Question about Gateway M6307 Notebook
Gateway M-6307 power dies on boot up (reaches widow screen dies)
I recieved a Gateway M-6307 from a friend. Some friend the laptop turns on goes to the windows screen and dies (turns off) what is the issue with this CPU
  • 10,515 Answers
Make sure that it must be charged. If you are sure, there might be a problem of overheating.
If you check, there is a CPU fan. Overheating might cause thie.
Use a vacuum to cool on the fan to make it spin manually, hmmm it actually started to work after that.
If not, let me know.
Thanks for using "Fixya".
Posted on Jun 18, 2009
How do I set the numb lock key to activate at startup on gateway laptop with widows 7
Often, there is a setting in the BIOS.
Other than that, I have not experiments with it.
Here are some suggestions for XP and Windows 7
Turn NUM LOCK on at start up
For Windows 8, there are some instructions:
Num Lock not turned on when booting Windows 8
Aug 19, 2014 | Computers & Internet
Tiene bluetooth la gateway 6307
You will find out if you try the following. To turn the Bluetooth radio on: 1 Enable the Bluetooth radio by sliding the wireless network switch to the ON position. If the Bluetooth radio does not turn on automatically, press FN + F6.
Jun 18, 2014 | Gateway M6307 Notebook
Como activo el bluetooth de la gateway 6307
Juan Manuel,
I have to apologize that I can only post this in English. I was able to understand your question though.
You want to know how to turn on the Bluetooth Features of your Gateway 6307.
Try the instructions below:
1. Enable Bluetooth on the mobile phone or other Bluetooth enabled device. This procedure is dependent on the make and model of the phone or the device. You need to see the user manual accompanying your mobile phone or device to see how to enable Bluetooth.
2. Turn on your Gateway laptop. Check the area next to the clock in the System Tray. There should be an icon with a stylized "B" on a blue background. This is the Bluetooth icon. Double-click on this icon and select "Enable."
3. Go to Control Panel. Locate "Bluetooth Configuration" and double-click on it. A window should pop up.
4. Select the Accessibility tab. Check the option "Let other Bluetooth devices discover this computer." A check mark should appear against this entry 5. Select the Local Services tab. Startup type for all services should be set to "Auto."
6. Select "OK" and click. Wait for a few seconds. Your laptop should have Bluetooth enabled by now.
I hope this helps.
Gateway MT6707 Laptop...Will not boot. I get an error at start up to "fix problems or Start Windows Normally........I have tried both. Just gets to the screen That shows Gateway and Please...
You need to launch the Last know good configuration to get this fixed.
Follow the steps below,
Step 1: Shut down your PC completely.
Step 2: Turn on the Power button.
Step 3: As soon as you turn it on start hitting the F8 key on your keyboard until you get to a black screen called "Windows Advanced option". (If you don't get to that that screen but you end up reaching the blue screen than that means you have delayed in hitting the F8 key. start again from step 1.)
Step 4: As soon as you reach "Windows Advanced option" use your down arrow keys to choose an option called "Last know good configuration".
Step 5: Select that and HIT ENTER.
Step 6: your PC will boot to the windows.
Dec 19, 2010 | Gateway MT6707 Notebook PC
My Gateway M-6307 has a backlighting issue. The computer works but the screen is really dim. External output works, but dim on the LCD. I have switched LCDs from another Gateway laptop...same results. I've...
Have u tried replacing or trying a different power supply? Sometimes when a power supply is going bad will not put out the right voltage for the internal switch to kick up the brighter setting. Therefore it still thinks its on battery mode. Test the voltage from the supply and compare it to the recommended voltage gateway suggest for that laptop.
Jun 24, 2010 | Gateway M-6307 Notebook PC
How do I take apart my gateway laptop model 6307
Here's a link to the component replacement guide for this laptop model:
http://support.gateway.com/s/Manuals/Mobile/8512949.pdf
You can make use of this document to know how to take apart your laptop.
Dec 20, 2009 | Gateway M-6307 Notebook PC
My Gateway M-6307 Notebook wont turn on
Ezra, It could be: 1. Dead battery due to faulty Charger. Check the voltage of the charger output. Replace if dead. 2. Dead battery NOT because of charger. You can check it by plugging into the wall socket. Replace if found dead. 3. Faulty power jack on the laptop. Replace it if battery is fine. 4. Faulty power on switch. Needs a replacement. 5. Fault ahead of the switch, then need a professional job.
Nov 08, 2009 | Gateway M6307 Notebook
My computer monitor will not display properly
this is the first way. use external monitor. if you get clear view then you have a problem with LCD INVERTOR (you say bulb).
i hope it works.
May 27, 2009 | Gateway M-6307 Notebook PC
Gateway M6307 Notebook Logo
180 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
