Question about Refrigerators
I have an Amana Refrigerator Model # ARB2202CC Freezer on the bottom. the coils keep on freezing up causing the fridge to warm up. after thawing the coils it freezes up after about a week again.
Where is the defrost timer located?
Posted on Jun 23, 2009
  • 35 Answers
BAD DEFROST TIMER OR TERMINATOR OR HEATER
Posted on Jun 18, 2009
I have an Amana A4TXNWFWW01 and at the top part of the fridge there is two vents. These vent freeze over and the fridge quits working. Does anyone know what is going on?
The defrost heater has a defrost limit thermostat ( a small disc with two wires) that is attached to the cooling coil. This defrost limit thermostat is a switch that will open when the coil is warm enough after defrost. If the defrost heater is staying on too long it can create steam which will condense and freeze on the vents after defrost period terminates.
Jul 14, 2014 | Amana A4TXNWFWW Top Freezer Refrigerator
Why do freezer coils ice up on my Stainless Steel Whirlpool refrigerator (model GB2SHDXTS)?
On your model your cntrl board has a relay that can stick causing the compressor to always run even when the unit is turned off or in defrost. turn the fridge off, move the temp of the freezer to it's warmest setting and it should display a line in the freezer and fridge temp display. listen to hear if the compressor is running in back of the unit. if it is you need part number: 12868513
Mar 15, 2013 | Whirlpool Refrigerators
My freezer is freezing food fine but my refrigerator seems to be warm and not cooling like it should. The temp control has been adjusted to a higher setting but does not seem to help.
if your freezer is working your fridge is fine
Your problem probably started a couple weeks ago when the drain that allows defrosted ice (water) to drain into the drain pan at the base of your fridge became plugged for some reason. Then everytime the fridge went on defrost more water melted but did not drain which in turn froze. Now ice has built up and caused the air that flows into the fridge to be blocked, causing a warm fridge.... my advice is to leave fridge unplugged for 48 hrs to thaw it and find the cause of the water not to drain... could be a corn niblet or pea from the freezer... the tube should be visible from the inside or the back
Jul 21, 2011 | Amana ABB1927DE Bottom Freezer...
Freezer works, but has some ice forming and refrigerator not cooling.
The refrigerator half of a refrigerator/freezer does not produce any cold! The refrigerator is cooled by transferring air from the freezer to the fridge. The fridge temperature setting controls a flapper between the freezer and the fridge. There should be a fan which blows air from the freezer into the fridge (through the damper).
If the ice forming in the freezer is concealing the cooling coil and air can not move through the coils, then the overall result will be a warm freezer (even though there may be ice in one location) and a warmer yet fridge. This can be tested by unplugging the fridge and allowing a complete thaw. If the ice is the cause of the problem, then it should work for a short while until it freezes up improperly again
:o).
Jun 04, 2011 | Whirlpool GB2FHDXWS (63 cu ft) Top Freezer...
Hi. I have an Amana/Maytag Fridge. Model ABD2233DES bottom freezer. The fridge was working fine, then it seemed like the compressor or motor started to make a funny noise. Like it was working hard or...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 24, 2010 | Microwave Ovens
Problem with the Amana Easy Reach AFD2535DE Bottom Freezer Refrigerator Clicking, buzzing, compressor too hot, thawed out freezer, fridge is semi cool
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
heatman101
Oct 10, 2010 | Amana Easy Reach AFD2535DE Bottom Freezer...
Amana refrigerator, bottom freezer. Back keeps icing up. I have unplugged and thawed it twice, within 2 weeks it is frozen again and freezer warm
This is a defrost problem most likely caused by a defective defrost thermostat. It is located in the freezer compartment behind back wall on top right hand side of coils and usually has a brown and an orange wire connecting to it. It should have continuity when checking with a volt/ohm meter when it is frozen and read open when it is warm.
I have seen many of the newer electronic temperature model bottom mounts with defective control boards as well that cause the fridge to skip the defrost cycle.
Jun 14, 2010 | Amana Refrigerators
Samsung RB215BSSB refrigerator freezes up
I had a similar problem where my evaporator coil was freezing into a block of ice, which caused my fridge to warm up due to a lack of air flow. I fixed this by doing a few things. I replaced the circuit board ($100) which was easy to do. Unfortunately, this didn't fix my problem so I took the inner fridge cover off to view the evaporator/heater coil assembly. I checked my thermo fuse and found it to be open (failed). I ordered the thermo fuse and the thermistor and replaced them both. I then plugged the fridge back up and put a regular thermometer inside the fridge to get an accurate reading of inside temp. A few days now and everything looks good. The board, fuse, and thermistor were all pretty easy to replace.
Apr 09, 2009 | Samsung RB2155 Bottom Freezer Refrigerator
Amana side by side
either compressor is jammed or the starting relay with capacity is faculty
Jan 13, 2009 | Amana ARB8057CSL Bottom Freezer...
Kenmore bottom freezer keep freezing up.
just called in a sears technician 150 dollar bill that was an easy fix. he says my bottom freezer kenmore fridge with warm fridge problem was due to the pathway being blocked by ice and garbage which is common with these fridges. he took off cover from the fridge bottom and poured boiling water down to the freezer. try that before you replace any parts or call in a tech. next time im getting a top freezer because the blower is on the top not in the middle with the bottom freezers and thus more problem prone.
Aug 13, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
378 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
