Question about Coffee Makers & Espresso Machines
Reset kurig coffer brewer
Does not change cup size
5 Suggested Answers
  • 2976 Answers
SOURCE: Brewer Overfilling
You need a water level float or indicator. Without the brand, model & serial number, I can't give you any specifics but, if you go to the manufacturese website or a small appliance parts website, you should be able to find what you're looking for.
Posted on Jan 15, 2009
  • 473 Answers
SOURCE: grounded coffer does not exit the grinder to the
Issue with your Logic Board...inside Due to exessive humidity..Keypad fail to responce ...
Posted on Oct 06, 2010
heatman101
  • 43501 Answers
SOURCE: the kurig brewer will not
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Posted on Aug 13, 2011
heatman101
  • 43501 Answers
SOURCE: My Kurig coffee maker will not brew a ful cup.
heatman101
Posted on Sep 11, 2011
Bunn is not heating the water
My bunn coffer maker is the one that keeps water hot all the time.
I was going away and shut my coffee maker off. 'When I came home I then had to start over like when it was new. I follow the directions and the ater never heated up.
Jan 19, 2013 | Bunn 10 Cup Home Coffee Brewer
My kurig fill ti one third and then I start over and get two thirds of a cup of coffee
heatman101
Sep 16, 2011 | Keurig B60 Coffee Maker
heatman101
Sep 10, 2011 | Keurig B50 Coffee Maker
The kurig brewer will not pump the hot water after pushing flashing blue ready light
heatman101
Aug 12, 2011 | Coffee Makers & Espresso Machines
My B70 Keurig will not brew. Tried turning power on/off, tried resetting the size of cups to default; nothing is happening.
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
Feb 14, 2011 | Keurig B70 Coffee Maker
Kurig is making a much louder sound when filling with water than usual.
23423nmmSorry to read about your issue.
The brewer should be de-scaled at least every 3-6 months. Scale is harmless, but if left unattended, it can hinder optimal brewer performance. De-scaling your brewer regularly helps maintain the heating element, removable water reservoir and other parts of the brewer that come in contact with water. Better water quality and water heating means a better cup of coffee, tea, hot cocoa or iced beverage. We recommend de-scaling your brewer at least every 6 months (every 3 months if your water has a high mineral content). The de-scaling process involves using 48 ounces of undiluted white vinegar.
Take 48 oz of white vinegar. place in tank. pretend you are making coffee (Do No Use K Cup). let the water fill you mug. then empty that mug. Do it again until tank is empty. then let sit for 4 hours.
Then fill with fresh water to the top. let that tank of water run thru. towards the end taste the water.
If you taste vinegar..use more clean water, until the taste is ok.
I tried to help you. Please help me and Vote/Rate this response. Thanks and good luck
Dec 16, 2010 | Keurig B70 Coffee Maker
My keurig only dispenses a half cup, no mater what size of cup its on, i have reset it and nothing
heatman101
Nov 03, 2010 | Keurig B70 Coffee Maker
We bought a Kurig Mini at this past Christmas. The machine worked great for about 4 months then the Kcups started exploding in the machine and coffee grounds would go into the brewed cup. Then the...
Mine has been doing the same thing.  I alkso received one at Chriustmas and it worked great for a few months.  Below is the answer I received from Keurig:
It is possible that the needle that penetrates the K-Cup has become clogged.  Please follow these simple steps to clean it:
Turn off the brewer and unplug it.
Reach under the nozzle (where the coffee comes out) and press up on the bottom of the funnel.  The K-Cup holder will pop out.
Separate the K-Cup holder into two pieces.  The top piece of the K-Cup holder is where the exit needle is located.
Use a paper clip to clear the exit needle by putting the paper clip in the tube on the underside of the holder. Be careful, the exit needle is sharp.
Wash the K-Cup holder with soap and water, rinse thoroughly.  Also make sure the drawer is clean.
Put K-Cup holder back into the drawer, making sure it snaps into place.
Plug the brewer in and turn on.
Run two cleansing brews (brew without a K-Cup) through the machine, and then brew a cup of coffee.
If you still find grinds in your coffee, it would be best for you to talk to a representative to help troubleshoot your problem and discuss your options.  This could be caused by too much pressure sealed inside the K-Cup or the filter alignment may be off.  Please contact our customer service department at 1-866-901-BREW (2739).  Representatives are available 7 days a week from 7 a.m. – 12:00 Midnight EST to assist you.  Please have the serial number of your brewer available for when you call.
The serial number for the Mini is located on the bottom of the brewer on a silver sticker.
For the Classic, Ultimate and Select, is located on a sticker behind the drip tray.
For the Elite, Ultra, Special Edition and Platinum it may be located either on the bottom of the brewer on a white sticker or, behind the drip tray.
Sincerely,
Briana Keene
Keurig Customer Service
At Home Division
(866) 901-BREW (2739)
csrah@keurig.com
Aug 25, 2010 | Keurig B30 Mini Coffee Maker
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
