp unit. This is the blub and housing. I turned the TV on and after a few moments the tv turned off and on the front of the tv where the power light is it is flashing red.
Please make sure lamp cover is reinstalled securely after replacement of lamp in TV.
If lamp cover is not fixed properly, TV wont power up and red light will start blinking.
Jul 16, 2009 | Sony (XL-2400) Projector Lamp for...
Tv will not turn on
For dark picture I need to ask one question, How long ago you replaced its lamp? one year, two years?
Picture brightness is depends on lamp in LCD rear projection (DLP) TVs and if lamp got weak in generating light, you will see dark picture.
I would recommend to replace lamp and buy Sony original lamp from Sony Accessories Store.
Required lamp part number is as follows..
F93087500 LAMP BLOCK ASSY XL-2400
and price is $200
Good luck.
Apr 29, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
REPLACED LAMP WITH XL2400 AS REQUIRED
3 time blink shows that Lamp Cover is not fixed properly. Please check Lamp Cover and make sure its fixed securely.
Mar 25, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony KDF-E50A12U TV Swith on ok, after about 30 seconds the tv goes into standby mode, green power light on with 3 rapid red flashing lights. Any assistance appreciated
red light flashing means it can't dectect lamp housing. you can try and take it out (door on side of TV to the right hand side) and reinsert. But it probably means your lamp has blown. Replacement xl-2400 lamp is east to replace. Search ebay to buy one (about £100) and youtube has a video showing how to do it.
Dec 22, 2008 | Televison & Video
Sony KDF-50E2000 50" HDTV Logo
54 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
