Question about Wilbur Curtis Curtis TCTS10000 3-5 Gallon Stainless Steel Iced Tea Brewer - 120V
Gets an error code sensor problem in the screen
E000079-0001
The E079 error code indicates the home position of the outside heating roller (engagement) home position sensor does not get detected. The outside heating roller (engagement) home position sensor does not go off.
The detail code 0001 indicates the home position sensor does not go on within 5 seconds after the start of the home position search.
The error code does not reset after the machine's power is turned off and on again.
Check the position of the outside heating roller home position sensor's (PS22) flag. The flag can easily be moved out of position or broken during transport.
Note: the parts manual refers to the outside heating roller home position sensor as PS66 rather than PS22. (See figure 810 page 2-156)
Apr 28, 2012 | Canon imageRUNNER C5800 Copier
What does error code #e1 mean on Canon CLBP 460 PS mean?
Meaning of error code E1
The motor sensor or sensors, the DC controller on the main board DC controller.
I can not give solution to your problem, because possibility of damage main board.
I suggest you contact Canon Customer Support (e-mail, telephone, or repair contacts).
Nov 16, 2011 | Canon CLBP 460 PS Laser Printer
Code 3452 and my touch screen is not working
These could be related problems, however I doubt that they are. The error code 3452 refers to thermistor not reaching temp within specified 30 second time frame. There is a sensor there that monitors this. Touch screen may not work due to error code. However, I'm a little suspect that it may be a different problem. But first, let's solve the initial issue and then move onto the screen.
Try clearing the error code first, and then if it appears again, you'll need to look at replacing either the sensor or thermistor. If you are not a certified technician, but attempting to resolve yourself, I would suggest sending the fuser back to whomever you purchased it from and telling them to supply you with another one. During rebuild they probably did not properly gauge the sensor from the fusing roller. therefore it is not able to properly monitor temperature. (very common problem)....
Here is the instructions for clearing the error code:
1. Turn OFF the Main Power Switch.
2. Turn Main Power Switch ON again while holding down the Utility/Counter key more than 10 seconds after. A screen will appear saying "TROUBLE RESET"
3. Touch "TROUBLE RESET".
4. Check to make sure that "OK" is displayed below which confirms it has been reset.
If "OK" is not there , it will show a different code....
IF it says "OK", you should be good to go. Error code should now be cleared.
5. Just Turn off the Main Power Switch wait at least 10 seconds....and turn it on. Make sure that the machine properly starts.
** If it re-displays the code again within a short period of time, replace the fuser unit. Or get a certified technician to replace the or adjust the sensor or Thermistor unit. However, since you just purchased this I will assume that it is either a defective unit from manufacturer, or the company who rebuilt it did not properly ensure it was working. Return it and demand a replacement in EITHER case!! J
Hope this helps
Sep 02, 2011 | Konica Minolta bizhub C450P Laser Printer
General Electric Radiant Slide-in Range JSP39: The oven does´nt work, in the screen appear F-3 very often, and inmediatly it gets off, sometimes appear F-2 and then gets off
These codes indicate an over temperature condition. The F2 & F3 error codes both mention the temp sensor. The temp sensor is mounted inside the oven cavity & regulates the oven set temperature. If the temp sensor fails the oven could overheat. This is what generates the error codes. I recommend having the temp sensor checked with an ohm meter, at room temperature the sensor should ohm out at approx 1100 ohms. If the sensor checks ok, then the control will need to be replaced.
Jan 20, 2011 | GE Profile 30" Self-Cleaning Slide-In...
E1 and E4 error code desplay on the screen induction cooker. what is the fault in the induction cooker?
E0 error - ensure pot or pan is placed correctly
E1 error - the circuit has malfunctioned
E2 error - the temperature sensor is opening circuit or short circuit
E3 error - the voltage is higher (140 - 160V) for 3 seconds
E4 error - the voltage is lower (80 - 100V) for 3 seconds
E5 error - the cooktop surface temperature is too high
E6 error - Internal electronic temperature is higher than normal for 3 seconds
E7 error - Internal electronic temperature sensor is opening circuit or short circuit
Dec 12, 2010 | Stoves Heating & Cooling
The meaning of error code 24?
Hi, F24 error code a water temperature sensor error or enought hot water to the washer.
check to see you have both valves are turned on. Also, the water inlet valve on the washer has a screen and it is known to get clogged and restrict water flow. Turn off the hot water valve. Pull the hot water hose off where it attaches to the back of the washer.
Even if you are getting good hot water flow, inadequate water temperature can cause an F24 error code. Check the temperature setting on your hot water heater. It should be set at 120 F. You should reach this hot water temperature at your washer within about 1 minute.
If you are getting a good hot water flow, you may one of the following failures:
1 loose or dirty connection at the temperature sensor or control board.
2 The temperature sensor could be out of range. Bad or shorted sensor
3 Control board failure.
The temperature sensor should have a resistance reading of 6.6k ohms at 104 degrees F and should drop in Ohms as temperature rises,
The temperature sensor is located at the back lower section of the tub with 2 small black wires. It would require a ohm meter to measure the resistance of the sensor. .
Sep 13, 2010 | Kenmore HE2 Plus Front Load Washer
Code 131 appears on the screen. How do I fix it?
The code 131 indicates Rotor Position Sensor Error. The Motor Controller has found an error in the pattern received from the Rotor Position Sensor. This code appears due to bad connection on the harness between the Rotor Position Sensor and the Motor Controller Module, or a faulty Rotor Position Sensor.
1) Check for corrosion on the edge connector of the Rotor Position Sensor and the Motor Controller Module connector.
2) Check the contacts on the Rotor Positional Sensor end of the Hall Harness to see if any have been damaged. (Each set of contacts in the socket has two wipers. If the distance between these wipers varies between different contacts, replace the Rotor Positional Sensor Harness).
3)Check the Rotor Position Sensor with an R.P.S. tester. Replace if it is found to be faulty.
Thank you !!
Jun 29, 2010 | Fisher and Paykel IWL12 Top Load Washer
Cannon MP600-where do you see Error Code? I just get "Paper output slot" paper is jammed; but it's not!
That error usually comes from the sensor under the platen roller. It's a tiny black plastic piece that the paper pushes when it passes under the platen roller. The end can bend when you pull out a jam, or a tiny paper scrap can hold it down. The same screen gives error codes when there are other malfunctions, the error now is just that sensor.
Dec 29, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Dsc232 code 571 how to reset
Error code 571 is for oil overflow sensor error.If you pull out fusing unit,on the left side of it there is an oil unit attached,that has oil sensor on it.Most common problem is the sensor is getting disconnected.After you checked the sensor connection,here the procedure to reset the error code:
Turn main power switch off and back on.Then press "clear modes" key, 107 and press and hold "Stop" key for until you see screen has changed. Touch "Copy SP" tab on the screen, the press 5810 and # key. Press "Execute" tab on the screen to reset fusing error code.After that turn the main power to the machine off for a few minutes.Turn the machine back on - the error code should be gone and the machine should be working now.
Oct 05, 2009 | Gestetner DSc232 Copier
Canon IR 400
i have canon ir405 cpier it dispays error code E243 please help me sir
Jun 01, 2009 | Office Equipment & Supplies
Wilbur Curtis Curtis TCTS10000 3-5 Gallon Stainless Steel Iced Tea Brewer - 120V Logo
129 people viewed this question
Top Wilbur Curtis Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Wilbur Curtis Kitchen Appliances - Other Expert? Answer questions, earn points and help others
