Question about Warehouse of Tiffany Photography
I recently purchased a "Susan" chandelier and am missing part "E" which is the longest needed chain of chrystals. Can you send me a part "E" for this chandelier
What size of chainsaw file do I need for poulan pro PP4620AVX
hi there susan brown6
if your chain is a 3/8 lo pro chain the file will be 5/32nd ------- and if its a 0.325 size use a 3/16th file -------- or if its a 3/8 -0.58 chain use a 7/32nd file
but its more likly to be either 5/32nd( for 3/8 low pro chain ) or 3/16 th for .325 chain
cheers
pauly46
Sep 10, 2011 | Poulan Pro PP4620AVX 46cc Gas Chainsaw...
Recent purchase of Hunter Fan #21648. The following items were missing: Pull Chain Pendant - Pull Chain Extension - Light Bulbs I tried for over two hours to contact you at your 888 number. Each...
James, you can pickup the missing parts from either Home Depot or Lowe's for less than $8.00 and not have to be left waiting on hold for over 5 minutes. FYI - In most cases, light bulbs are not included with the fan. They are shown in the Owner's Manual as a recommendation.
Thanks for choosing FixYa.
Aug 10, 2011 | Hunter Heating & Cooling
I recently purchased a 20"
The chain guard is usually fastened to the seat tube of the bike (the frame tube coming up from the pedal area to the seat) with a plastic band. If this band is broken or missing, and there is excessive play in the chain guard, I suggest removing it entirely or returning the bike as it may be a hazard.
Mar 15, 2011 | Mongoose Cycling
My chain keeps falling of, when i put it back on and tightened the chain tension it brakes the chain. What do i need to do?
The chain shouldn't break from tightening the tensioner. Is this a bad chain? Tension should be tight enough that the chain has about 1/2 inch of back and forth movement in the middle of the longest run.
Let me know if this helps or if you need more information.
Gary
Dec 13, 2010 | Garden
I have a 1600w electric black & decker chainsaw recently purchased that simply takes forever to cut the smallest of logs. Is this the norm?
Hi there Bugs,
Definitely not the norm. I'm guessing that although it was recently purchased, it was used?
It will either need a new chain or have the old one professionally sharpened. You didn't mention bar size, but a new chain should be between $18-30.00.
A less expensive alternative would be a small engine repair shop that services chainsaws. Most also have reconditioned chains for sale.
Eight days ago I picked up a 19" bar banana bar and used chain for $15.00 total to finish some oak. It Rocks.
Try the chain change. Difference? Night and Day.
Best regards
Mike
Jul 30, 2010 | Black & Decker Garden
I recently purchased an AB Rocket. There was no DVD/meal plan
You'll have to call them directly to get what was missing since this was newly purchased their phone # is 800-647-2290 Monday through Friday 8am to 5pm Eastern standard time.
Jun 07, 2010 | Exercise & Fitness
Tried to install a ceiling fan to replace a dimming light chandelier.......light on fan and fan itself works but only by the pull chains....it will not turn off or on by the wall switch that controlled the...
Trip the breaker and verify that the fan/light will not operate. If tripping the breaker kills the circuit and flipping the wall switch would not, the switch is probably bypassed. Place the wall switch to "off" with the breaker tripped to the "off" position as well. Gain access to your wiring connections at the fan. Look for a single (black) wire that is not connected. This should be your hot return from the wall switch Make your fan/light connections to this wire. (Are you sure that the ground wire that you connected is a ground? If it is, it should be bare copper with no insulation). Your white (neutral) connection to the three white wires should be fine. If you don't find a single wire in the ceiling box, call on an electrician. Regards --WoobieDog--
Jul 07, 2009 | Hampton Bay 46056 Callaway II Ceiling Fan
Instruction manual
Go to the manufacturer and request a manual to be mailed to you or sent via email that you can print out. www.gracobaby.com
Good Luck! from Moms Just Know
Oct 22, 2008 | Baby Gear
Chrystal is crack
Hello Cop3480, If crystal is cracked it must be replaced. Costing from $150.00 on up.
Hope this helps
Apr 30, 2008 | Watches
Photography Logo
Top Warehouse of Tiffany Photography Experts
Tony
Are you a Warehouse of Tiffany Photography Expert? Answer questions, earn points and help others
