Question about Alpine INE-Z928HD - 8" In-Dash Navigation Receiver
Alpine ine-z928hd problem with software update
I know I followed te directions but the unit shows "no data" when memory stick is inserted in the USB port.
    New Friend:
  • 87 Answers
Be sure to format the memory stick using fat or fat32.
Posted on Apr 18, 2014
Color code for RCAs on Alpine ine z928hd
its all relative. keep the reds on the same side and the whites on the other.
Mar 04, 2014 | Rockford Fosgate 800.2 Car Audio Amplifier
Re MiBody 360 Personal scale. downloaded software successfully (Windows XP) inserted USB into scale and stepped on . waited for a few seconds then put USB in PC but no data transferred (PC recognised USB...
Make sure that you have selected USR1 each time you weigh yourself.
When you stand on the scales it records your measurements against that user ID and holds them in the internal memory of the scales.
When you have taken a few readings and when you are not standing on the scales, insert your USB memory stick (any memory stick will do) and press the SET button. The scales display "USB" and write the data out to the memory stick and gives you a message "END" afterwards. When you insert the memory stick into your computer you can read the data into the Homedics software
Aug 26, 2013 | Health & Beauty
Is alpine going to upgrade the usb formay from fat32 to ntsf for playing memory sticks in unit or how do you format music to fat32 on a windows xp ntsf format without wiping out hard drive
The Alpine CDE-103BT requires only USB media that is FAT12/16/32. You can format your USB medium on your PC to FAT32 then copy your media (music) to the the USB drive.
Insert your USB Drive to the PC On your PC navigate to Start ->MY Computer Then locate your the drive that is your USB Drive. At this time you will want to save any of your data before continuing. All Data on the USB drive will be lost. Next ensure that you have selected the correct drive. Right Click on the drive on go to format... Under File System select FAT32. I would suggest leaving Quick Format unchecked. So you ensure that will information is removed. Then Click start. Next copy your media (music) back to the USB Drive. Insert in to the CDE-103BT Stereo.
Notes: MP3/WMA/AAC files are prepared, then stored to a USB memory. This unit can recognize at least 100 folders (including root folder) and 100 files per folder stored in USB memory. Do not make a file's playback time more than 1 hour.
Nov 07, 2010 | Alpine CDE103BT CD Reciever iPod and USB...
My memory stick has stopped working, nothing shows up when I insert it into the computer...I need some of the files which are stored on it, do you know how I can fix it?
Files on a flash drive can be corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon and then click on the flash drive you want to remove and then remove the flash drive when the computer message says it is Safe to remove.
To restore the flash drive you may need to format the flash drive, but you will lose the data stored on the flash drive.
If you need the data on the flash drive this program may help: -
Digital Photo Recovery
www.artplus.hr/adapps/eng/dpr.htm
Nov 12, 2009 | Sony 1GB Memory Stick PRO Duo Memory Card
I have pictures on the card that show up on my
Keep the memory card in your camera....plug your camera into the computer and then turn your camera on...options should start to appear on the screen...follow the questions to get your solution...
Nov 08, 2009 | Sony 2GB Memory Stick PRO Duo Memory Card
Want to update my sharp blue ray disk player bd-hp21u - does not play current disks
To obtain the software update file, please call 1-800-BE-SHARP (23-74277). Save the update file into a USB drive.
  1. Insert the USB memory device
    with the update file into the BD
    STORAGE/SERVICE terminal on
    rear of this player.
  2. Press SETUP to display the SETUP
    MENU screen.
  3. Press arrow keys to select
    “SETTINGS”, then press ENTER.
  4. Press UP/DOWN keys to select “SOFTWARE
    UPDATE”, then ENTER.
  5. Enter the 4-digit number using 0-9.
  6. Press ENTER to start checking data
    in the USB memory device.
  7. During the data checking,
    “Checking” blinks.
  8. The current version of this unit software
    and the version of the update file on the
    USB memory device are displayed. To
    update this player software with update
    file, select “YES”, and press ENTER.
  9. If the USB memory device is not
    properly installed or the correct update
    file cannot be found on the USB
    memory device, an error message is
    displayed.Check the file on the USB memory
    device, and then reinsert the USB
    memory device correctly.
  10. Press ENTER to start updating.The screen becomes dark for a
    while until the update screen can be
    displayed. Please wait for the update
    screen to appear. Do not unplug the AC
    cord
  11. When the software is successfully
    updated, a screen is displayed
    indicating that the update process is
    completed.If the update has failed, check the file
    in the USB device and try Software
    Update again.
  12. Press POWER to turn off the player.
  13. Remove the USB memory device.
Oct 18, 2009 | Sharp BD-HP21U Blu-Ray Player
I am not able to open my memory stick of data traveler 40 gb
Dear,
You can do then please
!. Check the same Memory Stick on another PC (if possible then of same configuration as your PC)
2. Make sure your Pc has Updated antivirus.
If both are Ok then follow the steps
1.Backup the Memory Stick data on other PC.
2. Format the Memory Stick.
3. Paste the data back to the Memory Stick.
It will solve your problem.
Regards,
Rakesh Kumar
Apr 03, 2009 | Electronics - Others
Cant upgrade my ps3
maybe you didnt download the update data to the memory stick, maybe you downloaded it to your pc. Next time download the update data to the memory stick and not the pc.
Aug 13, 2007 | Sony Playstation 3 (PS3) Console
Alpine INE-Z928HD - 8" In-Dash Navigation Receiver Logo
112 people viewed this question
Top Alpine Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
SHARCNET-USA
SHARCNET-USA
Are you an Alpine Audio Player and Recorder Expert? Answer questions, earn points and help others
