Question about Harmar Automatic Electric Wheelchair Lift
Lift won't go up and down - Harmar Automatic Electric Wheelchair Lift
Lifting deck won't lift
Inspect the linkage connecting the lever to the deck. That's what I would do.
May 14, 2013 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Lift is out of vehicle and won't go up or down
Sounds like the jack screw has bound. That requires a complete disassembly and inspection to see if it just needs lubrication or a part.
Feb 27, 2013 | Pride Backpacker Avp Lift SSBPAVP
Hydralic bar stool won't go up or down
We have the same model with the picture. It's better to change a new gas lift one.
Oct 18, 2012 | Lumisource Black Ripple Hydraulic Barstool...
Craftsman lawn tractor parking brake won't engage
are you holding the lever while lifting your foot of the pedal?
Jun 27, 2012 | Garden
97 Mercury Mountaineer driver side door won't open. Outside handle flops around; inside handle won't open door
Try a slim jim first, down the side of the window. Or AAA or locksmith. If no luck, remove the seat first. Find the screws and bolts around the door handle and arm rest. Most Ford's have screws around the outer side of the panel. I don't believe your's does. The panel lifts or pops off. Once the panel is off, you can reach down and open the door. Just a note. I have done some to where the panel came out in pieces.
Mar 14, 2012 | 1997 Mercury Mountaineer
I have an activa 130 and the foot won't go all the way down
Is your machine fitted with a knee-lifter ? If so, its possible the knee-lift mechanism has got stuck, which will prevent the foot from coming all the way down. It's also possible that the foot lifter bar has slipped which will require re-setting. When the foot is lifted and the feed-dogs are dropped, there should be a clearance of about 7.5mm between the underside of the foot and the stitch plate.
Mar 02, 2012 | Bernina Activa 130
Cant get the sparetire to come down on my 03 surburban
Those GM truck spare tire lifts can be a problem. There's a secondary catch to prevent the tire from accidently coming down. The problem seems to happen when corrosion sets in due to exposure to the elements. The secondary catch won't release. If you can lower the tire a little bit you should be able to reached up over top the spare tire and the lift. In the center is a bolt the holds the lift in place (I believe it has a 15 mm head). I removed the bolt and was able to lower the tire and lift assembly. It's easier to clean and lube the lift if it's on the ground. Check the spring at the end of the cable. If it's brocken you'll have to replace the lift.
Jul 24, 2011 | 2004 Chevrolet Suburban
Where do I find the front hood release on the car?
Bottom left next to driver's door is the pull handle.
Reach under the hood (you may have to pry a bit to get your fingers in there, particularly if the hydraulic gas lifts are dead so the hood stays down), slightly down and right from center. There's a flat lever you'll push right to release the catch.
Have about a 4' stick handy to prop it up if the lifts are dead, and make sure it's someplace which won't slip, if you do that.
Lube the mechanism with light oil such as 3-in-1 while you're there, and replace the lifts if they won't hold the hood up, not a big deal to do or costly...
Apr 16, 2011 | 2000 Mercury Grand Marquis
Harmar Automatic Electric Wheelchair Lift  Logo
Top Harmar Health & Beauty Experts
wcdoc1953
wcdoc1953
Are you a Harmar Health and Beauty Expert? Answer questions, earn points and help others
