Question about Logitech Computers & Internet
Mk320 battery level - Logitech Computers & Internet
How to install my Logitech wireless keyboard(MK 320)
YOUR KEYBOARD SURE A RESET BUTTON ON THE BACK. FIRST TURN YOUR KEYBOARD MAKE SURE THE BATTERYS ARE FULL THEN HOLD THE SWITCH ON FOR 5 TO 10 SECOND
THEN FOLLOW THE INSTRUCTION ON YOUR SCREEN TO RESET AND ACTIVATE YOUR KEYBOARD.
Sep 28, 2014 | Logitech Wireless Desktop MK320 Keyboard
POSSIBLE BATTERY DRAIN
I JUST had the same problem and spent 6 hours with tech support.
Click the wifi button on the bottom right and then when it\'s loaded, click Fn & F5 at the same time. A pop up should show up. By wifi click ON.
Jul 15, 2013 | Logitech MK320 WIRELESS KEYBOARD AND MOUSE...
Logitech mk320 usb receiver is missing can i get alternative causing my both keyboard & mouse are lying idle, iam from hyderabad, please give solution, thanks for helping
Good luck with this. I have been searching for a replacement dongle for 3 years now and cannot locate any. There are replacements for K320 and M320, but none for MK320. If you find one, I would really like to where you got it.
Jun 15, 2011 | Logitech Computers & Internet
HOW TO KNOW WHEN MK320 LOGITECH KEYBOARD CAPS LOCK IS ON/OFF
If it's typing in all capital letters (it appears to be doing so), then your Caps Lock is probably on.
May 20, 2011 | Logitech Wireless Access Duo Optical...
I hace logitech mk320 keyboard and mouse theyhave stopped working please advise
Verify that they are connected to the PC. Make sure the hub is plugged into a working USB port on the computer. If they are connected, replace the batteries. If this does not work, unplug and plug the hub back into the PC. You can also try unplugging the hub then shutting the computer down and restarting it. Then plug the hub back in.
May 10, 2011 | Logitech Keyboard & Mouse
Were is the mute button on the mk320 logitech
At the top of the keyboard it is the 3rd silver button from the left.
May 04, 2011 | Computers & Internet
How do you open the wireless mouse for the MK320 so I can change the battery??
To change the batteries in your Logitech MK320 desktop keyboard and wireless mouse, simply turn the mouse over. Move the on/off switch to the off position. Press the battery button and slide off the cover. Insert the batteries negative side first. Replace cover. Turn mouse on.
For a detailed visual diagram, click here:Logitech MK320 Suppport
Apr 04, 2011 | Computers & Internet
Computers & Internet Logo
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
