Wimdow Air Cond.
Have a Gold Star WG5000 air cond. Can you turn air cond. either vertical or horizontal in window. Don
  • 1,543 Answers
Sorry, that's a no. There are, however, window air conditioners made for casement style windows which are tall and narrow. I know GE used to have them. Check geappliances.com. There are also " portable " air conditioners which sit on your floor and vent through hoses to a window.
Posted on Jun 18, 2009
Why my ac button wont turn ac on
If the refrigerant has leaked out, the Air Cond pump may not turn on. If it has leaked out, you have other problems. ( check for power at the Air Cond. Pump )
Aug 22, 2014 | 1998 Cadillac DeVille
Aircon does not engage when turned on
the air cond requires the belt on or the pump cannot rotate as the air cond is belt driven on every auto that i know of. now if the belt is slipping it is a cause of one of two things. belt is stretched or not tensioned properly, or the air cond clutch is froze up. when you turn on with no belt the clutch is engaged and you will not be able to turn pump with ease. Install new belt and have air checked for proper freon fill
Sep 04, 2012 | 2001 Volkswagen Passat
Air cond. don't leak onto the ground
If you mean the condensation water from the a/c - the drain tube is probably gunked up.
There is a small tube or hose near the passenger floorboard that the water drains thru. You should be able to see if from under the truck.
Jul 06, 2012 | 1995 Jeep Grand Cherokee
Air cond
sounds like a low freon charge look for leaks in the right rear corner where the lines go threw the floor to the rear unit
Jun 05, 2012 | 2005 Dodge Caravan
Ac unit is leaking water out the front into the house whats the reason
Be sure you have the air cond tilted back away from the house. If you have a level, set it on top of the air cond and make sure the unit is tilted back by a half bubble. If you still get water in the house, the drain is stopped up in the unit and you will have to take it out of the window and out of the case and wash it out good.
Jul 09, 2011 | Goldstar WG5000 Air Conditioner
Where is low port to recharge ac?
Near the firewall you have both air cond pipes coming out. There is a black cap on the larger of the two alum pipes. It is under the air filter housing and should be able to see it without removing the air filter housing. That is the low pressure side.
The high pressure should run along the chassis rail and near the radiator there is another black cap on a smaller alum pipe.
Remember always yes always vacumm the air cond system for at least 3 hours to dry out the air cond system correctly. If you don't if will only work for a short time before playing up again.
Some shops don't do this and wonder why a car keeps coming back for more gas. Good for them bad for customer.
Jun 16, 2011 | 2003 Ford Ranger Regular Cab
Home air cond carrier A135H auto light flashes
Sorry don't have a solution for your problem, but I've got one that you may be able to help me with My Remote control, for which I have no user manual, seems to be locked and the buttons won't do anything. I have noticed a key symbol in the bottom right corner and cas only assume it is locked. Anyone know how I can unlock it? Cheers.
May 03, 2010 | Carrier Heating & Cooling
High pressure air cond line has frost about 10 feet inside home
You have a low freon charge or a blockage in air flow. Check the filter if it is clean then there is a low freon charge in your system in which an a/c tech will be needed.
Good luck on repairs
Dave
Jan 06, 2010 | Amana PTH123B35AJ Air Conditioner
Kenmore room air cond fan runs, no cool. checked
if the fan motor is on but the compressor is not : if the compressor has correct voltage up to the terminals and is not operating, the compressor is bad, if ther is not power to the terminals, the start components may be the culprit, if there is no power to the start componenets then the controller is the issue.
Jul 18, 2009 | Kenmore 75123 Wall/Window Air Conditioner
Heating & Cooling Logo
97 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
