Question about Makita BMR100 Radio
Makita radio bass adjustment - Makita BMR100 Radio
Makita radio stoped working
mine shows 'E' on display. was sent away to be tested by Makita they said nothing wrong, faulty battery. bought new battery, still doesn't work. Makita not pulling their weight
Jul 04, 2014 | Makita BMR100 Radio
Can't turn down bass on makita radio
Try using a high pass audio filter soldered to the speaker terminals.
Jan 21, 2013 | Makita BMR100 Radio
I have 06 ultra evrything works but no sound.i have got new speakers.plugged buddies radio in and it worked on my bike
You Have a bass with your headphone
You have to connect bass power and connect it audio wire to your computer or other players then turn on your headphone and find its wave by an adjusting volume on headphone.
By Khalil Zareh
khsh4343@yahoo.com
Mar 20, 2010 | Harley Davidson 426290 AM/FM Radio
I have an amp powering two subs but only work with the radio and not when its in aux mode or cd mode. do i need some other conection
I am not familiar with your head unit but I know some radios can control audio options for each source. My unit has adjustments for bass treble fade sub out etc in each source like radio, dvd, cd usb etc. I would check this first. For example, my radio can have the bass set to zero while the dvd can have the bass set to 5. If this is the case for your stereo, the sub out for the different sources can still be set to off.
Feb 22, 2010 | Alpine CDA-9851 CD Player
Pioneer- ipod doesnt have bass
On the EQ on the ipod turn it to bass boost if not try a new cable
Feb 12, 2010 | Pioneer DEH-P7600MP CD Player
Sony radio cdxgt210
Use the main control knob. The one that turns your volume up and down. If you press it in it should go through bass, treble, fade, balance, and sub. Then use that same knob to adjust it by turning it left or right.
Jan 20, 2009 | Car Audio & Video
Radio: panasonic cq-hx2083u
all radios do it these days so yes u must check if it has an rca line out for the amp
Oct 05, 2008 | Car Audio & Video
How the heck do I adjust the radio sounds (Bass/Treble)??
in newer sound systems they usually have an button that says audio with push of the button it should give you options of adjusting balance fade bass treble etc.
Aug 27, 2008 | 1999 Porsche Boxster
Makita BMR100 Radio Logo
139 people viewed this question
Top Makita Audio Players & Recorders Experts
Gil Shultz
Are you a Makita Audio Player and Recorder Expert? Answer questions, earn points and help others
