Question about Bissell Lift-Off Pet Deep Cleaner
I have a bissell lift off deep cleaner and wont spray from the base
No spray at the base
5 Suggested Answers
  • 3 Answers
SOURCE: my bissell deep cleaner wont
do you mean the little red spinning thing?try unscrewing the clear cover , lift the red thing out and check for hair etc.then put it back together. worked for me, hope it helps.
Posted on Jul 31, 2008
Vac Belts
  • 701 Answers
SOURCE: ProHeat Turbo Deep Cleaner Upright Steam Vacuum: Hello, My Bissell Proheat is not spraying water, ...
Most likely the pump belt is worn and needs to be replaced. Here is the belt you need:
Bissell Proheat Pump Belt
Posted on May 25, 2010
heatman101
  • 43501 Answers
SOURCE: my Bissell PROheat Upright Deep Cleaner
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
ghdhjd
Posted on Sep 30, 2010
bissellcs508
  • 315 Answers
Life Inspired Cleaning Innovations
    Verified Fixya Pro
    SOURCE: How do I get the sprays working again on the Bissell Lift-off Deep Cleaner?
    Here's a quick link to tips to help you with your machine.
    http://www.bissell.com/FAQDetail.aspx?id=18986&cid=ccsocial
    Posted on Oct 26, 2012
    I have a Bissell 2x preheat 9500 and the flow gauge is not turning and the formula is going into the bladder. There is no spray on the clean shot and no water coming out of machine.
    If you look at the location where the tank connects to the base, there is a socket, in that socket is a one way rubber flap. That flap sticks and wont open to allow cleaner into the pump. I used a small screwdriver to press that flap out of the way
    Jul 30, 2016 | Bissell 9500 ProHeat 2X CleanShot Upright...
    Water wont spray from cleaner how to fix
    Try cleaning the Flow Indicator Filter. Turn the Flow Indicator Cap counter-clockwise to remove, lift rotor and filter. Clean filter and replace in reverse order. Bissell's Consumer Care # 1-800-237-7691
    Sep 16, 2015 | Bissell 9500 ProHeat 2X CleanShot Upright...
    My bissel lift off deep clean wont spray water or solution on floor? any tips
    the spray nozzles are probably plugged they are like the ones on your car.unscrew the lower part of the head unit should see them there.
    Jan 01, 2015 | Bissell Vacuum, Lift Off Deep Cleaner
    BISSELL LIFTOFF WONT SPRAY CARPET
    replace the sprayer you can get one of those at guarantee vacuum and sewing center cheaper than any where else
    Mar 21, 2014 | Bissell Lift-Off Deep Cleaner 94Y2
    Bissell proheat2x 8920 wont spray water
    Hey Patti, spray is important when you want to clean. Here's a link to toroubleshooting steps to assist you.
    http://www.bissell.com/FAQDetail.aspx?id=1122
    Jan 26, 2013 | Bissell 9500 ProHeat 2X CleanShot Upright...
    The cleaning solution water wont flow thru the unit. What do i do?
    First, have you check the the owners manual? You can find them at http://www.bissell.com/SearchResults.aspx?searchtext=spotbot&mode=userguides
    Possibilities:
    Spray Tip clogged
    Clean/Solution tank is out of fluid
    Clean/Solution tank is not inserted into the unit securely
    Solutions:
    - Clean Spray Tip
    - Fill Clean/Solution Tank.
    - Gently press the Clean/Solution Tank until you see “bubbles”
    coming from the base of the tank.
    May 22, 2010 | Bissell SpotBot Hands-Free Compact Deep...
    Wont **** up water
    Go to bissell.com go unger frq.asked questions. Also check your belt
    Jul 23, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
    Bissell Proheat cleaner hand cleaner spray but floor cleaner wont
    heatman101
    cnb,m
    Dec 28, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
    Bissell Lift-Off Pet Deep Cleaner Logo
    67 people viewed this question
    Top Bissell Vacuums Experts
    Jim Thurston
    Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
