Question about AOC L24H898 24 in. LCD TV
Remote does not work
Used to work, changed batteries still no luck
    Habit-Forming:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 83 Answers
Try using a digital camera to see if the infrared LED on the remote is sending codes to the TV. If it is blinking, then maybe the problem is the TV and not the remote.
Posted on Jun 25, 2016
Clicker garage door opener
I don't believe that you need to configure it.
It should be preconfigure to work.
What i think after revising the manual and from past experience with car remotes, the type of socket used for the battery inside the remote itself is often missing or broken solder. To make this more clear, the battery socket might need to be resolder on the small circuit board inside your remote.
good luck
Nov 29, 2013 | Viper Televison & Video
Remote doen't work properly
apart from the balance for the speak button on the remote, does other buttons on the remote work or is it all the functions on the remote that is not working any more?
This may be as a result of the faulty remote sensor or problem from the remote.
Which ever the case maybe, the remote need to be changed. But before you change the remote, if you have a friend the has the type of your remote, you can simply use it to test the remote first, before you get another remote.
Good luck.
Mar 29, 2010 | Pioneer Audio Players & Recorders
Remote control not working (no functions),
Do the contacts look ok?
you can check if it is working by looking at it with a digital camera
press a button on the remote
if it shows as flashing on the digital camera screen, then you know it is transmitting.
then your problem would be either the device you are trying to operate is not receiving, or the remote is using the wrong code.
if the code is wrong then look it up online. there are some helpful sites that tell you the codes and how to program the remote.
good luck!
Jan 02, 2010 | Samsung BN59-00678A Remote Control
My remote will not work
Dessasembly the remote control:
1.Clean,use the izopropilic alcool or 75%alcool or finest wisky the remote taste rubber pad.
2.Assembly the remote control,change the batteries(see the polarity).
3.Near on functional in the FM or MW radio (the distance to remote and speakerphone max.10cm) press any buttons to the remote control.If you can hear the emitent signal in the speakerphone ,the remote is work.
4.Try the remote to TV.If work is OK,if not change the infra LED.
The solutions is work 100%,I tested 25 years ago.
Sep 07, 2009 | Vizio VX32L Television
Garage door opener will not respond to security plus remotes
Reset the Liftmaster unit. There should be a red reset button on the unit in the garage. If this does not work, reset the breaker. Good Luck!
Jul 03, 2009 | liftmaster Chamberlain Garage Door Opener...
Does any body know how to reset the ML350 alarm??....The remote control doesn't work after i replaced a new battery to the remote control. I couldn't even use the remote to lock/unlock the car. I was
SOME OF THE REMOTES REQUIRE THAT THE KEY BE IN THE IGNITION, IN THE ON POSITION. TAKE THE BATTERY OUT AND WAIT 10 MINUTES. THEN PUT THE KEY IN THE IGNITION AND INSTALL THE BATTERY WHILE THE KEY IS TURNED TO THE ON POSITION. HOPE THIS HELPS YOU. PLEASE KEEP ME POSTED. THANKS FOR AN HONEST RATING AND FOR USING FIX-YA. GOOD LUCK
May 18, 2009 | 2007 Mercedes-Benz ML350
Sharper Image iTower remote not working
I put a small piece of tin foil on the negative side of the battery and the remote worked again.
Mar 28, 2009 | Electronics - Others
Remote won't work
hi, see if the right funtion is selected, tv, vcr, dvd.then if that does not help, get a universal remote. they don't cost alot or some don't good luck. hope this helps.
Apr 15, 2008 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
Remote doesn't work
the IR [infrared] on your DVD is not working have tech check your DVD for defect.GOOD LUCK
Apr 23, 2007 | Samsung HT-DB120 System
AOC L24H898 24 in. LCD TV Logo
35 people viewed this question
Top AOC Televison & Video Experts
Raj Patel
Are you an AOC Televison and Video Expert? Answer questions, earn points and help others
